Old 01-05-2011, 06:31 PM   #1
72longbed
72longbed's Avatar
Question Tow Hook Bolt Pattern?
Maybe some of you guys that have a pair of 71-72 factory tow hooks can help me out. I'm trying to find out the 'center to center' bolt hole pattern for the front hooks for my truck. Are they 4" center to center, or something else? Did the factory drill them at an angle or straight up and down in 1972?
Thanks for your help and I look forward to some good feedback please.
72longbed
72longbed is offline   Reply With Quote
Old 01-05-2011, 07:10 PM   #2
OZman
OZman's Avatar
Re: Tow Hook Bolt Pattern?
On my truck the holes are in the frame. They are angled back.
OZman is offline   Reply With Quote
Old 01-05-2011, 07:15 PM   #3
72longbed
72longbed's Avatar
Thumbs up Re: Tow Hook Bolt Pattern?
Right Ozman ... in the frame. My question is how far apart are the holes? If you measured the center of one hole to the center of the other hole, or the bottom of one hole to the bottom of the other hole, what would that measurement be? That's callled the "bolt pattern".
Is the top hole farther back than the bottom hole, or the other way around?
Thanks.
Old 01-05-2011, 09:40 PM   #4
72longbed
72longbed's Avatar
Question Re: Tow Hook Bolt Pattern?
Can anybody who has a pair of hooks help me out here?
Anybody?
Thanks.
Old 01-06-2011, 08:06 PM   #5
swamp rat
swamp rat's Avatar
If i can remember i'll check my truck tomorrow, if tyou send me a PM tomorrow (friday) morning that may remind me.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-06-2011, 08:54 PM   #6
sdailey
The Few, The Proud
sdailey's Avatar
Here are some pics that I have saved of the '72-only extreme bend hook mounting location. I don't have exact dimensions, but take note of the bolt pattern on each frame rail and how one is mounted higher than the other.
Shannon
sdailey is offline   Reply With Quote
Old 01-06-2011, 09:32 PM   #7
72longbed
72longbed's Avatar
Thanks for the pics sdailey, and for checking the measurement tomorrow swamp rat .... I appreciate your help guys.
Sending a PM to you now swamp rat.
72
Old 01-06-2011, 10:17 PM   #8
Gene
Gene's Avatar
72
I get 3 1/4 center to center from my frame and tow hooks.
Gene is offline   Reply With Quote
Old 01-06-2011, 11:57 PM   #9
72longbed
72longbed's Avatar
Good Deal Gene .... I get one more 'owner' to confirm, and that's the measurement I'll go with.
Thanks Boss!
72longbed
Old 01-07-2011, 07:17 AM   #10
1malo68
1malo68's Avatar
Confirmed
1malo68 is offline   Reply With Quote
Old 01-07-2011, 12:23 PM   #11
I got 3 1/4",too,measured on the truck.
Old 01-07-2011, 04:12 PM   #12
swamp rat
swamp rat's Avatar
It looks like 3 1/4 here too, altho the light was not so great.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-07-2011, 05:20 PM   #13
72longbed
72longbed's Avatar
My Thanks to ALL !! 3.25 is what I'll go with. It looks like the upper hole is back about 3/4 of a hole from the lower one too.
I appreciate everybody's help!
72longbed
Old 01-07-2011, 05:55 PM   #14
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I take it you dont already have a set? if thats true I would hold off on any drilling till you get them..they are a very tight fit and almost touch the bumper and are pretty close to the springs. The best way is to just hold them up against the frame with your bumper mounted and find where they fit the best...if you get the holes to close to the upper or lower frame rail you wont be able to get a nut on the backside.
The 69 to 72 use the same pattern as the 72 only...but I dont remember one being higher than the other like in sdaileys pic.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-07-2011, 08:06 PM   #15
swamp rat
swamp rat's Avatar
Good point! Get them where you want them and clamp them in place with a couple C clamps, then drill them in place using the hook bolt holes as a guide, drill one hole then bolt it, then drill the last.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-07-2011, 09:04 PM   #16
72longbed
72longbed's Avatar
Good Advice ... I'll be sure to do it that way when I can finally find the hooks I want.
Thanks.
Old 01-07-2011, 10:17 PM   #17
sdailey
The Few, The Proud
sdailey's Avatar
Take a look at post #23 in the link below. This is where I found the bolt hole mounting pictures and information about how one hook mounts higher than the other. Being that Frank (pickmup) posted this information I took it to be gospel, especially since he said they were listed on the SPID.
http://67-72chevytrucks.com/vboard/s...d.php?t=218219
Shannon
Old 01-08-2011, 02:08 PM   #18
BLAZERMAN
BLAZERMAN's Avatar
Sorry, Not doubting you one bit..I just said I had never seen them staggered like that...but come to think of it the last 72 that I had I had to drill cause it had no holes. This could very well be a 72 only thing?? I have put the 72 only hooks on 69 to 71 trucks that were factory drilled with no clearance issues.
Old 01-08-2011, 02:37 PM   #19
sdailey
The Few, The Proud
sdailey's Avatar
No problem Rob. I never took it as you doubting me. I just wanted to throw this info out there as well and confuse everyone a little more. I have a set of exteme bend hooks that I'll be mounting on my '69 K10 and it doesn't have any predrilled holes for the hooks. My plan was just to mock them up and drill holes, but then I came across the link I posted above. I've never mounted as set of these hooks, so I'm new at this as well.
Shannon
Old 01-08-2011, 02:37 PM   #20
swamp rat
swamp rat's Avatar
On my 72 the hooks are the same per side, pretty sure they were put on at the factory. Edit: I don't have extreem bend i have the standard 72 bend hooks.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
