Old 12-02-2019, 11:32 PM   #1
WyattTX
Keep my old SBC 350 or ditch it and get a Vortec?
I'm thinking of rebuilding my 350 SBC, but I'm told a Vortec is a better engine.
If I bought a Vortec long block, how many of the old SBC parts can be carried over? I'd also like to use a Q jet on either one. Will the Vortec with a Q jet perform that much better, or should I just rebuild the engine already have? Thanks.
WyattTX is offline   Reply With Quote
Old 12-03-2019, 12:44 AM   #2
truckster
truckster's Avatar
Re: Keep my old SBC 350 or ditch it and get a Vortec?
There will be a night and day difference with the Vortec. In addition to about 100 HP, you'll have the advantage of an engine that will easily go over 250,000 miles, no break-in worries with a roller cam, and a one-piece rear main seal that will keep you leak-free for many miles. The Quadrajet is an excellent choice if you're going to remain carbed.
Some new parts you'll need:
Intake manifold
Flex plate or flywheel
Electric fuel pump
Melonized distributor gear
You'll also need to either change the front cover or get a plug for the sensor hole.
On my build I also change the cam to the GM 14097395 HT383/Ramjet 350 cam. With that combination it should easily put out 330 HP and around 400 ft-lbs of torque.
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 12-03-2019, 01:30 AM   #3
WyattTX
Thanks, what kind of Electric fuel pump would you recommend? Is the Bosch 044 a good choice?
Old 12-03-2019, 11:28 AM   #4
truckster
truckster's Avatar
Bosch makes great products, but you could get a good pump for a lot less. I've used Carter pumps that lasted a long time, and I've read good reviews about the Airtex pump that's available on Amazon for around $32 right now:
https://www.amazon.com/Airtex-E8016S...=fsclp_pl_dp_8
Old 12-03-2019, 12:12 PM   #5
Ziegelsteinfaust
If your rebuilding the Vortec you can have the push rod hole drilled out, and install a new cam with the pump lobe.
The Vortec with the roller cam will not be susceptible to low or no zinc oils of today like a flat tappet engine would be. Although you can change that in a gen 1 too.
Any engine rebuilt today from about the 50's on. Has a good chance if driven alot as in a daily driver. To make it well past 200,000 miles. Old engines were not the issue, but the oil offering very little protection to today's oils was. Earlier babbet bearings I have very little knowledge on. A friend I knew daily drove a flat head V8 1955 F1 for 12 years, and roughly 175,000 miles. Using the best oil he could get 10-20 years ago. Yes it needed alot of maintenance, but it didn't burn much oil. He took it everywhere mind you quite slowly, but he did do it. Even with the 5 speed OD he said 65-70mph was its comfort zone with the gears he had in the back. Which still allowed the truck to be a easy driver, and haul stuff.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-03-2019, 01:49 PM   #6
truckster
truckster's Avatar
That's actually one of the reasons I went with the HT383 cam - it has a pump lobe, and my Vortec is a rebuild of a block that had a mechanical fuel pump provision.
If you're looking for a crate motor, the push rod hole won't be drilled, but if you're looking to rebuild one you might find one with a block-off plate - if you do, it's been drilled. You'll need a bronze-tipped pushrod for a mechanical fuel pump - brass tip goes to the cam lobe.
For what it's worth, if I were starting over I would probably go with a crate engine.
Old 12-03-2019, 06:44 PM   #7
Tom
driving is in my blood
Tom's Avatar
Ummm no. Maybe 50hp extra. Heads = about 40 and the roller cam maybe 10. Otherwise its a standard small block 350 like all the old ones.
Old 12-03-2019, 08:16 PM   #8
Dead Parrot
If your existing block is in good shape, you can add vortec heads + cam + new lifters + new intake. Let's you keep your existing mechanical fuel pump with no extra machining required since you said you wanted to keep the Qjet.
