Old 02-18-2006, 08:55 PM   #1
KJ72
2wd to 4wd conversion ?
Hello everyone, I am new to your board and am restoring a 72 GMC suburban. I would like to put a later frame under it (73thru 91) Is this possible? What issues would I need to look out for? Any help would be appreciated.
KJ72 is offline   Reply With Quote
Old 02-18-2006, 11:30 PM   #2
Re: 2wd to 4wd conversion ?
Welcome.It`s your forum now.Not sure about the specifics,but the frames are different and will need some alteration.Definately body mount locations,I`m sure you realized already.Get the wheelbase measuirements hub center to hub center and go from there.Your`72 probably has leaf springs in the rear,right?You could use the parts from a 73-91 donor to adapt your`72 frame.
Old 03-06-2006, 02:35 PM   #3
Jr_Blazer_Boy
Using a donor frame shouldnt be the problem. Check with DMV in your state and make sure that you wont have a problem with the title when finished. I know Calif has a problem with more than one vin. Then they issue a new one through the calif CHP office. I hear it can be a real pain in the fanny.
Jr_Blazer_Boy is offline   Reply With Quote
