03-11-2012, 11:13 PM | #1 |
Is this normal?
I was looking at my new to me 71 swb and noticed the rearend has a drop out third member like a ford 9in is this normal? I didn't think it was...
Posted via Mobile Device |
03-11-2012, 11:44 PM | #2 |
20' Daredevil (Ret)
Re: Is this normal?
Could be an Eaton (corporate) HO52 rear diff... got any pics? An Eaton will look something like this:
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-12-2012, 12:02 AM | #3 |
Re: Is this normal?
I took a quick pic with my phone but dunno how to post from an iPhone but it looks similar just doesn't have a removable diff cover it looks factory. My truck is a 71 five lug truck so when I looked under it was a little concerned. I'll try and get a pic up tomorrow.
03-12-2012, 01:08 AM | #4 |
20' Daredevil (Ret)
Re: Is this normal?
OK... Eaton diffs are 8-lugs and used on 3/4T and 1T trucks so that's not what you have.
Don't know offhand who made a drop-in diff with no cover, besides a 9 inch Ford.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 03-12-2012 at 01:14 AM. |
03-12-2012, 01:27 AM | #5 |
Re: Is this normal?
Well that's great guess I'll have to figure what the PO screwed up and see if I can find some original equipment.
03-12-2012, 09:16 AM | #6 |
Re: Is this normal?
early ford pick ups had a 9 inch and 5 on 5 bolt pattern, good rear ends, wind up in a lot of hot rods.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
03-12-2012, 09:44 AM | #7 |
Re: Is this normal?
There's a 5 lugger 71-72 on Craigslist Oklahoma city $150 3.08 open 12 bolt linked HERE
or I have one pretty much an empty housing if you want it. (free)
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
03-12-2012, 12:24 PM | #8 |
Re: Is this normal?
Hey I appreciate it if I can't find one close I might take ya up on that I have a guy down here that has prolly ten of these ok trucks sitting in his lot so I'll see if he has what I need.
03-12-2012, 01:30 PM | #9 |
Roadtrip!
Re: Is this normal?
If it is already in and working fine, i would leave it. The 9" is stronger than the 12 bolt.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-12-2012, 01:33 PM | #10 |
Re: Is this normal?
Interested
1969 Chevy c20(Miss Hackjob) |
03-12-2012, 01:55 PM | #11 |
Re: Is this normal?
Check you lug pattern to see if its 5 on 5 and if not it could be a rear from a mid to late 50's GM car with the trailing arm mounts welded to it. Just a thought.
Bud |
03-12-2012, 04:07 PM | #12 |
Re: Is this normal?
Well it works fine but the trac bar the PO has cobbled on there is no bueno I am going to take pics in a bit and post them tonight I don't have a problem with it just want it to be right and safe. I have several six lug trucks I can rob a rear from but will have to convert it to five. And I don't want it to be a pain to find brakes or replacement parts for.
03-12-2012, 09:50 PM | #13 |
Re: Is this normal?
Ok I took the bed off today to survey what the PO has done and to see what rearend I am working with. So here is the pics... the bad is it’s a 9in and its a cobbled up mess on how they put it under there. So I am now in search of everything back from the cross member that holds the trailing arms... So let the search begin. I really want everything to be back like it was originally and I am doing a suspension kit and blasting the frame and coating it so won’t be a big deal. If anybody needs a good 9in give me a shout I got one lol.
03-12-2012, 09:52 PM | #14 |
67-72 parts collector,…
Re: Is this normal?
That looks like a '57 oldsmobile rearend.
http://cruisinstyle.com/tech/100015/
03-12-2012, 10:15 PM | #15 |
Re: Is this normal?
this
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
03-12-2012, 10:20 PM | #16 |
Re: Is this normal?
Well I have no idea but it's gotta go...
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
03-13-2012, 06:33 AM | #17 |
1969 Custom 30 wrecker
Re: Is this normal?
Might be a 55-64 full size Chevy, they used that style.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
03-13-2012, 06:59 AM | #18 |
Quit if it's not FUN!!!
Re: Is this normal?
I'm thinking "mid 50's or 60's Olds or Pontiac. The tri-five housing is slightly flat on the top and bottom. The Olds/Pont. were more round like what you have. Definitely NOT a 9" Ford. They have a removable front bearing housing. Good luck, and let us know what you find out.
03-13-2012, 07:16 AM | #19 |
Re: Is this normal?
Well if you have access to those 6 lug trucks see if one is a 1970, some of them had the wider housing (same length as 71-72 5 lug) then you can snag everything you need and swap out the 6 lug axles for some 5 lug axles. I forget the measurements but keith (lolife99) can tell you for sure. or for that matter measure all of the rears, my 67 had the wide 70 in it already, thats why I have an empty 71 housing.
03-13-2012, 07:45 AM | #20 |
Re: Is this normal?
Yeah, definitely not a 9".
www.fatdaddieshotrods.com |
03-14-2012, 11:27 AM | #21 | |
Re: Is this normal?