Dead Parrot is offline   Reply With Quote
Old 12-03-2019, 08:34 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Vortec 350's were available from 1996 to 1999. Unless you're talking about drinking LS Kool-aid.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 12-04-2019, 12:31 AM   #10
WyattTX
This seems like the best approach, since I wouldn't be utilizing fuel injection. I'll keep it in mind. Thanks for the suggestions, everyone.
Old 12-04-2019, 08:50 AM   #11
biketopia
I'd use the vortec block, like stated before you get the one piece rear main, unless you have an 86 up block now. You can also use your current timing cover. Go with the factory roller block either have it machined for the push rod or just go with an electric pump. A vortec headed SBC and a LT1/4 hot cam is a pretty potent little combo 400ish HP. I had a set up like that in my Camaro, changed out the springs and used a different retainer but it worked great until I over heated it from my own neglect and roasted the engine.
71 c-10 Long Bed, getting dropped on the ground with an LS, eventually...Scratch that, getting the 427SBC out of the Camaro
03 CCLB Duramax, EFILive, leveled.
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-04-2019, 07:18 PM   #12
Tom
Tom's Avatar
Adding a roller cam to an a old block is WAY more expensive then using a new block and an electric fuel pump.
Old 12-04-2019, 09:36 PM   #13
sweetk30
selective wrench turner guy
sweetk30's Avatar
plowed snow for years in my last k30 with tbi 350 and was happy .
new k30 with new gm long block L31 vortec 350 and edelbrock pro flo 4 efi =
burn less fuel / more power / super happy .
same axles and driveline under new k30 over old k30 .
bolted up my tbi era full serp belt drive no problems .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-04-2019, 11:45 PM   #14
Rick Bollinger
I am freshening up my 350 4 bolt with the elderbrock top end kit with aluminum heads. Kit number https://www.summitracing.com/parts/edl-2038 . I caught it on sale for 1400 and change with a free carb. Selling the carb takes the price down to around $1000.00. Machine shop is going to rebuild my lower end assemble the engine and break in run and dyno for around $1500.00 So for around $2500.00 a new street able 350 with around 350 hp. I could have gotten a rebuilt vortec for that but I knew what I had to rebuild. No knocks or hot runs since I have owned it so there's that piece of mind. Adding a Fi Tech efi should be ready to see the country when done.
Rick Bollinger is offline   Reply With Quote
Old 12-05-2019, 11:31 AM   #15
b454rat
Vortecs went to 02 in vans. I thought roller cam was good for like 50 horse? Didn't think it was only 10. Either way Vortecs make more power than a traditional 350. But like mentioned it's cheaper to go with electric fuel pump than to go retro roller kit. Last time I looked into it (20 years ago) was a grand....
Old 12-05-2019, 01:20 PM   #16
vince1
After all the disassembly and cleaning, I put rings bearings, seals, timing and cam set in a 350. Later I phoned a Chev dealer up here for a price on a 350 long block. They quoted me $5700 plus taxes for their cheapest one and then I thought I had made the right decision in repairing the old one. On further reflection though I sure would have saved a lot of time by buying new. On the upside overhauling a SBC is no longer on my bucket list.
vince1 is offline   Reply With Quote
Old 12-05-2019, 06:15 PM   #17
garyd1961
I gave around $2100 for my brand new block and all GM crate Vortec about 3 years ago.
I thought I saw the same motor online for $2700 (HD version) a couple days ago and the 2 bolt version for a little over 2 grand. Of course that doesn't Include the extra stuff like intake and flexplate or installation.
garyd1961 is offline   Reply With Quote
Old 12-05-2019, 07:58 PM   #18
Tom
Tom's Avatar
The factory vortec cam is only 191/196@050", its puny.
Flat vs roller doesn't mean anything unless you compare specs. Sure, an aftermarket big ass roller cam could get you 50hp. But not a stock truck cam. Not a stock cam from anything actually.
Old 12-06-2019, 12:49 AM   #19
WyattTX
These are all solid ideas. Once I decide something I'll post. Thanks for the input, gentlemen.
