Old 10-29-2008, 09:44 PM   #1
Oregoon
Roadside Rebuilder
Oregoon's Avatar
My $900 '66 Suburban project begins...
Finally had a chance to snap some photos of my daily driver. Been digging the forums and researching the various projects I have planned. Here's some snaps, with a few questions for ya'll...
Basically, I'm looking to build a fun, family cruiser. I'm gonna drop it, swap to discs with dropped spindles, and c-notch the frame enough to get her nice and low. It has a 292 with 34,000 miles, an SM420, and a posi rear, with 4:11s. Anything over 55 mph approaches redline.
It needs a different tranny, or a rear end swap to improve driveability. While I'd like to keep my rear end stock, I'm not totally attached to it. The 292, however, is staying. So, what would you do? Tranny? Rear?
What would you use? Budget and simplicity are the watchwords for this build.
Oregoon is offline   Reply With Quote
Old 10-29-2008, 10:14 PM   #2
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: My $900 '66 Suburban project begins...
Nice Burban, I like it stock.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 10-29-2008, 11:12 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Smile Re: My $900 '66 Suburban project begins...
Somebody on here swapped in a 700r4 behind a srt8 six. I dont remember reading how sucsessful it was in the end. Too much stuff on here, but I would keep the rear end. Its close to factory set-up on later model overdrive pick-ups.
Looks cool.......I'll be posting pics of my burb here soon to update the thread. Good luck with your project.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-30-2008, 01:32 AM   #4
rickf
rickf's Avatar
From all that I have read and observed (mostly right here) I am thinking the 250 or 292 with 2004R (aka 200R4) would be the hot L6 setup. It is a little smaller and lighter than the 700R4, and I've read that is it easier to hookup. It came standard with V6's (right?) and I bet the displacement between the L6 and V6 is roughly on par,and that the V6 made more power per cube than the L6 (maybe not as much torque down low, though). Anyway, I believe it would hold up fine, especially if you sprung for the fancy hotrod built ones, and would provide a nice freeway gear.
The project you have going there is exactly the project I have fantacized about.
rickf is offline   Reply With Quote
Old 10-30-2008, 04:32 AM   #5
283 Man
283 Man's Avatar
good looking burbgetting harder to find now days.. good luck with your project.
283 Man is offline   Reply With Quote
Old 10-30-2008, 07:10 AM   #6
Tim64
Tim64's Avatar
I took my 3 speed out last winter and installed a 700R4 behind my 250 inline 6. Same gear in rear as you have. I had the same problem with highway speeds as you're having. Now I can run 70mph @ 2200 rpm. The tranny swap and installing a HEI ignition are by far the best things I've done to my truck. It is my daily driver, every day. Bowtie Overdrive has just about everything you'll need from info to parts check out there web-site
www.700r4.com/faq/faq.shtml
Tim64 is offline   Reply With Quote
Old 10-30-2008, 10:33 AM   #7
Woogeroo
sweet Burb!
Welcome the the forums...
-W
Woogeroo is offline   Reply With Quote
Old 10-30-2008, 11:41 AM   #8
Rogue 64
Ol' Blue Viking
T5 with the SM420 shift lever.
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 10-30-2008, 12:00 PM   #9
Oregoon
Roadside Rebuilder
Oregoon's Avatar
I'm digging the T5 idea! Nothing against autos, but I'm a gear-jammer by trade, and I love throwing that stick around. Also, it sounds like something I could come up with from a wrecking yard, thereby saving some coin for further Suburban tinkering.
What did those T5s come in? Anyone done a swap?
Old 10-30-2008, 12:27 PM   #10
Tim64
Tim64's Avatar
There's a lot more to installing a T5 than meets the eye. Not just any old T5 will do. You can get the details @ http://inliners.org/
Go to the T5 page.
Good Luck!
Old 10-30-2008, 01:06 PM   #11
padresag
while the t5's are good they are not up to abuse.(i love throwing the stick around)
ron
padresag is offline   Reply With Quote
Old 10-30-2008, 02:07 PM   #12
Tim64
Tim64's Avatar
As far as cost goes if I remember right around $600.00 bucks in my swap. I gave $250.00 for the tranny. The rest was shifter, crossmember, lock-up kit, speedo kit, TV cable, and a few other misc. items. 700 trannys are on craigslist all the time.
Old 10-30-2008, 05:16 PM   #13
Oregoon
Roadside Rebuilder
Oregoon's Avatar
I'm starting to think a rear-end swap would be cheaper. However, I have the series 4 case, and need a series 3 to use lower gears--I'm thinking 3:54s? Have to lose my posi though. Probably just do a full housing swap, hub-to-hub. Might be easier.
Dunno. Still up in the air. Maybe tranny, maybe rear end. How hard is an automatic swap?
Or... Anyone have an extra NV4500 laying around? Thinking maybe $100?
Old 10-31-2008, 12:44 AM   #14
Captainfab
60-66 Nut
Have you considered a NV3500? Less expensive than the 4500 and stronger than a T5 I believe. You'd have to convert to a hydraulic clutch though.
