Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-19-2020, 10:52 PM   #1
Greasey Harley
Greasey Harley's Avatar
wiring sealed beam headlights.
I got a pair of headlights for my plow truck recently. Actually, these ones:
https://www.ebay.com/itm/6-Black-Mot...5524%7Ciid%3A1
It's a sealed beam, halogen, motorcycle headlight.
Just wondering, is there any problem with wiring them so High and Low beam are on, simultaneously when they are an high beam?
Too much heat, maybe?
They sure are brighter when high and low are both on.
Any thoughts?
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 10-23-2020, 12:59 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: wiring sealed beam headlights.
Halogen bulbs do get very hot so that might be a problem. Maybe you could add a second light with just a high beam element and wire the four high beams together and retain the low beams.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-23-2020, 05:47 PM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: wiring sealed beam headlights.
I'm completely lost on what you want to do here.
Are you saying you want these lights to work separate from the truck head lights? If so then add a relay and a toggle switch to the dash to turn them on. Make sure you use heavy gauge wire from battery to relay and relay to lights.
Put a inline fuse in the wire from battery to relay close to the battery. The relay should be out by the lights.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-25-2020, 02:26 AM   #4
Greasey Harley
Yeah, separate from the head lights. The plow blocks the headlights when it's in the "up" position, I will use the auxiliary lights instead of the normal headlights.
They are wired up:
One relay to the high beam
One relay to the low beam
Both relays have switched grounds on the control side.
There is no problem with getting enough power to the lights.
I was just wondering if I could wire them up so up both elements (High and Low) were powered when the lights aer on BRIGHT
Low beam= low beam element powered
High beam= High and Low beam element powered
Old 10-25-2020, 10:19 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: wiring sealed beam headlights.
They are wired up:
Ok, yea I got you now. I don't see why not if you just wire both relays together off the same dash switch. The trigger wire has very little amp draw but you may burn your lights out really fast. Having them on with both elements at the same time. This is going to cause a lot of heat and it will be very intense at both elements so I would think it will burn out very quick.
Being on a plow truck may help it some.
if it where me I would be looking at a LED light bar to mount.
