03-11-2017, 04:36 PM | #1 |
Paint Fuel Tanks?
Last week I painted the frame of my truck. This week I am going to be painting some smaller parts. I bought 2 new fuel tanks for the truck.
Seems like they have a oil type coating on them now. Thinking about wiping it off, cleaning them up with some degreaser and painting them with epoxy primer and black paint. Am I wasting my time or would this help with preventing rust more than the oil? I never see tanks being painted, so maybe there is a reason. Input is appreciated! Also - 2nd question - for the material that goes between the straps and tank - can a person use sound deadening material like fatmat there? Or bad idea? i just have some onhand and thought it may work. Last edited by Mattchu60; 03-11-2017 at 04:50 PM. |
03-11-2017, 04:42 PM | #2 |
Re: Paint Fuel Tanks?
I like to paint mine, gives them at least a fighting chance against rust.
03-11-2017, 07:46 PM | #3 |
I've never painted a tank.
Because I've never had one rust from the outside in.They always rust from the inside out. But,the paint will make it look good! Oh,and I use roofing felt on the straps. Mike. |
03-11-2017, 10:12 PM | #4 |
changed my tanks a few yrs ago, did'nt want 2 blobs of rust hanging off the truck....
03-12-2017, 08:30 AM | #5 |
I painted my tanks . I cleaned them and use krylon dull aluminum spray paint . They still look factory with protection . The spray paint actually has aluminum in it and weathers quite well . I painted mine just to keep the surface rust from showing up after my resto . The zink coating is not what it used to be on new tanks .
Also I used roofing felt as well . I would imagine you could use the fatmat with no problem . Its there for anti squeak and should protect the tank as well from the straps . |
03-12-2017, 12:01 PM | #6 |
Anyone used the poly replacement tanks? Ive got 1 probly 2 tsnks that the plastic rock guard trapped mud in and rusted the tanks and brackets. I saw a new tank in person and it was very thin walled.
03-12-2017, 12:55 PM | #7 |
Nothing at all wrong with poly. Pad the tank straps.
I used metal cause I had them. Cleaned, Rust converter where needed, Rust-Oleum primed. Rattle can bed lined. I used window roll flashing, the rubberized sticky stuff at Lowe's Depot, to put on top of the tank where water sits, and as a chip guard. It works OK for strap padding, but adds thickness and makes them hard to get around the tank. Inner tube is better. |
