Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-09-2018, 10:52 PM   #1
lutronjim
O'Reilly's
Had need of a 25" 4 gauge battery cable and looked online. Napa had them but with the crappy spring ends. O'Reilly had them copper with the 'bolt' ends - so off to the store I went. It was folded up in a package about 6" long.
I couldn't hardly bend the old cable in a 90 much less 180. Course its China made.
lutronjim is offline   Reply With Quote
Old 10-09-2018, 11:07 PM   #2
dmjlambert
dmjlambert's Avatar
Re: O'Reilly's
Yep.
http://67-72chevytrucks.com/vboard/s...d.php?t=734496
Old 10-11-2018, 07:56 AM   #3
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: O'Reilly's
Harbor freight has cables.
https://www.harborfreight.com/3-ft-i...awg-63748.html
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-11-2018, 09:19 PM   #4
lutronjim
Re: O'Reilly's
Went by - they don't have 'post' cables.
Old 10-12-2018, 09:11 AM   #5
gmachinz
Re: O'Reilly's
You can special order cables through a parts store from BWD-I have their catalog.
Specializing in building electrical harnesses and cooling systems
HARNESSWORX
"An army may march great distances without distress, if it marches through country where the enemy is not."
-Sun Tzu: The Art of War
gmachinz is offline   Reply With Quote
Old 10-19-2018, 05:47 PM   #6
ManNamedJed
Junior Member
Re: O'Reilly's
Have you tried building your own? Its super easy if you use the solder pellets.
I've built cables for my suburban and my jeep using this method:
https://www.wiringdepot.com/jt-t-tec...-Battery-Cable
I put copper lugs on the end and use these terminals:
https://www.wiringdepot.com/store/p/...als-clone.aspx
This works especially well if you have a winch or dual batteries.
I also replace the fusible link wire with a resettable breaker (still cleaning up the rest of that wiring):
ManNamedJed is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
