Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-10-2020, 06:29 PM   #1
65chevysub
65chevysub's Avatar
Dome light connection in fuse panel
My 84 Sierra didnt come with a dome light, so Im installing an LED light on the ceiling, and thinking I need to run a toggle switch, but is there any way of tapping into the wiring to the headlight switch to make the light come on when I turn the knob all the way to the left?. If so, where do I tap in? I added a picture of my fuse panel for reference
65chevysub is offline   Reply With Quote
Old 10-10-2020, 10:39 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Dome light connection in fuse panel
As per the wiring diagram for the 84 GMC the courtesy lights are powered by the tail light fuse, full time hot, by an orange wire to the courtesy and dome lights and the headlight switch for the tail lights.
They are switched by the door switches and the headlight switch on the grounded side by a white wire from each of these switches.
If you want to wire yours like you say, you will have to pull the headlight switch
and locate the terminal which grounds to the switch housing when you turn the knob all the way then run a white (or any color you choose) to the ground side of the LED. If you run a toggle switch to the dome, you can simply run a wire from a ground to the toggle and then run it to the same side as the one from the headlight switch.
Remember that LEDs are polarity sensitive so you run to the positive side with the hot wire and the ground side with the wire from the headlight and toggle switch.
The wires to the courtesy lights are shown on the lower left of the 1st diagram.
Name:  1984 GMC Truck-1.jpg
The second one shows the wiring to the rest of the lights.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-10-2020, 11:10 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
In the second diagram I notice that the fuse panel has a fuse for the horn/dome light. it is full time hot so you could run your dome light off that fuse for the power side.
VetteVet
Old 10-11-2020, 10:39 AM   #4
65chevysub
65chevysub's Avatar
Thanks Vettevet, I appreciate the reply with the wiring diagrams.
