01-29-2019, 03:50 PM | #1 |
high/low hump
i currently have a 64 k10, that is rusted beyond repair around winshield glass. i have a 65 c10 cab that im looking to swap. everything should be the same except for hump correct, even though it appears to be pain to swap them. thanks in advance
01-29-2019, 04:29 PM | #2 |
Re: high/low hump
The "K" in that VIN is what makes the cab valuable... and worth repairing.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
01-29-2019, 05:58 PM | #3 |
Check The Champ, Demonstrator
Re: high/low hump
65 the floor is stamped a low hump while the 4 spd high hump is removable?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
01-29-2019, 07:29 PM | #4 |
Re: high/low hump
My low hump on 62 was bolt in. You can swap or Slosh Tubz sells a fiberglass one.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-30-2019, 12:41 AM | #5 |
60-66 Nut
Re: high/low hump
Assuming that the 'new' cab has a non-removeable low hump, you will have to change the mating piece that is spot welded to the firewall/floor. And then you will need to attach some nuts or threaded inserts to bolt the high hump to the floor.
