06-11-2017, 10:10 AM | #1 |
Major Loss of low end power after Pertronix install
I swapped out my points for a pertonix module on my 69 with a 350 and now I have a major loss of low end power, to the point of hoping I can get enough speed to cross a street with out getting hit.
I did have a major backfire while setting the timing, some gas collected overnight and the next day when I stared it I actually blew out my muffler, it has since been replaced. It feels as though there is a fuel starvation or some restriction in the exhaust, it takes a bit of time to get up to speed but I eventually can. As well after it gets hot it starts to idle rough. Any ideas?
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
06-11-2017, 12:29 PM | #2 |
Re: Major Loss of low end power after Pertronix install
What's your timing set at and where do you live?
06-11-2017, 01:07 PM | #3 |
I have tried a few pertronix in a few different vehicles. In each, I ended up going back to original parts, or upgrading to factory electronic ignition. There are a lot of people who have had luck with pertronix products, but I'm not one of them. I was not happy with either the quality or how they ran.
06-11-2017, 01:08 PM | #4 |
Canada and 8 degrees
06-11-2017, 01:13 PM | #5 | |
I used one of their drop in stock look distributors on my Blazer a couple weeks ago. I had a miss show on my timing light and my tach was jumping. It took 4 calls to them and several hours trying to figure out was wrong. They had no idea. The solution in the end I figured out was I had to run a separate power wire to each to the coil and the distributor despite the fact that they both tested adequately for power.
06-11-2017, 02:21 PM | #6 |
06-11-2017, 02:26 PM | #7 |
I'm smack dab in the middle of the country at 812 ft
06-11-2017, 03:20 PM | #8 |
I got it running good with the timing at the 12 o'clock position on the balancer. Problem is my tab is at 2 o'clock so I don't know what the timing is. Did I put the distributor back in the wrong position? I just check with my finger and found TDC lined up with the timing mark correctly.
06-11-2017, 04:03 PM | #9 |
You need to find true tdc on #1 using a piston stop.
Then time it correctly. http://www.crankshaftcoalition.com/w...op_dead_center |
06-12-2017, 08:56 PM | #10 |
driving is in my blood
Yeah sounds like the timing is very advanced. Starts way easy then no power....detonation/pre-ignition? I'd go over timing again and get that light onto the timing tab.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-12-2017, 09:11 PM | #11 |
i got a pertronix coil on my engine and it sucks.
06-12-2017, 10:08 PM | #12 |
I just went over it again. Timing at 8 degrees and it's un drive able. 20ish degrees which is way off the mark and it's perfect.
If I put the distributor back in off one tooth would that cause this? All I did to this engine was pull the distributor to put the pertronix in. It ran fine before all of this.
06-12-2017, 11:34 PM | #13 |
60-66 Nut
Installing the distributor one tooth off from where it was will not change the timing requirement of your engine. My guess is that either the Pertronix unit is not installed correctly or it is defective. I had a bad experience with Pertronix years ago and will never purchase any of their products again.
06-12-2017, 11:34 PM | #14 |
So lets figure this out!
At first you were at 8 degrees, then you weren't sure and now you're at 8 again, sorta. You'll never know what it is or why it's like it is now until you find true tdc like in the link I gave you. And you can be off 3 or 10 teeth and as long as the rotor is pointed at #1 plug wire on the cap it'll still run like it does now. |
06-13-2017, 01:07 AM | #15 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-13-2017, 11:18 AM | #16 |
Never Ending Projects
It is also very possible that the outer ring on the harmonic balancer has spun and now the timing marks do not show true TDC. I have seen this on two trucks and I just swapped out the one on my panel. I could never get the timing marks to line up using plug #1 but if I moved it to plug #3 they would. That's when I knew it had spun, as the truck ran perfect.
You need to determine true TDC first. Work the problem from there.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-13-2017, 01:50 PM | #17 |
Just double checking, but you bypassed the resistor wire when you hooked it up, right? Doubt it would cause your timing issues, but just one more thing to check. Did you ever have trouble with timing it before the install?
06-13-2017, 07:22 PM | #18 |
I contacted Pertonix yesterday and just heard back. This is their response.
"This means you have weak spark. By running the extra timing you are giving the spark event more time to happen. It's a band aid but should not be left this way" They gave me some trouble shooting things to check and report back. I'm thinking the return to points will be in my future.
06-13-2017, 07:41 PM | #19 |
It's only a bandaid if you live at sea level.
Did you tell them where you live? If you did they'd maybe know you need to advance the timing the higher in elevation you go. Air gets thinner, runs a bit richer and needs to start the flame earlier. Why points? Put an hei in it. But you'll still need to figure out why your balancer/timing tab is wacky. |
06-14-2017, 02:08 AM | #20 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Verify that timing mark first!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-14-2017, 08:44 AM | #21 |
I have verified TDC a few days ago. It sure would be nice to have a small cap HEI system that was readily available.
06-14-2017, 09:31 AM | #22 |
What did you use for a piston stop?
Here's a small cap style hei. http://performancedistributors.com/p...nition-system/ Last edited by geezer#99; 06-14-2017 at 10:03 AM. |
06-14-2017, 09:35 AM | #23 |
You mentioned the backfire and that the problem feels like similar to exhaust restriction. Maybe part of the muffler guts blew into the exhaust pipe and stuck, creating a restriction. Or if you still have one, the heat riser valve is now stuck shut from the backfire.
Everyone is suggesting ignition since that was what you changed, but do a tank to carb check of your fuel system. Something might have chosen NOW to fail. And you mentioned the feel of fuel starvation. Did you get a new tank of gas to go test your new ignition? If so, might have been bad gas. What kind of carb? IIRC, some Holleys are sensitive to large backfires. |
06-14-2017, 10:55 AM | #24 | |
06-14-2017, 11:18 AM | #25 |
Wire method is usually 10 to 20 degrees off!
As is the pencil or screwdriver method. Piston stop is the only way. Takes more time but is bang on accurate. |
