11-21-2018, 01:42 PM | #1 |
4x4 frames...k10 vs k20
Ok, before people starting posting.."SEARCH", I have, nothing definitive has been posted, no actual information.
So my question is, for those who have a STANDARD CAB LONGBED K20 4wd, can anyone measure the thickness of the frame rails for me. I have a K10 LWB frame, I have gone on GM Heritage and read the info there, but then I have seen postings of frame thicknesses before and none of that info matches. I am wanting to build a K20 out of it, but I want REAL LIFE measurements to match my frame to. Thank you.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
11-21-2018, 02:19 PM | #2 |
Re: 4x4 frames...k10 vs k20
All I have is an 84 K30 Camper Special, the rest are K10s.
I know the frame is taller on that 30 but I will measure thickness for you if you think it will help you. |
11-21-2018, 02:32 PM | #3 |
1977 Heritage Center shows K10 LWB and K20 LWB both have 3.92 frame modulus, so the frames are the same.
As far as actual measurements, you would need a clean unrusted unpainted frame and then measure each individual section shape. i can tell you here in Michigan 100% thinning is common. Like, missing from salt corrosion LOL.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
11-21-2018, 10:31 PM | #4 |
I've been wondering for some time what the "Heavy Duty Frame" on my 85 K20 means. That's what it says on the SPID. Was there a "regular or light" duty frame?
11-21-2018, 11:27 PM | #5 |
I have an 83 K20 and just forward of the rear cross brace, the frame measures 4 3/4" tall, 3 1/4" wide, and 3/16" thick. Best I can do with a tape measure in the dark. If you need something else or more precise measurements, let me know.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
11-22-2018, 01:27 AM | #6 |
Awesome, THANK YOU to all of you.
11-26-2018, 07:24 AM | #7 |
Yes, there is a 'heavy' duty 3/4 ton frame available. Weight was taken out of the frames in the 1981 redesign, but there was still an need for a stronger frame for certain applications. Usually goes along with HD suspension, most common on the military pickups and firefighting units that we always heavily loaded.
11-26-2018, 01:10 PM | #8 | |
military pickups were k30 1tons . totaly different frame size . and most fire truck ambulances were build on these frames also . i have seen some k20 fire trucks but not a lot . 2 easy ways to spot a k30 only frame is the middle section of the frame like under the cab is 8.25" tall almost 2" more than 1/2 and 3/4 ton frames . and in the rear 1ton frames had inboard shocks on a set of 4 bolt riveted in frame ear studs . this was cause the outboard shock design of 1/2 and 3/4 ton would not clear the leaf springs being sucked in 1" each side to make room for the narrow c&c axle option if it was to be a drw c&c truck .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-26-2018, 01:30 PM | #9 |
I found my rpo code (C6P) actually states HD Chassis so it may have nothing to do with the frame, rather the springs? Swapping in the 14ff & Dana 60 probably only lowered my payload capacity. Lol. Of course I probably gained it back when I swapped to the Vintage Air system and lost 300 lbs of useless wires, vacuum hoses, cables and connectors.
11-26-2018, 09:57 PM | #10 | |
11-27-2018, 09:49 AM | #11 | |
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
11-28-2018, 11:52 PM | #12 |
If someone that has a K20 would actually measure thickness with calipers or micrometer, I can do the same for the K10, and someone with a K20 CAMPER SPECIAL could do the same thing, we can FINALLY put this to rest. I will take measurement in 3 locations, right in front of engine crossmember, under cab and around area of tow hitch. I will clean these spots well and post my findings.
12-01-2018, 12:06 AM | #13 |
I mic'd my K20 in three spots and they ranged from .225 to .255.
