Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-26-2017, 03:57 PM   #1
Lower
Lower's Avatar
What order would you paint an entire truck
I have my k10 strung all over the shop, got the few larger dents fixed and getting ready to start putting epoxy on it.
Would you go ahead and get the interior of the truck painted before starting the block sanding on the exterior?
I really don't want to "block" sand the dash and roof, what steps would you suggest for this.
Thanks for any and all help!
~Jon
Ol Green 1970 K10ish LWB,355/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 04-26-2017, 09:34 PM   #2
hugger6933
Re: What order would you paint an entire truck
Lots of hand sanding there use a 220 grit paper then a 400 grit paper and maybe after that a red scotchbrite pad.
I would paint the inside of the cab after putting the cab in high build primer. That way as you are sanding the outside the overspray will be removed.
Be careful when sanding on the inside[outside for that matter too] with your fingers on the paper you can leave " fingerwaves" in the surface pretty easily and every time you see those three grooves in the paint you will feel a little queasy in the pit of your stomach.
hugger6933 is offline   Reply With Quote
Old 04-29-2017, 08:31 PM   #3
Tiger Joe
I never lay any paint until all bodywork is done.
Doing my dads 79 now. We have everything finish sanded ready for a final once over before paint. Then I sprayed the cab inside.
Tiger Joe is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
