05-12-2003, 12:08 AM | #1 |
Trying to fine out compression ratio!
My son has a 87' chevy truck, with a stock fuel injection engine in it. I am wanting to know what the compression ratio is in this truck, and what size heads it has. I am thinking about putting the L98 heads on this truck, they are 59cc on the combustion chamber, i dont want to install them if it is going to jack the compression ratio up so much that it won't run on pump gas. Any ideal what the stock compression ratio is?
What cc heads is on there with out tearing it down? Sam
72 LWB chevy truck. Pasadena, Texas |
05-12-2003, 12:45 AM | #2 |
Used to have a truck
should be 8.5:1 nominal with 76 cc chambbers and dished pistons
No truck :-( |
05-12-2003, 01:07 AM | #3 |
Thanks Mike, that is what I was thinking, what would it be if you went from 76 cc chambers ( being 8.5:1 ) to 59 cc chambers?
Sam
05-12-2003, 02:08 AM | #4 |
Young Gun wth Fast Inline
Desktop Dyno is showing 11.5:1 so it might not be a good idea :S
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
05-12-2003, 02:33 AM | #5 |
BEER-Vacation in a can...
Kurt 03' Trailblazer 69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik 2000 Yamaha V-Star 1100 Custom For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics |
05-12-2003, 03:07 AM | #6 |
chevyhouse,
That site does not do me any good. Sorry, It ask for info that I don't know, the engine is still in the truck and it is running. Sam
05-12-2003, 03:20 AM | #7 |
My guess would be around 10.2:1. Depends some on head gasket thickness though.
05-12-2003, 08:21 AM | #8 |
I come up with: 59cc chamber-12ccdish-4.100 bore gasket-.039 thick-.025 deck height=====9.47-1
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
