Old 03-30-2009, 07:02 AM   #1
renegade6
TF Air conditioner ideas
Besides all of commercially available systems (Hot Rod air, etc.) what have you all used for A/C? I have a pick a part that is local that has a pretty good selection and if I can make something work that may be cheaper, I'm for it.
I saw in here where someone used a heater/AC from an S-10 on a 1st series...
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 03-30-2009, 10:26 AM   #2
Houston54
Re: TF Air conditioner ideas
I have seen two trucks with OEM HVAC units scabbed onto the firewall. One was a AD series and the other was a Task Force.
Neither looked like an installation I would want on my ride. How they perform may be another matter completely.
How much it will save you should be tempered with what it will cost you upon resale. In my book it would probably be a deduct since I would have to tear it out and replace with an aftermarket set up.
just my opinion.
Houston54 is offline   Reply With Quote
Old 03-30-2009, 01:11 PM   #3
blackdiesel
blackdiesel's Avatar
The OEM air would cool better for sure. The problem is room. It will not fit under the dash, so it would have to be on the firewall. which as stated just don't look right. If money is the main reason, then the 1k for an aftermarket might or might not be worth it. I seen a 57 with a T/A clip, motor, radiator, and A/C heater in it. It was not pretty at all.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-30-2009, 01:37 PM   #4
OrrieG
OrrieG's Avatar
I have a Vintage Air unit that I am going to install. So far it looks like the fit is going to be okm every thing mounts up in the dash. Glove box is reduced to about 2" deep and the unit hangs about 3-4 " below the bottom lip of the dash on the passenger side. It does not affect passenger foot room or stock WS wiper. There is nothing on the firewall side except for the lines and obvious stuff like compressor, evaporator, etc. I don't care for the diffuser grilles that come with the unit and am probably going to make a center console and valence below the dash for nicer ones. I too have seen later unit grafted onto the firewall, they can work but take up a lot of room and you then have to deal with relocating the battery. I think because the newer trucks have wider firewalls you might have conflicts with the engine too. It seems like I have seen units that mount behind the seat for street rods that might work too.
OrrieG is offline   Reply With Quote
Old 03-30-2009, 02:54 PM   #5
weldvair@embarqmail.
Smile Re: TF Air conditioner ideas
Here is an alternative to the expensive street rod a/c units.
http://www.danhard.com/pub/catalog06.pdf
Here is another one. http://www.ackits.com/c/BlackDeath/A...+Death%29.html
Hope this helps.
I used Vintage air because I liked the console controller.
Don Meyer
weldvair@embarqmail. is offline   Reply With Quote
Old 03-30-2009, 07:30 PM   #6
renegade6
Thanks everyone. I will probably just end up saving the money for a Vintage Air or something similar.
Brandon
Old 03-30-2009, 07:33 PM   #7
OrrieG
OrrieG's Avatar
Danhard looks very comprehensive. Thanks for the link.
