Old 09-17-2020, 12:22 PM   #26
Tom
driving is in my blood
Tom's Avatar
Re: Tom's 4L60E build
Amazing. This is why I didn't try it myself.
As for the water...I had the trans in the detail bay at the dealership I work at. I'm assuming a cleaner got some on it being careless.
Old 09-17-2020, 04:22 PM   #27
AussieinNC
Moderator
AussieinNC's Avatar
This tutorial is fantastic!
clinebarger is a true professional who doesnt mind sharing his expertise....
Thank you!
Family and country before all others...
1968 C-10 SWB
1974 C-10 Longbed
2001 GMC Sierra
2006 Chevy Silverado (Daily Driver)
AussieinNC is offline   Reply With Quote
Old 09-17-2020, 09:57 PM   #28
clinebarger
Got the Band Clearance right with a Sonnax 77787-02K servo pin kit, Uses 700R4 Teflon seals for the 4th apply circuit & an O-ring to seal where the 2nd apply piston rides......
clinebarger is offline   Reply With Quote
Old 09-17-2020, 10:05 PM   #29
clinebarger
Finished up the pump, Running a Sonnax .490" Boost Valve & a 10% over Regulator Spring......
Old 09-17-2020, 11:23 PM   #30
clinebarger
Next up is the 2nd & 4th Accumulators, Spacer Plate, & Valve Body....
*I blocked the 4th Accumulator by driving a .250" check ball into the 4th Clutch feed hole in the case, If you leave the Accumulator piston in the case......The Lo/Reverse Clutch will no longer receive orificed lube while in 4th gear. So I leave the piston & pin out of the case & let Accumulator Oil feed the orificed lube circuit at all times.
*The 2nd Accumulator Piston, Springs, & Housing were in excellent shape & got reused with a new piston seal.
*This in a new OE GM spacer plate for a 2003 Silverado SS.....
2nd feed.....Left factory at .073"
3rd feed.......093"
3-4 Circuit....093"
4th feed........093"
BR (Band Release).....Left factory a .086"
*Basically installed most of a TransGo SK-4L60E shift kit.....
*Did not use the 2nd Accumulator Springs as they break.
*Did not use the 4th Accumulator Spring because it's blocked.
*Did not use the Pressure Regulator Spring because I use the Sonnax 10% over one, I DID use the PR Bumper Spring though.
*****Your Accumulator Valve was stuck HARD in it's Bushing, I had a like new one with the same (DX) code, Was this thing "Thumping" into 2nd before it started slipping??
This PIN (Arrow) can be removed & allows access to the Accumulator Valve & Bushing without dropping the Valve Body.
I used the recommended 24oz TG spring (For a DX Accumulator Bushing & a Vette Servo)
****After a minimum of 500 miles, If you find the 1-2 Shift a little soft for your liking......Swap the Accumulator Spring for the next heavier weight. I'll send all the extra Accumulator Springs with the trans.
****If the 1-2 Shift is too Firm for your liking.....Remove the Spring entirely.
IF it's still too firm......You'll need to source a YZ,C,CX code Accumulator Bushing & Valve, These are found in Camaro, Firebird, & Corvette 4L60E's.
A,AX,B,BX code bushings are found in 700R4 & 4L60 units & require a slight modification to work with the "Special Pin"
I'm confident you'll be happy with the 1-2 shift after the Band gets seated in, But without being able to test drive it myself.....It's definitely a variable!
Old 09-17-2020, 11:31 PM   #31
clinebarger
Forgot the most important page.....This gives you the Accumulator Spring colors to their respective weights.....
Old 09-17-2020, 11:33 PM   #32
clinebarger
Waiting for a Delco Filter from Amazon......Nobody has one locally! F'ing Covid!!!!!
Old 09-18-2020, 07:59 AM   #33
AussieinNC
Moderator
AussieinNC's Avatar
Thank you for your excellent tutorial...plain language, excellent images....
True professional....
1968 C-10 SWB
1974 C-10 Longbed
2001 GMC Sierra
Old 09-18-2020, 10:26 PM   #34
clinebarger
You're welcome.
Old 09-21-2020, 07:12 PM   #35
Tom
Tom's Avatar
No, it worked perfectly until it slipped in 3rd gear accelerating on a freeway on ramp. I did put the b&m line pressure controller into its highest pressure setting at that point and drove it another month or so until I could afford a rebuild.
Old 09-21-2020, 10:30 PM   #36
clinebarger
Who knows when the valve stuck, I was just curious, But I don't think it was shrapnel from the pump as I could Clear It by working the valve back & forth.....I wasn't stuck fully closed either.
Finished it up this mourning with a GM filter & pan gasket, Has new O-rings & Clips in the Cooler Fittings, New Shift Shaft Seal, And the VSS Sensor got damaged somehow.....It got replaced with a used one out of my stock with a new O-ring.
You now have 2 magnets in the pan instead of 1.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
