01-12-2018, 08:11 PM | #1 |
69 c10 wont fire up
ok so im back ... my poor 69 wont fire it was fine 2 weeks ago. its a inline 250 with HEI i took the coil out and put a meter on it both the primary and secondary coil ar good. i have power going to the cap. ran i hot wire right to it from the batt just to make sure. wtf is going on. what should i check next . took a plug out had my gf turn the truck over as i grounded the threads no spark. what is going on? please please help me . i want back in my truck .
01-12-2018, 08:13 PM | #2 |
Re: 69 c10 wont fire up
Is the distributor spinning?
Is the battery weak? Is the cap old and nasty? Cracked? Grounds for engine are good? Burned up rotor? For the heck of it, pour a little gas down the carb and see if it wants to start?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-12-2018, 09:26 PM | #3 |
Points & condenser or electronic ignition? Which electronic?
One plug has no spark or all of them? <-- Quite important! Turn it over in the dark to see if any wires are grounding out. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
01-12-2018, 09:36 PM | #4 |
i only have a month to get this done. ill check all for spark tomorrow. and im sure its just a delco remy cap and coil. nothing fancy.i put fuel in the carb ...nothing. cap is good grounds are good. its not burnt up.
01-12-2018, 10:04 PM | #5 |
If you are running an HEI should always keep a spare module around IMO. It is the component most likely to fail and easy enough to swap and test.
01-12-2018, 10:12 PM | #6 |
That's my guess too. Ignition module.
Easiest way to check spark is throw a timing light on a few of the wires.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
01-12-2018, 10:24 PM | #7 |
laying low
The module is the usual culprit and on occasion the pickup coil fails. In all of my years I have only had one pickup coil fail. Nephew said that was the problem with mine. I said nooooooo. Yup. It was. You have to disassemble the dist to replace it too.
01-12-2018, 10:49 PM | #8 |
Make sure battery has a full charge.
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
01-13-2018, 02:23 PM | #9 |
Skip White sells a brand new L6 HEI distributor complete for $68. Gives you a spare everything.
01-13-2018, 02:39 PM | #10 |
Msgt USAF Ret
See your replies in the electrical forum.
It isn't a good idea to post in more than one section about the same issue, it leads to confusion for forum members and besides it's against forum rules.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-14-2018, 11:41 PM | #11 |
oh sorry i didnt know that. just to let anyone know who has to deal with this ever.. the problem was the coil. like it is most of the time. also when i was removing the old one i noticed that the ground wire was in the wrong location. the coil is held on by four screws, ground wire is under one of them,under the coil is a metal strap that the one screw goes in. my truck is now running great again thanx for everything. again sorry for the posting in more then one fourm
01-15-2018, 01:49 AM | #12 |
Msgt USAF Ret
Darn I thought about the ground on the coil but you said that it had just quit running so the module seemed to be the culprit. You got a lot of good ideas anyhow.
