09-03-2020, 08:22 PM | #1351 |
Re: Columbus..the 1957 IH 4x4..
getting ready to bleed the brakes...since I'm a one man operation it's a near impossibility to do without mech help..I've had a mityvac for several yrs..and it really sucked...very hard to keep air out of it..
I had seen on TV where they had a pump that hooks to the master cylinder...it had a hand pump like a garden sprayer,but no cap assortment....I was searching for those when I ran across this ...its pressured up with a air hose..and comes with every kind of cap imaginable...it was only a few dollars more..so I sprung for this..will give it a try this weekend and see how it works...
09-04-2020, 07:34 AM | #1352 |
Richard...the sealer in the tube isnt glue according to them..
Heres what they sent me.. Thank you for your inquiry. We recommend using a polyurethane based adhesive on our products. The smallest we offer is two gallons to cover 120 square feet which is probably a lot more than you need but polyurethane is what we recommend.... I tried some 3M847 adhesive last night... just checked it...it didnt hold either..
09-04-2020, 08:59 AM | #1353 |
Equal opportunity joke ofender
well crap. take a look at this link from McMaster. It looks as if JB weld is actually a possibility
https://www.mcmaster.com/polyurethane-glue .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
09-04-2020, 10:20 PM | #1354 |
I ordered some 3M5200 black...gonna try it...
09-05-2020, 11:30 AM | #1355 |
Proprietor of Dale's Corner
Best of luck, I hope you find something that works.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-13-2020, 09:47 PM | #1356 |
thanks Dale..glue is still stuck in the mail somewhere.....haha
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 09-13-2020 at 09:59 PM. |
09-13-2020, 09:48 PM | #1357 |
I took a week or so off to get caught up on non-truck stuff that i been letting pile up on me.
Got most of it done and now I forgot where I was.. One thing that bothered me was on my hydroboost lines was the ol ribbed plastic loom crap.. For some reason to me the stuff looks outta place on old trucks...I was just gonna leave it off and not use anything on the hoses..but while i was working on my tractor it dawned on me the hydraulic hoses have a sheath over them..so some quick measuring and a Ebay search and I had a piece to go over all 3 hose I like it much better than the plastic crap..
09-13-2020, 09:54 PM | #1358 |
Also after several delays in shipping (thanks corona)..
the relays finally showed up.. These are for the homade rear blinker setup ill have to do for the rear blinkers.. on the IH , blinkers were a option..the column is setup for blinkers but that's it..no hardware..out side of adding another set of lights to the rear there was no way to cancel the brake light so it would blink..on the front marker lights I changed out the 1156 bulb sockets to a 1157, so that solved the fronts..so to make the rear brake lights blink I'm gonna use a normally closed relay in each brake light wire..so when the front blinks, it will fire the relay momentarily to make the rear blink..only downside is the front and rears will blink alternately..but that's no big deal... Still waiting on the floormat glue..(thanks again corona)...shipping delayed on it as well
09-13-2020, 09:58 PM | #1359 |
Also I didn't get the brake bleeding done yet..I wasnt real thrilled with the bleeder lid that's for the reservoir
It's very flimsy and very difficult to get it to seal off without leaking... So I made me one from 1/4" aluminum plate..a c-clamp to hold it down..and I'm in business...I'll l have to wait a day or so to try out but I think itll work.. Our temps have been dropping along with humidity so hopefully I can get the painting finished soon... But we got a hurricane headed some what for us, so I may wait it out...
09-14-2020, 05:32 AM | #1360 |
It's coming together. I hope the glue gets found and you can only see one end of the truck at a time. Who's gonna noticem them blinking differently.
09-14-2020, 05:55 AM | #1361 |
Good progress, the little things can be time consuming
71 C10 72 K20 72 K10 Super Kirk |
09-14-2020, 07:04 AM | #1362 |
Coming along nicely! I don’t envy your humidity, but heck we had a random blast of snow last week. Crazy, but now it’s in the 80s and dry again.
