Old 04-05-2008, 06:09 PM   #1
BluTrukker
BOHICA
BluTrukker's Avatar
gas filler cap leaks
My 68 has a new gas tank in the factory location(PO installed). The problem I have is gas leaks out any time I make a right hand turn with more than a half tank of gas. The cap is pretty new. it also looks like the PO used a file to smooth out the very top of the neck, maybe that is causing it, I don't know. Is there any type of gas cap that can correct this? Possibly one that fits down inside the neck and expands?
BluTrukker is offline   Reply With Quote
Old 04-05-2008, 06:57 PM   #2
elektrik
Foolish Mortal
elektrik's Avatar
Re: gas filler cap leaks
I recently had the exact same problem-I swapped out my old gas tank for a new one (in fact, I haven't even gotten rid of the old one-still in the garage, )...
Anyways, I was leaking gas all over my new paint job-was getting pissed; however, the way I ended up fixing it was by troubleshooting a (seemingly) unrelated problem-I had a new tank, sending unit and locking gas cap but my gas gauge wasn't "working". I also noticed when I removed my gas cap that all these fumes and pressure would release from the tank, and that my gauge would work (temporarily)
The solution (for me anyways): I took the gas cap (it was plastic), found the smallest drill bit I could find, and drilled a miniature hole in my gas cap-that relieved the pressure, made my gauge work and stopped the spillage (because the cap could seal correctly)...
elektrik is offline   Reply With Quote
Old 04-05-2008, 07:09 PM   #3
68jimmy
68jimmy's Avatar
Go to your favorite auto parts and ask for a stant non-locking vented gas cap for a 67-70. The one I picked up is chrome non-locking and looks original. It has a thick rubber o-ring and is very snug as you twist it on, I no longer have issues with leaks when turning or any pressure buildup. I was using a locking stant cap previously...
good luck.
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 04-05-2008, 11:06 PM   #4
El Jay
Gone to greener pastures
I don't know the part#, but I got locking caps from my local CarQuest store.
Haven't had a more problems with leakage on either truck.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-06-2008, 07:52 AM   #5
Brad
Out of the carpool lane.
Brad's Avatar
In the past I've just used compressed cardboard- like what's used for gaskets- that I had laying around and made 2 donuts and added them to the rubber. It helped seal the filler tube.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 04-09-2008, 10:45 PM   #6
68c10guy
68c10guy's Avatar
is the gas cap supposed to be vented?
68c10guy is offline   Reply With Quote
Old 04-10-2008, 01:06 AM   #7
HoupPhotography
That's a good question, mine isn't. I had the same problem, gas spilling out of the filler neck... I looked at my gas cap and the rubber was deteriorated in some area's, bought a new one at checker and the problem went away.
If your adding anything to the filler cap, it's the wrong one. Thre are a few that look the same, the difference is the inner cylinder. Be POSITIVE that the one you have is correct for your application.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 04-10-2008, 03:02 AM   #8
Sicmaro
Always wrenching!!
Sicmaro's Avatar
the tanks should be vented...... mine did the same thing, I just re-bent the lip of the filler neck where the cap locks onto it and it holds the cap tighter and no leaks.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 04-10-2008, 06:52 PM   #9
68jimmy
68jimmy's Avatar
Not sure if it was 71 or 72 when the tank came with a vent as part of the fuel sending unit or not... But I do know that my 68 requires a vented cap otherwise it build all sorts of pressure especially now that the weather is warming up.
Old 04-10-2008, 07:00 PM   #10
prg machine
prg machine's Avatar
good luck.
Is "stant" a brand name?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 04-10-2008, 07:04 PM   #11
BluTrukker
BOHICA
BluTrukker's Avatar
I was wondering if "stant"is a brand or he meant "standard". Anyway I plan on stopping in to the parts store next week, so I will check.
Old 04-10-2008, 07:05 PM   #12
BluTrukker
BOHICA
BluTrukker's Avatar
68jimmy, do you have a pic of the cap so I know what it looks like?
Old 04-10-2008, 11:25 PM   #13
prg machine
I wonder what it is?
383 .040 over
Old 04-10-2008, 11:33 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
Stant is a brand name...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-11-2008, 01:42 AM   #15
elektrik
Foolish Mortal
elektrik's Avatar
That's why I just drilled a tiny little hole in my gas cap, because I figured it was a *cheaper* fix than modifying my gas tank =]
Old 04-11-2008, 03:51 AM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
stant p/n 11623 for 67 - 70.
Old 04-11-2008, 04:54 AM   #17
BluTrukker
BOHICA
BluTrukker's Avatar
Thank you very much everyone.
Old 04-12-2008, 04:02 AM   #18
prg machine
who sell dat??????????????
383 .040 over
Old 04-12-2008, 04:58 AM   #19
Longhorn Man
I know advance auto does... with stant being the biggest name in thermostats... I'm willing to bet any parts house can get it, or cross reference the number at least. But that's a good number. I've held onto it after getting one for my first truck, then second and third, and I've lost a cap, had one stollen (with the fuel) ran over one... and managed to wear a couple out.
Old 04-12-2008, 08:10 AM   #20
rwgregory
I have a Stant locking cap on my '67 GMC. The cap used to fit loosly on the filler neck when installed and would spew fuel out whenever turning right at anything above a crawl. I got 3 large O-rings at the parts store and put them over the snout of the gas cap. Now the cap fits snugly up against the lip of the filler neck, still breathes, and only spits out a drop or two of fuel when turning right.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 04-12-2008, 04:10 PM   #21
68jimmy
68jimmy's Avatar
Here is a link with a picture...
http://www.partsamerica.com/ProductD...rtNumber=11623
Old 04-12-2008, 07:59 PM   #22
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
I decided to buy a new cap from Classic Parts as the old one was loose and had some paper wraped around to try and make a better seal by the PO but the new Stant one did not fit the neck, so I thought I had choose the wrong year or maybe it was for a stepside, so got another and made sure this time, but it was the same as the last one...now i've added an extra rubber washer to the origianal and it's fine.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-12-2008, 01:11 AM   #23
72-c20
Packrat
72-c20's Avatar
my 72 K20 did not have any vent fittings in the tank, and just one fitting on the sending unit.... no charcoal venting in the engine bay either....
according to some stuff I've been reading the the vents were not put on the 20-30 series trucks (some GVW cut-off)...
I replaced my tank with a '72 style tank, and a new cap, and I capped all the vent fittings on the tank, but my old vented cap does not fit the filler neck at all.
not sure if my new cap is going to cause a problem or not.... I don't think it's vented....
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
