12-03-2010, 08:47 PM | #1 |
Bowtie heads vs. Vortec heads
What is the difference between the bowtie heads and vortec heads?
1965 c/10 swb 1969 c/10 lwb |
12-03-2010, 10:50 PM | #2 |
Re: Bowtie heads vs. Vortec heads
Bowtie heads are racing heads. Most of the bowtie castings have large ports and are along the same lines as a set of dart iron eagles. The vortec heads are a stock head that came factory. They are the best flowing productions head from Gm but its not fair to compare vortecs to bowties its apples to oranges.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-03-2010, 11:05 PM | #3 |
the vortecs out flow most bowtie heads,
12-04-2010, 01:20 AM | #4 |
60-66 Nut
There are also Bowtie Vortec heads. They are over the counter heads with larger intake ports, valves, etc. than the production heads.
12-04-2010, 12:57 PM | #5 |
vortecs might outflow bowties under .500 lift but anything over that and vortecs are done. They simply wont flow anymore.
12-04-2010, 01:20 PM | #6 |
These conversations are best had with specific part numbers in front of everyone
12-04-2010, 01:23 PM | #7 |
Utt ohh here comes tickers with facts again .... Very good point.
12-04-2010, 02:06 PM | #8 |
ok lets say the 906 casting to the 034 bowtie
12-04-2010, 02:32 PM | #9 |
This is a question that has an answer
The Vortec is a far better head. The 12480034 head is intended for racing classes that require a "Stock/Replacement" type head and they're based on the '462 (camel back) type casting...but with a ton of extra room in the casting for decking or angle milling and porting. They have a bit better chamber and runner configuration than the old heads, but not by much. They're only available bare for around $750/pair...so they're pretty pricey for mild street head! This is the same type of head offered by Dart, World, etc. that has been certified for those "old skool" racing classes. Racers add in 40 hours or so of porting and maybe a little angle milling and get a pretty decent tier 1 head out of them...but for most folks either the Vortec or another tier 1 head is going to be a better deal. Last edited by Ticker; 12-04-2010 at 07:13 PM. |
12-05-2010, 01:09 PM | #10 |
ok sweet thats some good info!
I was mainly asking what the difference between the two was. not really trying to compare. my bad! So these "vortec bowtie" heads, are they good for the street or more for race?
12-05-2010, 03:40 PM | #11 |
No bad - just Chevy puts "bowtie" on a lot of stuff
GMPP sells Bowtie Vortecs in two sizes - "small port" 185cc under P/N 25534421 and "large port" 225cc under P/N 25534446. Both heads have 2.00/1.550 valves. It takes either a fair bit of RPM or a fair bit of CID to use these heads, so they'd be targeted at a 450+ HP 355 for the small ports, and a 500+ HP 400+ for the 225s. |
12-05-2010, 05:11 PM | #12 |
so the small ports would'nt really go well with my 327?
it was just an idea more or less, i know that people have showed me some other heads but thought i might ask since i didnt know anything about them.
12-05-2010, 05:27 PM | #13 | |
Specs on the 327 would help - CR, cam, intake, exhaust, gears, budget, etc. Last edited by Ticker; 12-05-2010 at 05:27 PM. |
12-05-2010, 08:01 PM | #14 |
well only i can't answer all of those questions.
im shooting for 9.5 to 10.5 cr, cam idk yet most likely a Crane around a .470 lift with a 110 lsa, exhaust not sure, gears 3.73, intake eldelbrock rpm air gap most likely, no more than 2500 stall , manual brakes. budget... lol probably $2500 but who knows
12-05-2010, 09:31 PM | #15 |
Small port vortecs will be fine with that cam.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
12-05-2010, 10:37 PM | #16 |
In that case you're looking at the standard GMPP Vortecs - not the Bowtie versions.
12-05-2010, 11:57 PM | #17 |
60-66 Nut
I agree
The standard Vortecs will work just fine on a mild to moderate 327.
12-06-2010, 12:25 AM | #18 |
Fair enough. Thought i might ask though! Thanks guys!
12-06-2010, 04:43 PM | #19 |
Does anyone have some flow numbers any of these heads Also what is the best vortec head out there for street 400ci plus?
nickle and dime |
12-07-2010, 12:32 AM | #20 |
60-66 Nut
Most every aftermarket head manufacturer will have flow numbers on their website. Here are a couple private sites with some flow numbers also.....
http://users.erols.com/srweiss/tablehdc.htm http://purplesagetradingpost.com/sum...fo/heads1.html As for what head to use on a SB400, that depends on a lot of things. A couple being, how the rest of the engine is built and what is the intended useage of this engine.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 12-07-2010 at 12:34 AM. |
