Old 01-22-2017, 04:42 PM   #1
69-72
69-72's Avatar
1970 Vin Plate location
Could someone take some measurements of where the holes for the vin plate on a 1970 pickup should be? �� I just need the position down from the latch indentation.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 01-22-2017, 05:23 PM   #2
Re: 1970 Vin Plate location
I get 9 3/4" from center of outer lower latch bolt hole to center of outer upper VIN-plate rivet
Old 01-22-2017, 05:42 PM   #3
69-72
69-72's Avatar
Thanks, is that a 71 or 72 you measured? The vin plate for a 70 is higher up than a 71 or 72
Old 01-22-2017, 07:08 PM   #4
Yes, I did measure my '72. I never thought about that. I guess the jamb vent makes 71-
/72s lower. I just checked a cab I have but it looks like it's a '69. Sorry for giving bad info.
Old 01-22-2017, 07:29 PM   #5
BugzC10
BugzC10's Avatar
I measured 1-7/16" from the edge of the latch indentation down to the center of the left rivet
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-22-2017, 08:41 PM   #6
69-72
69-72's Avatar
Awesome! Thanks
Old 01-23-2017, 09:33 PM   #7
James Pierce
If you take the vin plate off for paint where do you find those funny rivets to
replace it?
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4WD 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
71 GMC Supr 350 Auto
70 C10 350 Auto
67 CST 327 Auto
James Pierce is offline   Reply With Quote
Old 01-23-2017, 09:43 PM   #8
69-72
69-72's Avatar
replace it?
It's illegal to remove thE Body tAg Yourself
And they are commonly referred to as rosette rivets.
Old 01-24-2017, 12:24 AM   #9
El Dorado Jim
replace it?
google "rosette rivets" and you can buy them, a little pricey...
El Dorado Jim is offline   Reply With Quote
Old 11-14-2017, 09:54 PM   #10
70K GMC
70K GMC's Avatar
Where are the VIN locations? I tried to register my vehicle today at DMV and was told I needed to have 2 VIN locations. I could only find the VIN plate on the door...
1970 GMC Jimmy
LT1 w/Holly EFI
Willwood Hydroboost
70K GMC is offline   Reply With Quote
Old 11-14-2017, 10:45 PM   #11
jocko
jocko's Avatar
There are 2 full VINs: metal tag and SPID in the glovebox. There is a partial VIN on the frame rail topside in the vicinity of the steering box.
EDIT: Would use the partial frame VIN only if the SPID didn't exist or the gb door had been changed. Also - actually check the frame VIN first if you're gonna let them see it - might be embarrassing if you learned you had a cab or frame swap in front of the little ol DMV lady.
