Old 03-14-2018, 10:55 AM   #1
paul blair
1970 4x4 blazer fuel tank ?
Looking for a direct replacement 21 gal fuel tank for a 1970 4x4 Blazer. Seems the tanks I found need the filler neck modified. The original filler neck comes out of the tank horizontal, all the ones I see offered angle up. Any one here know where to buy a tank that does not need to be modified?
paul blair is offline   Reply With Quote
Old 03-14-2018, 11:51 AM   #2
1rippen6
Re: 1970 4x4 blazer fuel tank ?
I don't think they offer a direct replacement best thing to do is remove you filler neck before scrapping the tank.
1rippen6 is offline   Reply With Quote
Old 03-14-2018, 12:25 PM   #3
paul blair
Thanks for your input...form what information I have found some say weld the original filler neck to the new tank!? Body mount in the way!
Old 03-14-2018, 12:49 PM   #4
A1971Blazer
A1971Blazer's Avatar
The filler neck has 2 nuts and is soldered on to the tank...you can melt it off if you have a torch set-up or take it to a radiator shop...you can also get some pre-formed hoses and work it that way. That's what I did on mine.
I cut about an inch off the neck.....got some pre-formed 45 fuel filler hosed and a coupler....I made it come out in the correct place to connect to the filler tube on the body....
2 of these https://www.fillernecksupply.com/1-3...ler-neck-hose/ and a stainless coupling...
you have to route them around in front of the body mount to be in the correct location
here's where it need to come out across the frame.
original tank with neck still on it
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-14-2018, 02:16 PM   #5
paul blair
Thanks A1971Blazer for the information and the photo! I haven't removed the tank yet so your photo is a big help! Best place to buy a new tank With sender and straps???
Old 03-14-2018, 02:41 PM   #6
A1971Blazer
Most all the vendors have a similar tank...I try to use vendors that are here on the board...GMCPauls is a good place for parts.
Since you still have your tank...I would suggest just having the filler neck moved to the new one...that's the best way....
Old 03-14-2018, 03:38 PM   #7
paul blair
I just checked out GMCPAULS----Thanks again and I see a POLY TANK MADE IN THE U.S.A.---SOME THING YOU DON'T SEE MUCH---don't know about the POLY but some thing to consider...
Old 03-14-2018, 07:48 PM   #8
lks dcvn
lks dcvn's Avatar
I went with a Boyd Welding Tank on my 71 project and will do the same with my 72 2wd blazer - you can pick the Blazer option so the neck is correct, be ready for EFI upgrades, rollover protection from leaking and it is made out of Aluminum.
http://www.boydwelding.com/
lks dcvn is offline   Reply With Quote
Old 03-14-2018, 08:06 PM   #9
jaros44sr
jaros44sr's Avatar
If it were me, I wouldn't melt it off with a torch, I would probably feel the shock wave in Philadelphia, better to cut neck off with a hammer and chisel, then use tin snips once the hole has been started
There was a thread on here a long time ago about a guy trying to resolder his float bowl, it didn't go well, but was very funny, since he didn't get hurt
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
Jim
jaros44sr is offline   Reply With Quote
Old 03-15-2018, 01:05 PM   #10
paul blair
Any thoughts on POLY TANKS?
Old 03-15-2018, 01:47 PM   #11
A1971Blazer
A poly tank would be fine...but you will have to use a fill hose method like I described....one thing you wouldn't have to worry about...rust...
If you go with metal....any competent radiator shop can melt the old neck off and back on with no problem...I would think that most people would have enough sense not
to apply flame near a tank that had gas or residual gas fumes still in it....but....you never know...
Old 03-15-2018, 02:05 PM   #12
paul blair
I appreciate your input...leaning towards the POLY TANK because it is advertised as MAD IN THE USA and no rust...mostly beach riding here...right now I wish I was in your state!
Old 03-15-2018, 05:18 PM   #13
SeventyOne
FWIW i bought a poly and ended up selling it and restoring my original tank. Didnt care for the way it fit between the frame rails and the way the straps ran under it.
SeventyOne is offline   Reply With Quote
Old 03-15-2018, 05:31 PM   #14
paul blair
Where did you get the POLY TANK from? Did it fit to tight or loose--how different from the original tank? Thanks for the information!
Old 03-15-2018, 07:10 PM   #15
SeventyOne
All the poly tanks are the same. I bought it from some weird site that had the cheapest price shipped to my door.
I installed the poly tank reusing my stock straps because everyone hates the new straps.
I recall the lips/flange on the tank that seats against the frame rail were too narrow, and it did not have the locating tab that the stock tank did. In general it just didn't feel as secure as I wanted a 20 gallon tank of gas to be
After taking my stock tank to a shop to restore the install was clean tight and the way it should be.
Old 03-15-2018, 07:47 PM   #16
paul blair
Thanks for the info...Happy Trails
Old 03-15-2018, 07:56 PM   #17
jaros44sr
jaros44sr's Avatar
But, ya never know. This was not meant as a knock towards you, please don't take that way.
SAFETY FIRST
Jim
Old 03-22-2018, 11:36 AM   #18
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I did the same thing... Filler is a direct shot from where it drops down from the side... No curve required...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2015 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 03-22-2018, 11:48 AM   #19
A1971Blazer
Not taken that way at all....and we agree..."ya never know".....
When I melted the old one off my tank it had been sitting empty for a number of years...and it was all rusted out inside as well...
Old 03-23-2018, 01:58 PM   #20
ochre1971
ochre1971's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=536746
ochre1971 is offline   Reply With Quote
Old 03-23-2018, 05:33 PM   #21
jaros44sr
jaros44sr's Avatar
Thanks for finding it....I gotta reread it
SAFETY FIRST
Jim
Copyright ©2000 - 2018, vBulletin Solutions Inc.
