03-20-2017, 03:25 PM | #1 |
'50 Model AD Radiator Support Bolts
I'm looking for the radiator support to frame cross member bolts & shims as shown on sheet 2.11 in the 47-54 Factory Assembly Manual. Apparantly in our haste to dismantle last year these items got misplaced. I've looked in the LMC catalog & online, & Bowtie Bits online and have not found these listed. I also searched The Stovebolt and can up empty.
Appreciate any help.
http://67-72chevytrucks.com/vboard/s...d.php?t=698665 |
03-20-2017, 06:09 PM | #2 |
Re: '50 Model AD Radiator Support Bolts
From what I remember I think I just used some long 3/8 bolts and made shims from thick hard rubber, like old tires sidewalls
These shims are a critical adjustment point for fitting the hood to the cowl
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
03-20-2017, 06:19 PM | #3 |
Here's the pads
http://www.classicparts.com/1950-54-.../#.WNBVG9IrKM8 And the bolts http://www.classicparts.com/1947-54-.../#.WNBVWdIrKM8 They use carriage bolts, which you may be able to find locally. This allows you to loosen them when everything is put together and add shims. |
03-20-2017, 06:29 PM | #4 |
Carriage Bolts!
Any hardware store will have them!
03-20-2017, 08:14 PM | #5 |
Thanks jweb & solidaxel, seems like i do remember a carriage bolt.
03-21-2017, 12:51 PM | #6 |
if it's anything like the tf mount there is also a tube spacer thru the rubber
this allows you to tighten the bolt without totally squashing down the rubber
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
