Old 12-15-2016, 04:29 PM   #301
donandal
Re: Plus Five
I'll post more of the radio install after I get the dash speaker and
sub.
I installed the fuel filler and tank emissions lines.
Charcoal canister and vents all hooked up.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 12-15-2016, 04:32 PM   #302
donandal
Re: Plus Five
and the filler...
53 Chevy Pickup
Old 12-15-2016, 04:39 PM   #303
donandal
Re: Plus Five
I also temporarily installed the park brake and center console
frame. The handle is from a 350Z, and the bell-crank and assembly
I made from scratch. It drops thru the floor and will have a grommet
to seal it up.
It will be covered later.
53 Chevy Pickup
Old 12-15-2016, 04:43 PM   #304
donandal
Re: Plus Five
the rest of the linkage,
53 Chevy Pickup
Old 12-17-2016, 09:26 AM   #305
RockinKees
RockinKees's Avatar
Re: Plus Five
Nice update!
I have to make a parkbrake myself, you have set me in the right direction, Thanks!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-17-2016, 03:53 PM   #306
donandal
Re: Plus Five
Originally Posted by RockinKees View Post
Nice update!
Thanks,
those kind of parts are fun to make.
53 Chevy Pickup
Old 12-17-2016, 04:01 PM   #307
donandal
Re: Plus Five
I got the speaker for the dash yesterday.
today was drizzly and cold so I spent a few hours in the shop.
I made a bracket for the speaker, and mounted it temporarily.
It will be covered with black speaker cloth.
I also made a thru the firewall fitting for the windshield washer line.
I'll make a reservoir for the fluid later, and mount it in the engine
compartment.
53 Chevy Pickup
Old 01-02-2017, 05:22 PM   #308
donandal
Re: Plus Five
New Years update,
I don't have any pictures, but made some real progress.
I painted the emissions lines and put new emissions/fuel hose on
the lines and new stainless hose clamps so that is all complete.
I also completed several wiring harness tasks. I completed the Radio,A/C,
cigarette lighter,motorized cowl vent,wipers,headlights,turn signals, horn,
third brake light,backup lights,sport mode, overdrive lockout button, LED dimmer,
high/low beam dimmer, ignition switch, interior dome/courtesy lights,front hood tilt,
power seats,park brake light, cooling fans, engine harness, check engine light, etc.
In fact, I think everything is wired up except the two round gauges.
I'll make a separate harness for those two.
I installed the fuses and so far everything works!
I even bumped the starter a few times....
53 Chevy Pickup
Old 01-02-2017, 05:46 PM   #309
mongocanfly
Re: Plus Five
Sounds like your getting close..
mongocanfly is online now   Reply With Quote
Old 01-02-2017, 06:10 PM   #310
Flysocal
Re: Plus Five
This will be epic
Flysocal is offline   Reply With Quote
Old 01-02-2017, 10:03 PM   #311
gotmotors
gotmotors's Avatar
Re: Plus Five
Just read through your whole thread and I'm blown away by your fab skills and attention to detail. Funny how all those systems that you didn't have a "comfort level" with seemed to get finished up like you had been doing it for years. Looking forward to seeing you finish her up.
Jim
My 55 build
http://www.trifive.com/forums/showthread.php?t=97044
gotmotors is offline   Reply With Quote
Old 01-03-2017, 06:03 AM   #312
donandal
Re: Plus Five
Thanks,
I am hoping it won't be an epic fail!
I have plans to have friends stand by with fire extinguishers for the
First start up.
Wiring has me a little nervous.
Hoping for start in February
53 Chevy Pickup
Old 01-11-2017, 07:47 PM   #313
donandal
Re: Plus Five
Ok,
I'm on the road again tonight, and have a question about my
transmission control.
I have the Connect and cruise supermatic transmission controller
and the harness included a wire labeled "brake light".
The instructions read as follows;
2.2.9 Brake light wire
Although not necessary,the wire labeled "brake light" should be
run to a factory brake pedal switch (NC) so the TCC will unlock
When you apply the brakes.
The switch I have has six terminals, some NC and some NO.
Is the tranny looking for a 12 volt + positive or is it looking for
a ground to be supplied to this wire?
53 Chevy Pickup
Old 01-11-2017, 08:15 PM   #314
MIKESAD50
Re: Plus Five
I'm going with 12 volts + on mine, I didnt think anything different. Generally 12 in and 12 out.
My thought just looking for you stepping on brake
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 01-11-2017, 08:46 PM   #315
donandal
Re: Plus Five
Thanks Mike,
Just to be clear, cause I know nothing about this, the 12v + that feeds
into the brake switch to power the brake lights is normally open isn't it?
I think it is Orange wire in my AAutowire harness.
I pick up the out put side of that switch....
The tranny would not see a 12v positive till you step on the brakes,
and this 12v + is sent to the brakes lights AND now also the tranny TCC?
53 Chevy Pickup
Old 01-11-2017, 09:04 PM   #316
MIKESAD50
Re: Plus Five
Yes normally open switch, would be 12+ in and 12+out to brake lights, and Trans control module.
I havent driven yet either.
I figured if they wanted a normally closed switch they would say that. in instructions.
1950 3100 5 window
Old 01-11-2017, 09:29 PM   #317
donandal
Re: Plus Five
I agree about the 12v + part, but the instructions on mine said that
part in parenthesis about (NC), so I'm still confused.
For all of the other functions they tell you what the wire is "looking"
for, like the O/drive or shift modes needed a ground signal for example.
Any transmission guys out there?
53 Chevy Pickup
Old 01-11-2017, 10:15 PM   #318
mongocanfly
Re: Plus Five
THE transmission man around here on this site is clinebarger..contact him
Old 01-11-2017, 10:29 PM   #319
MIKESAD50
Re: Plus Five
If I have given you wrong info. Sorry. I will also have to change my wiring.
1950 3100 5 window
Old 01-12-2017, 12:32 AM   #320
solidaxel
solidaxel's Avatar
Re: Plus Five
Rock Auto is having a big sale, do you have one of these for your TCC and brake light
I just bought one from AZ and I think it was 15.00
STANDARD MOTOR PRODUCTS SLS89 Info
Brake Light Switch w/CRUISE CONTROL
Choose:
^ Ships from same location as parts in cart
$1.64
Part In Cart
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll ZZ4 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red 327
340hp 4spd 3:36
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wifes cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-12-2017, 05:46 AM   #321
donandal
Re: Plus Five
Choose:
$1.64
Part In Cart
Thanks for that,
I just looked at it, and I have something similar that has two
more terminals, but works the same.
53 Chevy Pickup
Old 01-12-2017, 05:50 AM   #322
donandal
Re: Plus Five
That's the thing,
You may be right, I just don't know from my instructions.
I'll try to get info from Pace performance, or clinebarger.
I'll keep you posted.
53 Chevy Pickup
Old 01-12-2017, 08:52 AM   #323
solidaxel
solidaxel's Avatar
Re: Plus Five
Brake light ON
TCC off cruise off
340hp 4spd 3:36
Old 01-12-2017, 12:02 PM   #324
donandal
Re: Plus Five
Brake light ON
TCC off cruise off
Thanks,
I have terminals available to use for this correctly.
53 Chevy Pickup
Old 01-14-2017, 05:08 PM   #325
donandal
Re: Plus Five
installed the gauges and speaker,
53 Chevy Pickup
Copyright ©2000 - 2018, vBulletin Solutions Inc.
