04-24-2017, 05:03 PM | #1 |
Longer Front Brake Hoses
I have a 71 GMC K1500 that will have a 2.5" lift when the build is complete. Is anyone aware of someone or someplace that sells longer front brake hoses? My current hoses are approx. 19" long. To utilize the mounting hole in the frame side rail, it looks like the hose needs to be 3-6" longer. I'm trying to avoid using a non original method of securing the brake line(like a lift kit would have you do.) .... Long as I'm asking, anyone know of a longer shock that has a regular dust shield and not a dust boot? .... Except for the small lift, this truck will be 95% stock and I'm just trying to keep the brake hoses and shocks looking stock.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) |
04-24-2017, 06:45 PM | #2 |
Re: Longer Front Brake Hoses
Offroad Design make longer hoses in various lengths. The catalog states they are for '73 & newer but they have a note that the hoses will fit 71-72 if your front brake lines are 3/16". My 71 GMC K25 has 3/16" lines.
04-24-2017, 07:35 PM | #3 |
Not sure on the shocks. As far as brake lines, I wanted the stock looking black brake lines but ended up with some from skyjacker that I got from 4Wheel parts.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-24-2017, 10:19 PM | #4 |
offroad design has a dark brown outside cover skin that hides them good .
I have had them for years on a truck up here in the north east rust belt no problems. ditch the soft rubber hoses and go braided . firm pedal ! !
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-24-2017, 11:58 PM | #5 |
Lots of hydraulic hose shops can make custom length DOT hoses in rubber or braided. Call around those kind of shops aren't big on web sites.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-25-2017, 01:30 PM | #6 |
thats what i had done years ago when i lifted a old truck i had, just showed them the ends of the old rubber line and got braided stainless steel. little pricey though
04-25-2017, 02:21 PM | #7 |
ck out 1 ton vans late 70's they are about 22 or 23" long. rockauto has pics and lengths.
1961 chevy K10 my build is------------61K10 build |
04-25-2017, 02:57 PM | #8 |
You can put your own together for about half the cost of what the assembled ones run. Inline tube sells braided line in any length you want, I think I got 21". Added a proper size -an banjo fitting and an adapter to fit the brake line and I think they came out to about 30 bucks each. I run it through the factory hole in the frame.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
04-25-2017, 10:14 PM | #9 |
Thanks for the info and help.
