08-12-2017, 03:07 PM | #26 |
Re: Spark Plugs What is wrong?
Just curious, you're running an Edelbrock carb. Are you still running a stock fuel pump, or a low pressure pump? Stock pumps put out too much fuel pressure.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
08-13-2017, 09:32 AM | #27 |
He has bubbles everybody.
I had a head issue I got through this time last year. I had a plug that was stuck, wrung it off flush, removed head(s), magnaflux found crack, better performance rebuilt heads, I'm a happy camper. Hopefully it's just a gasket for you. I guess my plug was rusted in from coolant. Truck never smoked and ran great till I broke the plug while removing to take the header off to access the brake line/hose union better. Talk about a snowball! Good luck!
08-13-2017, 11:39 PM | #28 | |
Who Changed This?
08-14-2017, 10:05 AM | #29 |
Apparently we're the only ones besides the owner that realize his engine troubles go a little deeper than fuel and spark.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
08-14-2017, 03:38 PM | #30 |
Moderator
Yep...he has a constant bubble stream in the radiator...obvious water ingress into at least three cylinders...and an engine running like KRAP...
Pull the heads and take a look... Post a pic of the heads once they are off... Then we can all see what the issue really is... Its a Chevy...its not rocket science... |
08-14-2017, 11:04 PM | #31 |
Yes..thanks guys for all the comments....I am presently working on wiring....
soon will pull the heads...will let everyone know what I find...thanks...Tim |
08-15-2017, 12:00 PM | #32 |
You can confirm the presence of combustion gases by having a shop place their emissions analyzer sniffer above the filler neck, if "HC" readings go up, bingo!
Not all head gaskets leak coolant into the oil, some leak into the intake passages. I'm surprised this engine isn't running hot....if you cannot maintain system pressure in the radiator, the boiling point of the coolant goes way up, placing a vacuum on water does just the opposite, lowers the boiling point. That's why you keep a pressure cap on the radiator. 15-16 psi is normal, should raise the boiling point to 230-240 degrees.something like that. You haven't noticed any unusual smoke/steam coming out from behind when you accelerate have you? Hope it's an easy fix, I'd be looking for cracks in between the combustion chambers or maybe it's just a gasket issue. Hth, Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
08-15-2017, 01:06 PM | #33 |
^^^ This. I've used a buddy's SnapOn emission sniffer for this. I put it on CO (not HC, though maybe either works) and sniffed the filler neck, and even in a car where the leak was slight enough that there were no visible bubbles, the CO count would shoot up when placed over the filler neck.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-15-2017, 02:00 PM | #34 |
I stand corrected! Knew it was one of the two!
Ben
