04-15-2018, 11:53 AM | #1 |
Need emissions help
Hello, have 1990 Silverado 1/2 ton, 2 wheei drive, 350 engine, extended cab.
Smog pump missing off this truck and won't pass inspection in my state, only requires safety inspection but if it came with pump has to have it on there. Willing to buy one but don't know if im missing what ever the pump connects to so i've been searching everywhere for a diagram of the emmissions system for my truck with no luck, have found a couple that supposedly are for my truck but it shows it with the air injection pipes that screw into the heads like the 80s model trucks and these models didn't have those, even my Chilton manual doesn't show mine. Does anyone have a diagram or know what the pump attaches to? 1988 to 1993 are the same, 1994 and newer are different. Thanks for any help. |
04-15-2018, 03:09 PM | #2 |
Re: Need emissions help
This is from a 1993 fuel & emissions manual.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 04-15-2018 at 03:26 PM. |
04-15-2018, 03:21 PM | #3 |
I edited my post to only have one photo at a time because with some browsers this site messes up multiple photo posts.
These are from the 1993 Fuel & Emissions Manual.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 04-15-2018 at 03:30 PM. |
04-15-2018, 03:32 PM | #4 |
Another from the 1993 manual.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
04-15-2018, 06:12 PM | #5 |
I don't understand this requirement. I have a Calif. truck and it never had an AIR pump. Calif. was typically the state that required equipment like AIR so I don't know why NC would need it. Do you have exhaust manifolds where someone put plugs in pipe holes or are they bare of those ports.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
04-15-2018, 07:37 PM | #6 | |
04-15-2018, 08:01 PM | #7 |
76r... Could you take a photo ( photos), of what that area of your engine looks like now?
EVERY truck after the '70's have an "air pump".. also called a smog pump. Your right side exhaust manifold should have connections for the attached plumbing, and there is a small pigtail / vacuum hose that will connect. Yellow - most of smog system. Orange - sensor pigtail / vacuum hose. Red arrow- Smog Pump.
'70 GTO Midnight Blue '88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany. '93 Cadillac STS Black '93 Mercedes SL 500 Teal '86 Yamaha FZ750 - 15,000 RPM '86 Yamaha FJ1200 - Criminally Fast 2016 Ferrari 488 GTB, I drive it - don't own it. '05 GMC Yukon XL , SLT 4wd ( just purchased 2018) Last edited by mountie; 04-15-2018 at 08:19 PM. Reason: add photo |
04-15-2018, 09:01 PM | #8 |
You may have misunderstood the point I was making. Calif. always had the strictest smog laws as a 50th state vs. everyone else that had 49-state vehicles everywhere else. Why would my Calif. truck not have AIR when an NC truck required it. Only difference might be that my truck originally came with a 305 and I later replaced it with a 350. Could that be it?
04-15-2018, 09:26 PM | #9 | |
" W/O A.I R.".... I am not sure what it meant. I assumed it meant A/C... maybe not. I can assume an off-road only truck did not require it by law? BUT,....In this decal, the serpentine belt seems to bypass the A/C compressor, unless no smog, has the A/C located lower on the engine? Hmmmm....
'70 GTO Midnight Blue '88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany. '93 Cadillac STS Black '93 Mercedes SL 500 Teal '86 Yamaha FZ750 - 15,000 RPM '86 Yamaha FJ1200 - Criminally Fast 2016 Ferrari 488 GTB, I drive it - don't own it. '05 GMC Yukon XL , SLT 4wd ( just purchased 2018) |
04-16-2018, 01:21 AM | #10 |
Here's a pic when I replaced this 350 with my spare in 2012. These are the stock brackets for an '89 with the AC comp right at the top. AIR pump would be mounted on the space below had it been optioned that way so you can see the AIR pump is in the dashed area of the pic on the shroud that was posted.
04-16-2018, 05:56 AM | #11 | ||
Op, can you snap a pic of your emissions label and post it? It may be on the fan shroud by the rad support or the air cleaner |
04-16-2018, 09:00 AM | #12 |
If 76r could post a picture, showing the lower passenger area... Then we can see what is missing - needed. ( Is the smog mount bracket there?)
04-16-2018, 10:09 AM | #13 | ||
There were more trucks made without air pumps than with. There is also a tube that goes around the back of the engine to supply fresh air to the left exhaust manifold. Quote:
OP, It will look like this. It will have a vacuum diagram. It may be black. |
04-16-2018, 12:09 PM | #14 |
This raises a question in my mind; is there a code in the option list that indicates the requirement for an AIR pump and related hardware?
04-16-2018, 01:34 PM | #15 |
The dealer should know by the VIN number? If the emissions decal on the fan shroud is missing...... that decal will show it clearly.
04-16-2018, 02:39 PM | #16 |
As a matter of fact I still have the original upper fan shroud off my truck. When my truck was still relatively new the 305 had a factory defect/ cracked engine block in the lifter valley. I checked the oil one day and there was chocolate jello under the oil filler cap. This was at 30K miles. So I take my truck to the dealer for warranty work and the dealer "mechanic" (I hesitate to use the term) said that they only authorized replacement of the short block and so they put the damaged heads on the new short block. This guy cross threaded some SAE bolts into metric threaded holes and other assorted nightmares along with breaking the upper fan shroud. I gave up with dealership mechanics at that point. I had problems with the work that was done and months later I went to the local Pontiac dealer and bought a 350 OTC and installed it into my truck at the curb outside my apt. at the time. Best thing I could do at the time. I know I got side-tracked here but ignore it if you will and refer to the pics I posted.
04-16-2018, 02:50 PM | #17 |
Mr Rich...
If your crappy engine repair was at a GM dealership, then you have a warranty ( if your original warranty / extended warranty is in effect).... If you return to any GM dealer due to their (GM) bad repairs, & they accept the truck - ( same complaint / second visit),..... Automatically, that repair is exempt from any time/ mileage limitations.
06-20-2018, 08:15 AM | #18 | |
I know this is a couple of months old, but that pic of your emissions label shows that your truck came from the factory without the air pump. It's not required to pass emissions. |
06-20-2018, 11:53 AM | #19 | |||
It's also pretty obvious that he didn't care to answer back in April so chances are good he's done with this thread. |
06-20-2018, 05:45 PM | #20 | |
Back in 1990, I had some serious warranty issues & spoke to GM in Michigan & wrangled the jerk-off "GM Rep" in So Cal. ( It had to do mainly with my defective transmission among other defects)
06-20-2018, 09:50 PM | #21 |
We probably lost the OP with all of our back-and-forth comments. And I still don't trust dealerships unless I work there and I'm not hired at any and so it goes. My old truck has almost 289K miles with just me as the mechanic for the last twenty-five or so years. I've replaced/ repaired everything in the drivetrain during that time. It doesn't look pretty but I still like that old truck; gray primer and all. The interior is in clean and very good condition. Amazing what a upholstery cleaning machine can do to freshen things up.
