Old 05-08-2017, 11:55 PM   #1
72timemachine
Gear Vendor holding shift point too long?
I have a GV in my 84 dually diesel, 6.2, 400th and it works great all shift points seem within reason of it's given rpm.
I found what appears to be a Laycock GV in a boneyard. Seems GV bought out Laycock from what I have read. This one I found was in an 88 c1500 with a 5.7, 400th. I have a 90 GMC, 5.7, 400th. I installed it and had the drive shaft shortened and balanced. I am using the synthetic oil in the GV so I do not have to change it as often as the conventional oil...per the GV tech on the phone.
Problem seems that when I start out in 1st, I need to get the truck up to 35 mph...at this point the engine is at a high rpm (sorry no tack) but I can tell, trust me. When it finally shifts into 2nd, it just about puts my head through the rear glass...clearly this is kinda cool on one hand but not as a daily driver.
It will then seem to shift at an appropriate rpm into 3rd (about 45 mp) and then on the freeway, it becomes a rocket ship with the engine at a very low rpm while I can cruise easily at 75....but do not.
Anyone know what the deal is? I did try to switch the other control box out of my dually but is sorta behaved much in the same way. I even swapped out the electronic solenoid but made no difference. I did this because I read that the gear oil can pass by the o rings on the solenoid shaft and cause shifting problems. My filter screen is also clean as I dropped the small pan to clean it out before adding new oil.
Any help would be great so thank you ahead of time.
72timemachine is offline   Reply With Quote
Old 05-09-2017, 10:50 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Gear Vendor holding shift point too long?
When I had my M1010 with the same 6.2L diesel and T400 trans (no gear vendor) I had this same problem. Ended up being a bad vacuum modulator on the trans and broken vacuum line. Once I replaced those items, it shifted great. Without these working, the T400 trans will use the mechanical governor to shift, which is at high RPM.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-14-2017, 10:22 AM   #3
DieselSJ
Yeah, that does not sound like an issue with the overdrive...that is something in the trans itself. Vac modulator and lines are a good place to start.
87 R30 CC Dually, 454, TH400
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
