Old 01-27-2019, 08:37 PM   #151
Cautrell05
Re: It's my turn, 47 S10 build
So I managed to get a few hours in this weekend. Next on the list was the steering column. I opened up the hole in the firewall and moved the bottom of the column up a little over an inch and about 2 inches to the left. Originally I figured I would have to run 3 u-joints to clear the exhaust but I managed to make it work with just two. Couple things worked out in my favor. I had some left over steering shaft pieces that I used to extend the bottom of the column 2 1/2". That combined with moving the column to the left gave me just enough room to clear the exhaust. The other thing that worked out really nice was that the Ford ranger lower steering shaft fits over the standard double d shaft. I cut up the steering shaft that came with the van column and used the upper u-joint. That fit over the piece I used to extend the column and the cut end fits inside the lower steering shaft. If I ran different exhaust I could have had a bolt in steering shaft with no welding but I like these manifolds.
Fast, Cheap, Reliable. You may pick two
My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723
Cautrell05 is offline   Reply With Quote
Old 01-27-2019, 08:41 PM   #152
Cautrell05
Top of the column was pretty straight forward. Centered between the gauges, all the way up and as far forward as I can and clear the shifter. Now that I have the general location hammered out I'll start making mounts to hang out from the dash. I can't count how many times I have been in and out, sitting behind the wheel making sure everything feels right.
Legroom feels pretty good. Maybe a little less than my Yukon but not cramped. The current pickup seats I'm using are fairly this in the back compared to the original seat. That helps a bit with the legroom.
Old 01-27-2019, 08:58 PM   #153
Cautrell05
Better picture of the GM to Ford adapter joint.
Old 01-27-2019, 09:14 PM   #154
Cautrell05
It's hard to see in the pictures but the factory shift linkage is going to clear the clutch linkage and the chassis braces I added. Straight shot from the column down to the frame. That's another advantage of the van column. The shift linkage runs down the outside of the column away from the engine instead of on the inside like most do. That would have run the linkage right through where the pedals move to.
Even though nothing is bolted or welded yet, there's something about turning the steering wheel and watching the front wheels move for the first time that really feels like progress. I've still got a long way to go but at least I'm making progress.
Nick
Old 01-28-2019, 01:06 AM   #155
joedoh
joedoh's Avatar
thats the important thing, to get in and out as many times as it takes haha
New Project! Project: KECHI
my L35 4.3 4L60E S10 49 chevrolet 3100
http://67-72chevytrucks.com/vboard/s...d.php?t=782525
Old 03-12-2019, 01:47 PM   #156
Cautrell05
I got the steering column temporarily mounted over the weekend.I don't know about you guys but anytime I come up with leftover brackets I have a hard time throwing them away. I have a drill press, cop saw and a welder but sometimes it's faster and easier to take an existing bracket cut an ear off and use that. It lucky and had two matching brackets already been and drilled that I think should work. The 89 Chevy van column I'm using has 4 threaded posts welded to the column already. The right one bolted up to the upper hole and matched the curve of the dash perfectly. The left one was close and just needed a little tweak. I don't have a good vice at home and making precise bends in 3/16"x1 1/2 strap isn't easy so I just used my cut off wheel and cut about half way through on the back side where I wanted my bend and then folded it. it'll get welded up later once I'm positive that's where I want everything. for right now the upper mounts are only using two of the bolts. when I get ready to finalize the mounds I'll add in years so that it's attached to both bolts on each side. The firewall will probably just a standard flange mount with a band clamp to hold it in place.
Old 03-12-2019, 01:50 PM   #157
Cautrell05
I also got the pedals halfway stuck in place so I can get an idea how that's going to work out. Right now everything is looking like if I notch that tube then it's sitting on and sink that sleeve about half or two-thirds of the way through it it'll end up being exactly where I need to be and just clear the exhaust manifold by about a half an inch while still traveling in the proper ark so it doesn't drag on the floor. I don't remember exactly how high the pedal set originally when I first got the truck. But it seems like if I pull the brake pedal far enough to be contacting the switch it sticks way through the floor to the point that it's almost uncomfortable to get my foot on it. I can play with the pedal ratio when I run the linkage from the pedal down to my brake booster. but it seems like about two-thirds of the way up is where it would feel natural. I'm going to wait to mount the pedals though until later this spring when it's warm out and I can roll it outside and pull the front clip off of it. Even with the motor in it, with the outer and inner fenders removed there area for the pedals will be wide-open where right now is just kind of a pain to get to. It is nice that so far everything seems to be coming together right as I had planned. I'm sure at some point that will stop being the case but for now I'm happy.
Nick
Old 03-12-2019, 03:14 PM   #158
dsraven
I think the old pedal lever had a rubber bumper on the engine side of the firewall so it would contact the firewall at the top of the pedal return stroke and set the pedal height that way. not totally sure on your truck.
Old 03-12-2019, 09:35 PM   #159
joedoh
joedoh's Avatar
man I have buckets of brackets too haha
nice work!
Old 03-22-2019, 09:46 PM   #160
Cautrell05
There's still one on the clutch pedal but if I pull the brake pedal up that high it makes it awkwardly high.
Old 03-22-2019, 09:59 PM   #161
Cautrell05
nice work!
I can't count all the times one of those left over brackets saved me a bunch of time.
