Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-20-2020, 09:16 PM   #1
Clyde65
Clyde65's Avatar
New project 65 GMC
I got a new project, just a roller
Clyde65 is offline   Reply With Quote
Old 02-20-2020, 09:23 PM   #2
Clyde65
Clyde65's Avatar
Re: New project 65 GMC
couple more pictures
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Old 02-20-2020, 10:27 PM   #3
DPowers
One foot in front of the other
DPowers's Avatar
Nice- congrats
DPowers is offline   Reply With Quote
Old 03-08-2020, 11:23 AM   #4
lownslw64
lownslw64's Avatar
awesome! what are your plans for it?
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors
2007 chevy 2500 hd 4x4 duramax
lownslw64 is offline   Reply With Quote
Old 03-10-2020, 08:42 AM   #5
Clyde65
Clyde65's Avatar
Plans are to pull the chassis, clean, paint and rebuild front and rear suspension. Ls swap it, Clean up the interior, fix the rust through and new body mounts and window seals, roll it like I stole it.
Old 08-30-2020, 09:12 PM   #6
Clyde65
Clyde65's Avatar
A little progress.
All front sheet metal is removed, front suspension removed and burb is up on jack stands to build the front suspension and rebuild rear brakes and check out the differential too. See if seals are needed or worse
Seats are removed to prep for reupholster but first strip, blast and paint.
I have almost every part to get this to roller status with all new suspension. I just need time to do the work. Back injury has taken a toll on how long I can work on it tho.
Once it’s a roller, it’s off to the body shop for a couple rust repairs.
Old 08-31-2020, 08:41 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Cool, can't wait to see more.
Old 08-31-2020, 08:04 PM   #8
Clyde65
Clyde65's Avatar
I got some pictures finally. I have to take small steps for now.
Old 09-03-2020, 07:20 PM   #9
Corts60
Just here to tinker
Corts60's Avatar
Nice score! Looks complete. Does it still have all the window locks? Those things are gold....
Old 09-04-2020, 07:41 AM   #10
Clyde65
Clyde65's Avatar
I found and purchased some window locks, it came with one ugly one tho.
Old 09-11-2020, 09:46 PM   #11
mcnally351
mcnally351's Avatar
Great project!
87 k5 silverado 4x4 350 38k stock
77 k5 Cheyenne 2wd 5.3 4l60e project
mcnally351 is offline   Reply With Quote
Old 09-30-2020, 02:33 PM   #12
Clyde65
Clyde65's Avatar
I got the rear brakes replaced, new drums ( 72 K10) worked like a charm!
Now, im going for the front. I have drilled the holes(2) and elongated(2), other 10 line up fine.
I went with an 87 suburban front suspension because it was cheap and available.
I found a bit of rust through on the DS toe board just up from the clutch pedal.
Rear bumper is bent up pretty good on one side, i may take that and try to get it repaired.
picked up a LM7\4l60E from a local guy, will be sprucing it up a bit too. gonna take the trans to a friend for a once over.
I think that's all the updates for today.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-22-2020, 06:16 PM   #13
Clyde65
Clyde65's Avatar
Front cradle is bolted in,, lower a-arms are in place, rear shocks and rear brake lines replaced.
I had a BTR stage II cam put in the 5.3, trans freshend up too.
I will start the front brakes and all next weekend. Finally got the parts I needed.
Will also drop the stock tank for the new CPP FI tank when it gets here.
Stripped the seats and will send out to blast and paint. Going with gloss fawn on the seats and eventually semi gloss fawn on the interior.
Old 11-22-2020, 10:56 PM   #14
Captainfab
60-66 Nut
It's good to hear you are making some progress
Old 01-14-2021, 01:57 AM   #15
aotte1
Sounds like a nice project, will be watching. As always pictures are great.
aotte1 is offline   Reply With Quote
