Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-07-2018, 12:38 PM   #1
OregonNed
OregonNed's Avatar
Question What would be the best way to wire-up reverse lights?
My truck is a '68 C/10, that was originally a four speed. It was converted to an auto transmission before I got it. Recently I upgraded the floor shift to a Lokar, and wired and connected the neutral safety switch - (It didn't have one when I got it). I know Lokar didn't suggest using the neutral safety switch, but I wasn't sure how the reverse lights were originally connected to the SM-465. Now of course I have a TH350. Thank you, Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-07-2018, 02:55 PM   #2
Hotcorner
Hotcorner's Avatar
Re: What would be the best way to wire-up reverse lights?
Interested. My SM465 equipped truck doesn’t have working backup lights.
Hotcorner is offline   Reply With Quote
Old 08-07-2018, 07:18 PM   #3
Grumpy old man
Grumpy old man's Avatar
bottom of page 14 Use the switch on top of the shifter for Neutral safety and this switch mounted off the pan for reverse lights.
http://lokar.com/catalog/#page=15
part # BL-1400U
Grumpy old man is offline   Reply With Quote
Old 08-07-2018, 08:09 PM   #4
OregonNed
OregonNed's Avatar
I saw that and need to call them to ask if it will work. I’ve already got a bracket
And apparatus for the cable shifter and not sure if both will mount and work together. This is a floor shift cable shifter I have. Thanks will check.
Old 08-07-2018, 09:11 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: What would be the best way to wire-up reverse lights?
To come on in reverse hopefully!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