Nick
Old 03-22-2019, 10:40 PM   #162
Cautrell05
So I had a couple free days and made some more progress. The pedals will wait until I have the front end off. and that's going to wait until things warm up and I can move the truck outside where I have more room. Figured it'd be a good weekend to change rear ends. The little 7 and 1/2 inch would probably get by with some wheel spacers. But I can't help but think the first time I get traction that 400 is going to make short work of it. I picked up a 77 Lincoln nine inch a while back for a hundred and fifty bucks. Complete rotor to rotor. rather than mess with it at home I loaded it up and took it into work. I was in a hurry that day and for some reason did not get a single picture while I was there but it's not a big deal. It was nice having all my tools there got it all tour down to a bare housing and all the leftover brackets cut off of it. The original Lincoln calipers have the parking brake built into them it looks like it would be easy enough to adapt. The rotors are I think 11 and 1/2 in. These are obviously toast but new ones are priced pretty reasonable. It's a lot easier to go with an existing system than trying to adapt something. As expected it had a 3.00 rear end gear. With short tires in a light vehicle that's probably not too bad. I have another third member sitting out in the shed that's got 350 years in it. The nice part with these is it does not take that long to change gears on a 9 inch if I want to try something later. Nice surprise was that it had a factory posi in it. Clutch kits for them I believe for under a hundred bucks. I can live with that.
With the rear end tore down inspected most of the way cleaned up and put back together The next step was pull the old one out of the truck. the leaf spring bolts all came out very nicely without any headache. I kind of wish the u-bolts would have twisted off. It would have made it a quicker process.
Old 03-22-2019, 10:42 PM   #163
Cautrell05
A while back when I was at the U-Pull-It yard there is an extreme S10 up on stands that somebody had already pull the rear axle out of. The leaf springs and rear sway bar we're just hanging there. For around 60 bucks I had a pair of factory lowering springs and 1 inch rear sway bar. I put the rear springs in and then roll the rear end under it. I did not have any leaf spring pads laying around, and I had zero patience to make a temporary set so for now it has two pieces of pinewood and some repurposed 3/8 u bolts that came with an old air bag kit. It won't be seeing any power with the current setup. I still have not decided if I want to go simple with a lowering block, or float the rear end housing and use a torque arm. A lot of that will be determined by how low it sets and how much room I have. I have sway bar links ordered for the back. Once they show up then I can get the mounts made. The front will be really easy, I have a brand new set of GM mounts that normally would go over the 7 and 1/2 in axle tubes. But on this one they line up with the center section. a little reshaping and welding and they'll be just fine. Because it moves the sway bar back about an inch and a half it doesn't quite line up where it would on the shock mount with the factory style but I've got an idea for something that should be easy enough to Fab up.
Old 03-22-2019, 11:55 PM   #164
joedoh
joedoh's Avatar
nice scores! that lincoln rear is a serious hoss.
someone told me that zq8 springs (on the extreme) were z85 high rider 3 leaf (not counting the flat overload) springs with the smallest leaf removed.
Old 03-23-2019, 12:49 PM   #165
Cautrell05
Side by side I expected more difference between the stock spring and the lowered one. On the truck though it feels a lot softer than the old one. Both were 2 leaf plus the overload.
Old 03-23-2019, 02:31 PM   #166
joedoh
joedoh's Avatar
have someone substantial sit on it, it will droop more. once you get some weight on it it will be fine. the zq8s got a hop shock to keep the softer springs from wrapping too badly.
there are three 2wd leaf packs, the regular 2 leaf +overload, the highrider z85 3 leaf + overload (1" higher ride than the regular), and the zq8 lowered (1" lower than the regular). I have been told that the zq8 is a z85 with the smallest spring out. my truck has brand new z85 springs on it so I am going to pull the middle leaf and the overload and see what happens. the western chassis drop leafs are two leafs with no overload.
Old 03-23-2019, 03:28 PM   #167
Cautrell05
I have already decided that it's going to get other a single pull bar on top of the axle or a torque arm to keep wheel hop in check.
Old 07-18-2019, 01:39 PM   #168
Cautrell05
Small update, been busy with usual life stuff and combined with the fact is really hot outside right now and my garage is not air-conditioned.the rear sway bar is officially done other than finish welding the mounts on the axle housing. I'll do that later when I have it out to weld the spring perches on.
The 91 S10 never came with the rear sway bar that I am aware of. The sway bar I used came off the rear of a two-wheel drive 2nd gen extreme S10.I have seen kits that you could buy that had the upper mounts but after mocking everything up in place I just made them myself out of some inch and a half by 3/16 angle iron. Cut them, round the corners and drill a hole. Simple enough. There's a nice flat spot on the back of the factory shock mount that they welded to. For the sway bar links I used a pair of rear sway bar links for a 2000 through 2006 suburban just because I had them already.
The axle mounts took a little bit more work, but it was really not that hard. The stock S10 sway bar mount attaches to the axle with a u bolt and a saddle. my cost on those saddles brand new through the dealership was about five bucks a piece so for that price I wasn't going to mess with Rusty ones. A little bit of time spent with the angle grinder and a flap wheel to readjust the radius for the Ford rear end and from there it was just tack it together and bolt it up.
Next on the project list is to pull the front end off again so I have access to get my pedals mounted and get my steering shaft hooked up. from there it's on to transmission linkage, get the master cylinder mounted, the fun stuff that I can actually see progress and feel like I'm getting something done.
Nick
Old 07-18-2019, 01:40 PM   #169
Cautrell05
Couple more pictures.
Old 07-18-2019, 10:24 PM   #170
99 to Life
99 to Life's Avatar
nice job
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-18-2019, 11:36 PM   #171
oldman3
oldman3's Avatar
Looks great, nice work...Jim
oldman3 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
