07-14-2015, 04:28 PM | #76 |
Re: My caster mod (with pictures)
Chevyrestroguy, Any updates on your truck!
07-19-2015, 06:02 PM | #77 |
I'm mocking my parts up to do this mod but it looks like my lca only has .5" before it will hit the saddle during travel. Tons of space everywhere else, just the part of the lca that kicks out will be hitting. Has anyone run into this? The suspension is stock '72 so far.
1968 LWB C20 / AC / Wood Bed |
07-19-2015, 06:11 PM | #78 |
Another angle. This is slightly past stock bumpstop travel.
07-19-2015, 06:52 PM | #79 | |
07-19-2015, 11:56 PM | #80 |
Thanks, I guess I'll go for it. Trim until it fits seems to be the consensus in general...
07-20-2015, 01:11 AM | #81 |
Ok I just went and tried to drill my cross-shaft... what kind of drill bit are you guys using? I didn't even make a dent. I have new TRW cross shafts and they seem to be made of a metallic form of diamond.
07-20-2015, 09:52 AM | #82 |
When I had mine done, I took them to a friend's machine shop and we chucked them up in a lathe and used a flat bottom carbide end mill. A local machine shop would not charge you much to do this. A standard hardware store drill bit set isn't hard enough to drill the hardened cross shaft. Plus, using a mill is much more precise because you can lock the shaft in the mill and get the new pin locations located exactly.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
07-20-2015, 09:56 AM | #83 |
So you trimmed the arm and not the cross member?
07-20-2015, 09:59 AM | #84 |
I have been working some insane hours for the past 6 months, but I have been working on the '64 whenever I have the time. I've gotten a lot of stuff done, mostly the tedious little jobs that drive you crazy. I'll post up progress pictures soon.
07-20-2015, 10:59 AM | #85 |
I did a little off both as I did not want to trim too much off the 'ear' of the arm.
I installed my modified arms & was able to achieve 100% suspension compression w/o contact but ultimately switched to Porterbuilt tubular arms for other reasons.
07-20-2015, 07:14 PM | #86 |
FYI, before you drill your new lower control arm shafts, verify that they match the stock hole position. Some aftermarket shafts come with the hole already moved a bit.
http://67-72chevytrucks.com/vboard/s...&postcount=237 |
07-21-2015, 12:45 AM | #87 | |
That sucks that I can't drill the hole myself, I bought a set of reduced shank bits just for this purpose! What if I just angle grind a notch across the shaft? If I go the right depth it would still prevent the shaft from rotating.
07-21-2015, 09:04 AM | #88 | |
07-21-2015, 11:28 AM | #89 |
If the locating nub is sitting flat on a flat surface of the shaft, the shaft won't spin without the u-bolts loosening significantly or the shaft rounding out. I can't see either of those happening without some other problems going on, and in those cases a rotating shaft would be the least of my worries!
07-21-2015, 12:00 PM | #90 | |
I'll stick w/doing it the way the engineers designed it. Seems safer to me.
07-22-2015, 05:48 PM | #91 | |
07-22-2015, 06:06 PM | #92 |
07-22-2015, 06:15 PM | #93 |
The ones in the link I posted above are Mevotech brand. Part number MK6147 on RockAuto.
07-22-2015, 06:19 PM | #94 |
Mine are TRW 13168A made in USA
07-22-2015, 06:23 PM | #95 |
Thanks. I'd be interested to know how many degrees that adds.
Posted via Mobile Device |
07-22-2015, 11:22 PM | #96 | |
Assuming 9" between ball joints and a currently vertical spindle, 3.14 * (4.5^2) = 64 (radius of a circle) 360 * (64 * .25) = 1.4 degrees (360 degrees in a circle times the fraction of the circle that is 1/4") So 1" should net about 5.6*, 3/4" would be around 4.2* gain
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 07-22-2015 at 11:35 PM. |
07-28-2015, 01:56 AM | #97 |
I ended up grinding a small flat in the shaft and then drilling with a 5/8" masonry bit. I noticed in the process that I didn't need to sink the hole in the shaft at all on the sides because the locating pin sits flush with the seats as they slope upward -- I think grinding flats for locating would work just fine considering this, since a sunk hole is actually just removing material that doesn't need to be there. Using a cap screw might be a different story though depending on the head depth.
07-28-2015, 12:30 PM | #98 |
A guy with a truck
Anyone done this with CPP arms?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-28-2015, 01:57 PM | #99 |
I would measure CPP's vs OE. Seems like they do this from the start & why they can advertise 'improved geometry'.
07-29-2015, 01:20 PM | #100 |
A guy with a truck
Research has led me to believe they gain caster via the uppers, which would pull the wheel back further.
