Old 02-24-2012, 07:43 AM   #26
68C15
blood type; Retumbo
68C15's Avatar
Re: Offroad lawnmower
I think you're right. the new fronts are too tall and the wheel base is too short. something sized like the old ones and move them forward about 8"
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 02-24-2012, 10:06 PM   #27
muddstir
muddstir's Avatar
Thank you 68C15 for your input Does "old ones" mean the ones on the purple rims.
muddstir is offline   Reply With Quote
Old 02-25-2012, 09:46 PM   #28
Restrorob
The One And Only !!!
Restrorob's Avatar
I agree with 68C15, The size of the purple ones look better on the front.....
Kool build !!!
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-28-2012, 11:23 PM   #29
muddstir
muddstir's Avatar
Kool build !!!
Thanks Restrorob!
I was looking at it over the past weekend and that's what I decided on too but I don't think I'm moving the front end forward, well not 100% sure about that yet.
Now my issue is that I can't get front rims & tires that size to match the back and the purple ones (they are a sport quad rear size) are the narrowest ones they offer in a 10in rim. I need a 10 in rim to clear ball joints, I can get a sport quad front tire setup most run a 10in rim but then there is no aggressive tread designs offered in them. Although when it's in 4x4 both front tires will be locked together so it won't steer very well and with the less aggressive tires that might help and let the inside tire slip and let it turn a little better. I think ill keep looking around at my options. Next on the list is steering but it'll might be a couple of weeks before i get to work on it.
Old 02-29-2012, 01:27 AM   #30
badpeanut
Not a bad nut after all..
badpeanut's Avatar
How does the drivetrain compensate for the different tire diameters front and rear?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 02-29-2012, 11:54 AM   #31
Gokart Mozart
Originally Posted by muddstir View Post
Thanks Restrorob!
http://www.offroaders.com/tech/ATV-T...rclaw-K299.htm
Size Ply S.W. (in/mm) O.D. (in/mm) Max Loading Max PSI/Kgf/cm2 Rim
23x10.00-10 6PR TL 10.2/258 23.0/584 374/170 7.0/0.5 10.0x8
This reminds me of the STi-atv.
Gokart Mozart is offline   Reply With Quote
Old 03-03-2012, 09:05 PM   #32
Restrorob
Restrorob's Avatar
I've started to say something about my build but held off so not to jack your thread, I bought a 96 Polaris Xplorer 400 with a blown engine. I stretched the frame to fit a new Kohler M20 engine I had laying around in front of the Polaris trans, I'm using a steering gearbox out of a mid 80's EZ-go three wheel golf cart. It will be set up as a mini 2 seater UTV with a 58' Pargo four wheel golf cart nose and dump utility bed on back.
Maybe a golf cart steering gear will work in your application ?
My gearbox will be mounted up near a dash position with the steering shaft and tube shortened to about a foot, It will tie into the upper section of the original 4-wheeler steering post via a bracket welded to the post.
As I said, I thought this is a Kool build..... Your putting a mower body on a custom 4-wheeler frame and I'm using lawn mower power with golf cart parts on mine, It helps being in the Lawn-n-Garden equipment/ATV/UTV business.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-15-2012, 10:47 AM   #33
muddstir
muddstir's Avatar
Between different sproket sizes and jack shafts I should be able to get it really close. The only time the 4x4 will be on is when im in something and that should allow for so tire slippage if its need. I going for the same distance per revolution of the old snowmobile track to keep the motor power to the tires the same as if it was on the snowmobile still.--(I Hope). This all is a learning experment, I have no real knowage in all this stuff- I just like to build stuff and learn by mistakes.
Old 04-03-2012, 10:49 PM   #34
muddstir
muddstir's Avatar
Your build sounds cool I like when people take stuff they have laying around and turn it into something that is useful. Got any pics?
I think for my steering i can get away with some arctic cat parts and snowmobile parts I have laying around, I might have to get some small u-joints too. I'd like to make it a direct steer setup. But I'm now thinking of switching to a different motor and that might get in the way of how I had the steering somewhat planed out. So now I got to decide to keep the snowmobile motor or ditch it for and bigger motorcycle motor.
Old 04-03-2012, 11:40 PM   #35
muddstir
muddstir's Avatar
I decided on the tire size that I'm going to run. Even through the winner seams to be the smaller ones which I like better myself I'm going to run with the bigger ones. There were alot of deciding factors that went into it but the main one was couldn't get smaller tires and rims to match what I had for the rear. So I'll use what I have.
After deciding on the size I started to look at my choices to make it look better. I streched the wheel base 3in when I made the frist frame, I realized that I could just move the hood back to offset the front end. I only moved it back about 3/4 of an inch anymore I'd have to drill new holes for the mounts and I would have to cut the hood brackets down to fit, so I can take it back farther but I kinda like where it is now. Then I looked at the body lines to the frame lines and saw something didin't look right. It looked level but low, almost like the tires covered up to much of the body. I ended up lifting the front 1in in the a-arms area and 1in in the hood. I ended up lifting the rear fenders went about 3.5in to get that slight rake look . Now looking at it with all the tires on it it don't look half bad in my book.
Here is a couple of pics of it now
Old 04-17-2012, 05:29 PM   #36
Prerunner1982
Prerunner1982's Avatar
I like the look of those front wheels/tires myself... can't wait to see this come along. Lookin good!
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-22-2012, 10:44 PM   #37
muddstir
muddstir's Avatar
Thanks Prerunner1982, got busy around the house and haven't been working on it for awhile. But now its back in the garage and I got time to work on it.
