10-06-2018, 12:04 AM | #1 |
71 c10 swap. Picked up a 5.3 200k miles everything except trans???
Came across a wrecked 2001 Silverado 5.3 with everything except the transmission. Going to install in my 67 stepside. Is there anything I should look out for on an engine with 200k miles and also any ideas on a rough estimate on cost for a transmission
10-06-2018, 04:50 AM | #2 |
Re: 71 c10 swap. Picked up a 5.3 200k miles everything except trans???
Depending on what your paying for the motor, I picked up a rusty driveable 99 2 wheel drive truck for $700 and drove it home, I pulled the engine and trans, it had 250,000 miles, I had all of it rebuilt and engine once torn apart was in good shape and would have went another 100,000+ miles
A trans might cost you $200-$500 and if it needs a rebuild then another $1700-$1900 from a qualified trans shop. |
10-06-2018, 12:09 PM | #3 |
Thank you for the response. I got the truck for free so only $ will be to buy a transmission and get the ecm tuned
10-06-2018, 12:24 PM | #4 |
I would rebuild engine if it has 200k on it...you can actually use your current trans if you wanted to...(not sure what you have)...you can get a remain from oreillys....
.if you want a trans like the 4l60 you'll need the controller for that....but not sure exactly because all mine are manuals...
10-06-2018, 01:50 PM | #5 |
Garage wrench
I'd check car-part.com and keep an eye on craigslist. You could buy any 4L60E in need of a rebuild for $200-$400, then have a transmission shop go through it for $700-$1,200 depending on what you have done, etc. A salvage yard like LKQ also offers reman transmissions for pretty reasonable too.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
10-07-2018, 12:01 AM | #6 |
Thank you all for the info. I currently have a 700r4 installed in the truck. What does it take to run a 700r4 with an LS? Adapter plate, different torque converter or torque converter bolts?
10-07-2018, 12:39 AM | #7 |
Here's some info on a 700r4 behind a LS.....
https://ls1tech.com/forums/conversio...-ls-700r4.html https://www.corvetteforum.com/forums...o-a-700r4.html
10-11-2018, 08:54 PM | #8 |
200k is nothing the 5.3 in my tahoe went 370k before it died just reseal it and let it ride my suburban as 220k still running strong
