Old 05-13-2017, 10:50 AM   #1
kennyhammond
Little motor rebuild question 350 or 383
Well I am buying a 90-98 k1500 4x4. And want to run 33 or 35. I will rebuild the motor and have been looking at options for the intake and top end .. what is a good way to go...carb or Holley or something ..it is a daily driver that is going to go about 15 ,isles round trip to work. More of a toy.. plan on the bottom end to be 9.5 to 10 ...and either vortex heads or the torquer 2s. Nothing crazy on cam .... i am simply researching and wanting to keep it cheap and simple ...main focus is it to start every time and not have to pump the carb to start
kennyhammond is offline   Reply With Quote
Old 05-13-2017, 12:46 PM   #2
kwmech
Re: Little motor rebuild question 350 or 383
A 4x with 35s I'd look at a 383 engine. Why not keep the Fuel Injection?
Old 05-13-2017, 01:49 PM   #3
kennyhammond
Yeah 383 is nice. Fuel injection is awesome just think it would be limited on supply with the extra fuel needed. I keep reading its a pig TBI ..tire size doesn't scare me I can get the years changed and go lower to help on that side. Just want some good reliable torque to be strong in the low end
Old 05-13-2017, 11:31 PM   #4
Captainfab
60-66 Nut
If you buy a '96-'99 truck, you will have a Vortec 350 to start with. While the Vortec injection is not the best it is a good bit better than TBI. If you're wanting an engine that starts every time without having to pump the gas, you should consider staying with the EFI. While building a 383 would be the smart thing with 33-35" tires, a 350 can be built to perform decently. This also depends on your budget. A budget upgrade to a Vortec 350 would be the Ram Jet 350/HT383 cam (14097395) and a set of 1.6 roller rockers
Old 05-14-2017, 08:37 AM   #5
kennyhammond
I was just looking at a small build a guy did with a Holley efi upgraded the vortex heads to use a higher lift can and used a small rv cam and made good numbers
Copyright ©2000 - 2018, vBulletin Solutions Inc.