BTW nice looking Burb!
Old 10-31-2008, 01:14 AM   #15
Frizzle Fry
Frizzle Fry's Avatar
If you want to swap to discs on the cheap you will probably end up going to 5-lug. In that case you might as well get the rear end out of the same donor. After that see if you still need/want a tranny. Sweet Burb. I will own a 60-66 Burb one day...
Frizzle Fry is offline   Reply With Quote
Old 10-31-2008, 09:40 AM   #16
Tim64
Tim64's Avatar
The auto swap takes a little time, but it's not a hard job. Hardest thing for me was removing the old crossmember.
Old 11-01-2008, 12:30 AM   #17
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Here we go: http://www.high-impact.net/transmiss...roverdrive.htm
Two sticks! Just like the '55 Kenworth I learned in!
I came to the conclusion that I want a resto-rod, but I don't want to turn my truck into a car. While I'm still going to do discs, dual master cylinder, and lowering, financial discussions with my supremely tolerant wife led me to the conclusion that I want a family cruiser that can pull a small old-school travel trailer--something to make winter surf trips here in Oregon a warm reality for my kids.
So, I'm keeping my low-mile posi, 4:11s, and granny-tranny, and keeping my truck a truck. I love the idea of 27% overdrive, and four more gears, and that great old-truck gear-whine. Wasn't planning on this one setting any speed records anyway, though the next project will involve a 472 Caddy I've got, and hopefully a short-wide done gasser style...
Anyway, I've been surfing around here, the HAMB, the Stovebolt page, etc, and there's some insane projects happening. Too cool. Everything from budget rats to high-dollar restos, and everything in between. So many cool trucks, and countless styles.
I think I'll try something somewhere in the middle--call it a utility-rod--and see how it pans out. I'm thinking dark green with cream bumpers and 16" steelies, cut springs and some performance goodies for my 292...
Okay, dream time is over for now. Glad I have a concrete idea about where I'm heading.
Thanks for helping me shape my thinking. Comment away!
Old 11-01-2008, 06:05 PM   #18
Frizzle Fry
Sounds like a plan. Here's some inspiration for ya:
Old 11-01-2008, 07:22 PM   #19
Oregoon
Roadside Rebuilder
Oregoon's Avatar
That's hilarious! I downloaded a jpeg of that truck the other day, and thought, "yep, that's pretty much what I wanna do." That's a sweet truck.
Great minds think alike...
Oh, in other news, I got my blinkers, brake lights and headlights to behave properly today. It would seem 42 year-old wiring occasionally needs a good cleaning.
Last edited by Oregoon; 11-01-2008 at 07:24 PM. Reason: I got all excitable, and forgot to type some words.
Old 11-02-2008, 09:58 AM   #20
Frizzle Fry
Can't wait to see it!
Old 11-02-2008, 12:25 PM   #21
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Ah... Now it's my turn to L-O-L. While financially, I'm not totally screwed (I managed to set aside a tiny build-budget), time-wise, I'm hating it. I'm a full time Grad Student at PSU, full time truck driver (Portland to Port Angeles three times a week), father of two kids under 3, husband, surfer, and occasional freelance writer. Oh, and I shattered my right arm about 5 weeks ago...
But hey, the surf season's winding down, my arm is almost healed, and my kids love playing around in daddy's truck while I'm working.
Hopefully I'll get the disc conversion done, and set her down proper by New Year.
Oh, that reminds me: Any local get-togethers ever happen? Looks like there's quite a few of us Chevy nuts along the I-5 corridor. Be cool to meet up and kick some tires!
Old 11-02-2008, 12:33 PM   #22
Stepside65
Still Truckless!
Stepside65's Avatar
Looks to be an awesome project. Best of luck and welcome to the board from SE New Mexico
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 11-02-2008, 02:31 PM   #23
Rogue 64
Ol' Blue Viking
Damn Dood, what do you do in your spare time!
Old 11-02-2008, 02:54 PM   #24
Oregoon
Roadside Rebuilder
Oregoon's Avatar
I relax by swearing at rusty bolts, delving into the innards of machinery I only somewhat understand, and spending my hard earned-cash on a vehicle most people equate with bootleg whisky and disreputable rural dwellings...
Calms me down just thinking about it!
Old 11-09-2008, 01:41 AM   #25
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Got a wiper motor installed today, and new blades. Fun times. Working under the dash usually sucks, but at least there's plenty of room in the Chev! Found a few other odds and ends too: Hubcaps, rear end stuff, wheels.
There's a guy in the neighborhood who has literally millions of old chevy parts.
Old Car Parts
7525 SE Powell Blvd
Portland, OR 97206
Phone: (503) 771-9416
Absoltuely packed with parts from four decades of parting-out GM cars and trucks. He has damn near anything you can imagine. Worth a call for old stuff. No idea about their shipping policies--like I said, they're a short jaunt down the street for me.
Still, great resource! Nice guys, and good about letting me pick their brains.
