#26 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Steering Wheel Restoration
Nice work Mario.
#27 |
![]() Join Date: Mar 2011
I just finished restoring my wheel. I opened all cracks down to steel and used JB Weld steel reenforced epoxy putty, smoothed it up and used SEM plastic adhesion promotor, a couple of coats of epoxy and smoothing, then paint.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#28 |
Great work, I would hardly have thought that possible, definitely a lot of work.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
#29 |
Hello everyone!
After a long time I finished with the steering wheel. Some clarifications, each crack was enlarged with a dremel up to the steel core of the steering wheel. I add some more photos of the painted and already installed on the truck. As you will see my "paint booth" is quite improvised, but with the possible care the result is acceptable. I send you greetings and good luck with your work. |
#30 |
![]() Join Date: Jun 2002
Nice work Mario!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#31 | |
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
Tags |
restoration, steering wheel |
