08-02-2011, 11:07 AM | #26 |
Re: Anyone running this? TCI lock-up kit for 700R4.
Might just have to hit you up some time. I have been sporting my short bed in town but might park it till the temp is down a bit. Got to love the Casa Grandes dehydrated rain. "Just add water!"
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
08-03-2011, 03:34 PM | #27 |
So I did a bit more testing. I replaced the radiator and installed some new fans. Motor temp is 195 and tranny in running 175. This is running hard in the AZ heat.
08-03-2011, 04:12 PM | #28 |
Newbee
Looks good!
From past experience, that fan thermostat will let you down at the worst possible moment. You may want to upgrade. |
08-03-2011, 05:42 PM | #29 |
Thats good to know. This is the first day running it. I will soon be adding A/C so when I get ready to do that I might just make it run all the time. Any ideas on a good unit to upgrade with?
11-29-2011, 10:59 AM | #30 |
Hello, I'm looking to do a inline 6 out of a 70 Chevy and a 700r4 and a 3.38 rear end. I'm building my 58 mostly to be a good driver and as fuel economical as possible
I would like it to be as simple as possible as any advice would be most apprecaited(me speel goood) Thanks
I pity the fool with only 2 headlights! |
04-19-2018, 03:36 PM | #31 |
I have a 86 700r4 that seems to have a bad 4th since it doesn't ever shift from 3rd to 4th. I think the last guy might have messed it up some how. I read that 4th can go after a rebuild or if someone doesn't have their TV cable right.
If I run the 700r4 in "D" instead of "OD", will it let me get by without having the lockup cable hooked up? I have heard that 85 and up will not burn up, if you run without lock up, but I wish I knew for sure. I like it how it is and it drives like a turbo 350, but I am wondering about excessive heat and wonder if that excessive heat is only when TC spins in 4th? My solenoid only clicked once and is probably bad, which is another reason im fine with no 4th.
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
07-05-2018, 07:07 PM | #32 |
But Found Her 25yrs Later!
Bumping this up for further discussion.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-09-2018, 12:05 AM | #33 |
I made my own setup. Ran fused ign on +12 thru a dual brake light switch to one side of the TC lockup solenoid and the ground side to a normally open 4th gear only pressure switch. Also tapped into the ground side with a wire running under the dash to hook up to a switch in the event I want the lockup in 3rd. So far works great and only cost me about $25 to do it.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