You will really like that pressure pot for bleeding brakes. We had something similar at the Benz dealer. They work so well that I never had to bench bleed anything using one. Pressure bleeding is the only way to go.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
09-14-2020, 07:40 AM | #1363 |
Thanks Dale...you wont be able to see front and back at the same time..unless you see a reflection..
I think even some square bodys had alternating blinkers on the front and the front fender Thanks Kirk...these little things just seem to drag out.. Thanks Clay...I'm really hoping the pressure bleeder works out...itll save me alot of hassle A IH guy I know up around the San Juan's told me he got about 5-6" of snow...and I think he got snow in June also..
09-15-2020, 05:42 PM | #1364 |
So my floormat glue finally showed up...so I was gonna do a test piece, and thought I'd give reading the directions a shot...well it says that once you punch the end of the tube, the tube has a 24hr shelf life..
Well that sucks...I'm not quite ready to be gluing floormat, so I guess itll have to wait... Was gonna get started on bleeding the brakes..poured some fluid in the reservoir and about a minute later I had fluid dripping on the ground...what the heck...even though I thought I had all the fittings tight, i didnt.. Had a loose fitting on the splitter T for the front...it was snug, just not tight..got that fixed...turned around and I see another drip..this one is a doozy..I had previously reinforced the front frame rails and boxed them in..not realizing I had a union behind the plate...yep its loose..and no way to get to it...so it's off to town for another piece of tubing and some unions...I'll reflare the tubing and move the unions out to where I can get at em..just more delays...
09-15-2020, 05:58 PM | #1365 |
I hate it when that happens. Still it is progress. I have none to report so I live through yours.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-15-2020, 08:34 PM | #1366 |
It is progress zepp...luckily I remembered I had a extra stick of 1/4" brake line leftover and I had a spare coupler and some nuts, so I saved a trip to town...already got it fixed, so I'll try the bleeding tomorrow..
09-15-2020, 09:26 PM | #1367 |
I hope it works out. But, 0progress is progress ya know
09-17-2020, 11:29 AM | #1368 |
I'm hooked on this thread. I love the way you solve problems as they arrive. I'm looking forward to seeing a pic of this truck when it's done.
09-17-2020, 01:42 PM | #1369 |
x2
09-17-2020, 05:16 PM | #1370 |
thanks fellers...
sometimes it seems like I can work all day and get nothing done.. I like to see big changes happen....but I know the little stuff has to be done as well
09-20-2020, 01:01 AM | #1371 |
After numerous delays, I finally got around to the bleeding....brakes that is..
The 1 man brake bleeder works pretty decent...id give it a B+...a few things I figured out by trial and error is fill the bladder full before you start..I didnt and about half way thru I had to start over...the other thing is the catch can that hooks on the bleeder screw isn't vented..found that out after I blew the lid off..so I just left the lid off.. A buddy at the dealership said this unit is similar to what they use but on a smaller scale... I started with a completely dry system..didt bench bleed the master cylinder either. I did gravity bleed the whole system before I started just so I'd have some fluid in there before I pressured it up..that's how I found the leaks I had..theve all stopped now.. I've got full engagement at half pedal..so I'll have to wait and see what it's like once the hydroboost is in play..
09-21-2020, 09:04 AM | #1372 |
I like that bleeder. Good idea.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
09-24-2020, 11:27 PM | #1373 |
Thanks Robert..!!..it worked pretty good...
09-24-2020, 11:28 PM | #1374 |
Another thing I been waiting on is some extra interior lighting...after I got the orig dome light working, even with the led bulb, it had less than useful results..would barely light up the cab..guess I'm to used to my GMC with all its lights..so I ordered a set of 4 led lights ..they were advertised as interior or tag lights..I was hoping I could get by with just using 2 of them, but after a light test, I'll need all 4..I'll mount 1 on each kick panel, and the other 2 on each side of the glove box...all aimed towards the firewall..
They'll be wired in to the dome light and the eventual door switches
10-01-2020, 12:33 AM | #1375 |
After several (as in many) delays, I finally got the doors painted..I'm gonna go ahead and say probably for the 1st time based on my past painting adventures..
