Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-24-2017, 02:00 PM   #1
mike1954
Sealer
The last time I did any auto painting was 25 years ago. I used Martin Senour products a the time. I shot a couple of clear coat/base coat trucks and a couple a acrylic enamel tucks(not my favorite).
I use a non sanding primer prior to the paint. Every time I ask about a non sanding primer a get a strange look. I know paint products have advanced a lot in 25 years,
I sure did like the non sanding primer I used to use you shoot it straight out of the can but I have no idea the name of it.
Any advise on non sanding primers would be appreciated.
Mike
mike1954 is offline   Reply With Quote
Old 03-24-2017, 08:43 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Sealer
Mike, I was a Martin Senour paint rep in the late 90's I don't remember a "non sanding primer" there were sealers but not a primer that I can remember.
The best today would be an epoxy primer, thin it to be a sealer. This would be of course following manufacturers guidelines! Check out what SPI has,m they mail to your house free. http://www.southernpolyurethanes.com/
But you do NOT want to use a single can product, you want a "2k" something with a hardener that "cures" instead of "dries."
Epoxy is the way to go.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-24-2017, 10:48 PM   #3
mike1954
Re: Sealer
You are probably correct it was a sealer shot directly from the can. Any way I appreciate the help.
Mike
Old 04-20-2017, 11:11 PM   #4
Marty68
Marty68's Avatar
Re: Sealer
i sprayed a lot of single component sealers in the 80s, was sprayed right out of the can to give uniform color, could have minor bare metal cut throughs, non sanding. never a SW sealer. we used dupont sealer Centari AE SW base clear. Martin Sr. is correct. there are 2 components sealers spi has one in several colors 4:2:1 use just as you remember or 4:2, use as filling primer. or best yet an epoxy mixed as sealer gives great adhesion and a stable substrate.
what I want in life... "click click VROOM".... stolen from someone here
Marty68 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
