Old 01-03-2019, 10:02 AM   #1
79 K10 Stepside
79 K10 Warn Lockers wont come out - Help
On my K10 I need to replace the rotors, so I have to remove the Warn Locking Hubs assembly. Typically no problem, remove the bolts take off the snap ring from the axle and remove the outer retaining ring from the hub. On some Warn kits for Chevy's the inner snap ring will not fit due to lack of clearance, Warn instructions say if this is the case you do not need it.
In my situation I had a mechanic (since retired) install the Warn Hubs replacing Mile Marker, Got the snap rings out (Mechanic had ground the snap ring eyelet holes slightly to get it to fit. Got them out no problem, issue is there is no outer retaining ring on the hub and I cannot get the hubs out will not budge. I can see the grove for the ring on the hubs but no ring.
Any ideas before I have to ruin a good pair of Warn hubs??
79 K10 Stepside is offline   Reply With Quote
Old 01-03-2019, 10:49 AM   #2
mongocanfly
mongocanfly's Avatar
Re: 79 K10 Warn Lockers wont come out - Help
got any upclose pics...there should be the outer ring there....its the one that really holds the hub in place
I have put the screws back in the hub once the outer hub is removed to have something to hold onto to pull the inner piece
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-03-2019, 11:57 AM   #3
79 K10 Stepside
Here is a few shots, tough to capture.
Old 01-03-2019, 03:45 PM   #4
79 K10 Stepside
Smile Re: 79 K10 Warn Lockers wont come out - Help
Problem solved needed the right picks and a helper with extra set of hands to hold ring and light. Retainer ring was in there tight. Took extra hands to hold and pry the end, now the fun part removing bearings putting in new rotors and brakes.
Old 01-03-2019, 03:47 PM   #5
mongocanfly
I was gonna say I can see the ring in there...but you got it...
Mongo...aka Greg
RIP Dad
RIP Jesse
