01-13-2019, 06:01 PM | #26 |
Re: 68 long bed Chevy
Got some more work done. After getting the frame cleaned up I painted it with Eastwood Rust encapsulater then topped that with Eastwood chassis black satin. Next step was to install the c notch. I cut out for the notch as well as welded in some 4” pipe in the trailing arm crossmember for the exhaust to run through. I am doing air ride but I don’t want to cut the bed so I decided to go with Deadend Garage stuff. Very good quality and great communication to answer any questions I have. Next step will be getting the rearend refreshed and back under the frame.
1968 C10 2WD LONG BED |
01-13-2019, 06:25 PM | #27 |
Frame looks good! I like the exhaust passages a lot. That might be something I have to do at some point. I hate how my exhaust runs under below the frame
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-23-2019, 06:58 AM | #28 |
Installed a Yukon Duragrip and new 5 lug moser axles along with all new bearings and seals. After that installed Deadens garage panhard kit and rear shock relocators.
02-23-2019, 01:12 PM | #29 |