Old 06-22-2012, 11:54 PM   #38
muddstir
muddstir's Avatar
Been working on getting the shocks positioned but with the motor size it's giving me issues. So this leads me to a ? for anybody that knows anything about a-arms and shock positions.
Here is my issue = with how wide my motor is the front shocks will almost be straight up and down, and that (A) limits the true length of travel of the a-arms and (B) viewing the tractor from the front it looks kinda goofy. So I would like to angle the shocks inward some to fix (A) and (B). Now here is were it gets tricky, I looked at all the atv's I have and all the shocks are 90* to the axis of movement of the a-arm. I assume thats how it works (I could be wrong). Now I was woundering if I took the top of the shock and angled them towards the front about 5 to 10* would it hurt anything/ or is that bad practice when it comes to arm design/ setup. I would cut the shock mts. off and rotate them so that there in line with the shock and not binding it up.
I can't move the shock mts. forward on the a-arm any more, the tire will then be able to rub on them when the tire is turned. This will be my forth attempt to get these shocks mounted.
Here is a crappy drawing of what I mean, I hope it helps. The green line is the axis of rotation of the a-arm ( where it bolts on the frame at).
Old 06-25-2012, 10:31 AM   #39
Restrorob
Restrorob's Avatar
muddstir,
I don't see any issue with tilting/moving the shocks a little, It's not like your building a corner hug'n racing machine. Get them on the best way you can....
Food for thought on the steering, Keep in mind 4-wheelers have wide handle bars for ease in turning those big front tires. Put a small mower or even car steering wheel on there and you may find it un-steerable, That's why I decided to go with modified golf cart steering.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 06-26-2012, 11:20 PM   #40
muddstir
muddstir's Avatar
muddstir,
That's what I was thinking about the shocks myself, so I went ahead and tipped them just enough to clear the motor. I had to cut the mounts off the a-arm, cut them in half, then cut off the the bends for mounting, went to work put new bends on for mounting, rotated them so everything was in line then welded them back on the a-arm.
Its nice to see something getting done, this setup is my 3rd design and after spending all that time building the other designs and them not working any work done seems to be alot.
Now I need to level up the frame at ride height, make the mounts for the top of the shocks and weld them up.
That's a good point you made about the steering, but the bummer is I already ordered new tierods and ends for it. I hope it's not to hard to turn or I know what my first improvement will be.
Old 07-04-2012, 12:58 AM   #41
Narxoleptic Customs
Sexy!! Keep it up man, it's looking great!!
Narxoleptic Customs is offline   Reply With Quote
Old 07-07-2012, 11:53 PM   #42
muddstir
muddstir's Avatar
Thank you!
Old 07-08-2012, 12:29 AM   #43
muddstir
muddstir's Avatar
Here is a pic of the upper front shock mounts. The tubing that the mounts are on is off of the unused rear section of the atv frame that I bought, they had the right bend/ angle that I needed. The mounts themself I bent at work, I put three holes in each one so I can lift or lower it easily. I left the tubing long so I can incorporate a so called rollcage and some how make my steering mount to it.
In the pic you can see that there are no blocks under the front frame, its finally sitting on all four tires (its about time). I still have more bracing to do where the shock mounts mount to the frame but that will be done at a later date.
Name:  Copy of DSCF0367.jpg
Old 07-08-2012, 05:15 AM   #44
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Very Cool build!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 07-08-2012, 08:32 AM   #45
jjzepplin
jjzepplin's Avatar
Sick!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-09-2012, 07:33 AM   #46
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Awesome build. This should inspire the guy I`m working with.
Old 07-09-2012, 10:07 PM   #47
muddstir
muddstir's Avatar
Originally Posted by propanemudtruck View Post
Very Cool build!
Originally Posted by jjzepplin View Post
Sick!
Thanks guys!
Old 07-09-2012, 10:55 PM   #48
muddstir
muddstir's Avatar
The next thing I wanted to do was get the steering shaft mounted so I could get it connected to the front atv stem part. But that's where one thing went to another to another.
I need to get the body in place so I could get the shaft mounted at the right angle/ area. So I sat the body in place and realized that there was going to be alot of trimming on the hood for the shock mounts to clear, no big deal, marked it out and got ready to cut. That's when I remembered about the chain case with the driven pulley on it. It bolts to the side of the frame and goes up about 18 inchs, and that puts it right at the top back corner of the hood where it latches to the console. I would have to cut the hole corner out and build around it, I didn't like that ideal due to losing the hood latch and I'd have to extend the hood out about 4in to cover up the chain case (I thought it would look out of place). After staring at it for alittle bit I decided on "body lifting " it first to see how it looks before I cut it all apart. I needed 5 inchs for the hood to clear the pulley so I made new front hood mounts that lifted it 4 inches then drilled new mounting holes that gave me the other inch.
It looks a little out of placed with the body lift to me- So let me know what you think. If I keep the body lift all gaps will be filled to make it appear stock. The pics are kinda bad but I hope you get the overall look.
This is with the 5 in lift
Name:  Copy of DSCF0377.jpg
This is the size of the chain case
Name:  Copy of DSCF0388.jpg
And this is where it should sit when mounted with the body lift ( will have very little trimming to do if its here.)
Name:  Copy of DSCF0392.jpg
Old 07-21-2012, 08:37 AM   #49
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I love this build, makes me smile every time I see pictures. So cool, keep it up!
fryer1979 is offline   Reply With Quote
Old 07-22-2012, 07:00 PM   #50
stepside83
stepside83's Avatar
this is a pretty cool build looking forward to more of it
stepside83 is offline   Reply With Quote
