01-04-2019, 08:03 PM | #1 |
Driveshaft - lsx swap
Starting to think about driveshaft options
What are most people doing or if custom recommending ? 57 Chevy. 4l65e 8.8 Explorer Rear Stock 6.0
FAKKY 57 PANEL BUILD |
01-04-2019, 09:02 PM | #2 |
Re: Driveshaft - lsx swap
I went with a custom PST aluminum driveshaft. 4l80E to a Ford 9”. All 1350 series joints used. I abuse this thing so I upgraded.
01-04-2019, 09:25 PM | #3 |
Post Whore
dennys makes some nice one..not cheap though....https://www.dennysdriveshaft.com/
will depend a lot on hp/rpm...id recommend calling him to discuss your options alum will have to be a larger dia...so if space is a problem that may not be a good choice
01-04-2019, 09:38 PM | #4 |
Out of Clearwater FL ?
01-04-2019, 09:39 PM | #5 | |
300hp ...... etc
01-04-2019, 09:56 PM | #6 |
Post Whore
buddy of mine just bought a chrome-moly shaft with all billet yokes for his..450hp..around $850 from dennys...you probably don't need one that extreme
01-04-2019, 10:01 PM | #7 |
01-05-2019, 10:13 AM | #8 |
Bought mine from deneys for less than local shops wanted to do the one I had and gauianted I could not break it
01-05-2019, 02:15 PM | #9 |
thanks guys
Ill check out PST and Dennys. PST is close to me ... so that would be useful but not the first time Ive heard Dennys either ..... thinking I'll just go with like 2/2.5" DOM steel unless some reason not to.
01-05-2019, 03:20 PM | #10 |
Post Whore
Diameter is determined by hp/rpm/yoke size...call the denny..he'll tell you what you need...even if you use someone else it'd be worth talking to him...2/2.5in is way small for a rear shaft...
The one on mine is 3in...
01-08-2019, 02:53 PM | #11 |
I bought all the components from Dennys will cut and weld it myself and have it balanced locally.
01-08-2019, 03:18 PM | #12 |
Dang.
Would love to do that just because ...... But my welds are hit or miss or (tight space way too much stickout) or
01-08-2019, 03:29 PM | #13 |
You can buy the parts cut them to length and let a local shop weld and balance. The yokes fits inside the tube very snug they will stay put for mock up.
I do everything myself whenever possible because I don't trust over the phone measurements. When ever possible I mock up everything, even if I take it to someone for finishing I like to see it works. Last edited by BAM55; 01-08-2019 at 10:41 PM. |
01-08-2019, 08:06 PM | #14 | |
Brian
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-08-2019, 08:38 PM | #15 |
Not really a kit I ordered all components for about 150-160 bucks. If you order call Denny and tell him what you have to make sure you get the correct components. I also got my Transmission Slip Yoke from them but I deducted that from the price.
01-11-2019, 01:04 AM | #16 |
Thanks, good to know. I also need a tranny yoke.
