07-28-2018, 09:55 PM | #1 |
External trans cooler
Question for the guys that have a trans cooler in front of radiator, how did you route/run the lines thru the core support? My 76 does not have any existing holes that would work.
07-28-2018, 10:21 PM | #2 |
Re: External trans cooler
If you don't have a/c,there may be some holes already there in the boxed area next to the radiator on the pass side.
That's where I ran mine on my 82,C-30. Or,possibly in the frame rail underneath the front of the radiator support,then up to the cooler. Mike. |
07-30-2018, 10:19 AM | #3 |
This is how mine is done. My dually had a factory oil cooler plumbed this way so when I rebuilt the motor, I swapped in a new unit & also added another/duplicate set-up for the transmission.
07-30-2018, 11:36 AM | #4 |
Here is how I did my '87.
http://67-72chevytrucks.com/vboard/s...d.php?t=733459 Through the external cooler first, then through the radiator. Hot always fed into bottom with return at top.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
07-30-2018, 02:49 PM | #5 |
Proud Vet that loves the USA
Like SCOTI said, I ran mine under the core support and up to the cooler.
Bubba |
