05-07-2016, 07:15 PM | #301 |
Re: 67 long box
Well it looks like the two ball has a representation of the trucks second life, I'm good with that. My buddies asked if that's what it stood for and I said it was the blue colored ball.
05-09-2016, 05:06 PM | #302 |
Re: 67 long box
Composite decking cut to length and set in. I'm digging that look of wood color that's aged in the sun. Waiting on 1 1/2 stainless strips to go between.
05-09-2016, 05:27 PM | #303 |
Re: 67 long box
Also got the tires changed over and put on. 235/75 15 on 6 1/2" van wheels and 255/70 15 on 7" truck wheels. I like a softer ride. I still would like wider rear tires but that will come after I'm driving it.
05-09-2016, 09:17 PM | #304 |
Re: 67 long box
Things are falling into place now. All that prep work is paying off. Looks brand new.
05-09-2016, 09:36 PM | #305 |
Re: 67 long box
looks killer.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
05-10-2016, 02:26 PM | #306 |
Re: 67 long box
subd
18 year old girl who loves old trucks •Previous Projects• 1971 c10 longbed 350/350 1977 Silverado longbed 350/350 1978 K10 shortbed 350/t400 lifted 6 inches on 33s "LONGBED LIVES MATTER" |
05-10-2016, 02:54 PM | #307 |
Re: 67 long box
wow man i have to say i really admire your work. i know what it takes to do all that work and it is super rewarding in the end.
instagram - @custom.chevy |
05-10-2016, 04:22 PM | #308 | |
Re: 67 long box
05-10-2016, 08:41 PM | #309 |
Re: 67 long box
Nice! Gotta ask, did you have prior painting experience before your blend work?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-10-2016, 09:29 PM | #310 |
Re: 67 long box
I do have painting experience and have painted many cars, boats, trucks, lawn mowers. I have never tried this type of blend before and now I have that checked off. The only way I no how to do this stuff is by doing it. Try everything and anything. I have done every bit of this build myself excluding some sand blasting on the frame.
05-10-2016, 10:45 PM | #311 |
Re: 67 long box
that's nice work
05-11-2016, 10:25 PM | #312 |
Re: 67 long box
Door seals and doors on, still have to touch up the door bottoms where I did some patching. Now to finish fit the fenders and cowl. The rest is bolt on.
05-12-2016, 10:36 PM | #313 |
Re: 67 long box
Got most of the front end on and lined up. That reconditioned grill emblem looks great on there.
05-14-2016, 02:09 AM | #314 |
Re: 67 long box
front bumper on and cleaned up the floor mat, gave it a coat of vinyl paint to make it look new with the sill plates. Daily progress gets it closer to driving.
05-16-2016, 02:32 PM | #315 |
Re: 67 long box
Looking at doing a sunken spare in the bed so I have it mounted but still able to put a tonneau cover over the bed.
05-16-2016, 08:11 PM | #316 | |
Re: 67 long box
Good to see you've found your lighter , I looked & didn't have - Bob |
05-16-2016, 11:23 PM | #317 |
Re: 67 long box
I have also been contemplating this sometime down the road.
05-17-2016, 08:54 PM | #318 |
Re: 67 long box
Made a set of shock relocate brackets, I can't pay for something I could and can make. Finishing my lowering blocks and then get shocks.
05-18-2016, 02:59 PM | #319 |
Re: 67 long box
2 inch lowering blocks fabed up with the same ends as my trail arms. I can see it if I crawl under the truck, But I know it's looks cool. I didn't put tubes through the holes so I welded in a piece of flat bar inside the middle parallel to the holes. This should stop any crushing of the 2x2 HSS.
05-24-2016, 10:12 PM | #320 |
Re: 67 long box
Picked up all the spacer bars for the bed. 1 1/2 x 3/16 flat bar. Little bit of added weight in the rear. Drilled 132 holes in them today. Still to redrill all the cross members to match. Made the drill press into an auto feed with a bungee cord and duct tape.
05-25-2016, 10:49 AM | #321 |
Re: 67 long box
If you don't mind can you pass along what product you used to repair the dash pad?
Great build I especially love the fuel filler set up. |
05-25-2016, 12:18 PM | #322 | |
Re: 67 long box
Derek |
05-26-2016, 01:01 PM | #323 |
Re: 67 long box
Finished up the rear end mounts and the shocks are ordered. Put in the two inch drop blocks in and it looks ok, But then again it's a driver and no one can see them. Still drilling holes, only 150 or so to go for the bed install.
05-27-2016, 03:10 PM | #324 |
Re: 67 long box
rear end suspension, done, front suspension, done, The drivetrain is done.
05-28-2016, 09:22 PM | #325 |
Re: 67 long box
Re-drilled the cross supports to match the new pattern. Welding nuts in them to use Allen cap screws from the top. I keep adding work but this will look neat I think.