Old 12-06-2019, 08:55 AM   #20
rpmerf
rpmerf's Avatar
Some thoughts, not sure how much of it matters.
Power rating for the 1970 350 LS9 found in C/K 10-30 trucks
Compression Ratio: 9.0:1
Gross Horsepower: 255@4600 RPM
Gross Torque: 355@3000 RPM
Now I'm pretty sure I've seen that the net horsepower was 195. This would be the number they went with after 1971.
Specs on the L31 5.7L Vortec 96-02:
Compression Ratio: 9.4:1
255 hp @ 4600 rpm
330 ft-lbs. @ 2800 rpm
The Vortec heads have 64cc combustion chambers. The 1970 heads have 76cc heads. This should change the compression ratio to about 10.2:1. That alone should give you some HP.
The Vortec heads have a relatively low limit on lift. I forget what it is, something like .450 before you hit spring bind. Stock cam has about .428 lift on the exhaust, so there isn't much room without modifying the heads.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-06-2019, 09:53 AM   #21
biketopia
You can toss on a set of LS1/LS6 factory behive springs and a retainer from crane with no modifications to the head and be good to go. The hot cam has lift of 525/525 with a 1.6 rocker. It's a fun little combo and very very streetable. I picked up a set of used take of springs when I did my swap, but I think you can get a set new for like 70 bucks. Here's a good thread I found when I was doing my vortec motor, https://www.thirdgen.org/forums/tech...ortec-lt4.html
Old 12-06-2019, 06:42 PM   #22
Tom
Tom's Avatar
Spring bind isen't the issue, the factory springs will go .480" without issue. Its the retainer to casting boss clearance that is an issue. GM sells these heads stock with cams that go to .480" but tons of people claim issues with as little as .450" lift.
Old 12-06-2019, 08:30 PM   #23
garyd1961
Forget hp, torque is what you want and at 375 ft-lbs at around 3000 rpm on the vortec delivers. The roller cam will open and close the valve a lot quicker than a flat tappet cam. It has a steeper incline and this makes more power than a flat tappet with the same lift.
The old 195 hp motor had something like 396/401 lift. The L31 has 414/428 lift. With the valves opening faster this adds quite a bit more power.
The Vortec heads are GM's cast iron version of their Corvette Fast Burn heads. They burn the fuel faster and more efficiently than the old type heads. That's why you don't need as much total timing with the vortecs. The heads also out flow any factory sbc heads ever produced.
One thing most people don't mention is the L31 uses low tension piston rings which put much less wear on the cylinder walls.
Personally I wouldn't waste my time on the old flat tappet motors. Chevy went to a roller cam for a reason.
Old 12-07-2019, 02:20 PM   #24
68c10owner
68c10owner's Avatar
Stock Vortec 350 was 255hp. TBI was 210hp, think carbed 250 was about 170hp.
You could add vortec heads to your shortblock and even add a roller cam but I agree that the retro fit roller cams are expensive. Its the lifters actually that are expensive.
Personally I would rather use a late 80s-early 90s block over the vortec block. Some are actually drilled for the fuel pump but as mentioned can easily be fixed by the machine shop. Using a oem roller block allows the use of oem roller lifters. They do have limitations but for a street performance engine they will be fine. If you decided to use a mechanical fuel pump with a roller cam you will need a special fuel pump pushrod.
Anthony
78 C10 SWB
68c10owner is offline   Reply With Quote
Old 12-07-2019, 08:55 PM   #25
6T7 C10
I agree with the previous posters on the L31 benefits. I went the Vortec crate route to keep it classic with a touch of modern when I ditched the 250-6. Your carburetor would work fine on a Vortec specific intake manifold. I am using a spectra fuel pump SP1130 along the frame rail. Timing chain cover w/o the hole and yes to the mellonized distributor gear on the HEI distributor. Your accessory brackets will bolt up to the block and heads just like before. The only go fast goodies I have in it are the FelPro 1094 .015 head gaskets and 1.52:1 full roller rockers and it runs fine. Any questions please ask.
6T7 C10 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
