Old 09-22-2018, 06:24 PM   #1
Can68GMC
68 Canadian GMC 920 4x4 Questions
Recently bought a very original Canadian GMC 3/4 4x4 - in really nice shape. Getting ready to pull the trigger on a resto and I’m struggling with a few things - truck has the original rebuilt 327, HD closed knuckle D44, HO52 rear with factory no spin, SM465 and T221.
There is something to be said in keeping the truck original, but I am seriously thinking of swapping out the frt diff for an open knuckle D44 with disc brakes and swapping out the 221 for a 205. Nothing really wrong with the original kit now, the 221 whines and it would be nice to have some stopping power in the old girl. These trucks are fairly rare (being the Canadian GMC), so would it make more sense for future value in trying to keep it as stock as possible? Or would the upgrades make it more valuable?
If I knew how to post pics, I would, it’s a great color combo with the off white exterior and red CST interior
Can68GMC is offline   Reply With Quote
Old 09-22-2018, 07:19 PM   #2
ratty69
Re: 68 Canadian GMC 920 4x4 Questions
Why not do the front axle swap, and keep the original? Then if you ever want to put it back to original, you can.
Not really sure what the transfer case swap would give you other than better parts availability.
ratty69 is offline   Reply With Quote
Old 09-22-2018, 07:44 PM   #3
mike16
if your 221 whines, its time to freshen it up with a bearing kit and seals. replacing the front axle is not as easy as you thing, disc breakes in the front will requir a new mc and perportioning gizmo and new lines and maybe new rear brakes and rebuilt wheel cylinders and on ward and so forth.
and since it is all origonal, canadean and rare and cheaper to maintain origonal rather than rat rod it.... better to pass on it and experiment with a turd. I'm bias and for a good reason
mike16 is offline   Reply With Quote
Old 09-22-2018, 09:18 PM   #4
ratty69
Originally Posted by mike16 View Post
if your 221 whines, its time to freshen it up with a bearing kit and seals. replacing the front axle is not as easy as you thing, disc breakes in the front will requir a new mc and perportioning gizmo and new lines and maybe new rear brakes and rebuilt wheel cylinders and on ward and so forth...
All true, but front disks would make it WAY safer to drive on today's roads. You can try to drive defensively all you want, then some bozo cuts you off and stands on the brakes. Sometimes they're on the phone, sometimes they're looking for an insurance payday. It's inevitable.
Locally, the insurance company allows upgrades like disks, leds, and seatbelts on collector vehicles that must be otherwise stock for just that reason - safety.
I guess the OP needs to decide whether he wants a perfect stock resto, or something he can actually drive with confidence. If he keeps all the original parts, and does nothing irreversible, no harm no foul.
Just one guy's opinion.
Old 09-23-2018, 12:35 AM   #5
YBNORML
YBNORML's Avatar
I don't know anything about the 4X4 stuff, but it is generally accepted that safety upgrades don't negatively effect a classic vehicles value. I could see it hurting the value if it was a low production rare vehicle or something like that. But these are just trucks, trucks that are meant to be driven and enjoyed. Safely.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-23-2018, 08:28 AM   #6
68panelman
68panelman's Avatar
In to see pictures. Unless the whine is obnoxiously loud, your probably just not used to the sound of straight cut gears. Not much available for them but seals and some bearings, but just as bomb proof as the NP205.
Me, I'd leave it alone, but it's your truck to play with.
68panelman is online now   Reply With Quote
Old 09-23-2018, 10:57 AM   #7
jocko
jocko's Avatar
Sounds like a nice stock truck and worthy of keeping it original. I do understand the desire to upgrade exactly the two things you're discussing though - they are good choices for upgrade. Having said that, a full resto on that truck's brake job will provide more than sufficient braking - but you are correct in disks being a safety upgrade. Keep in mind, that even though they were VERY sufficient in 68, now everyone else can stop much better than a set of drums or even power disks on a 72 D44 axle with disk brakes which have no anti-skid. So that's a plug for keeping a larger safe distance behind others than you do in a more modern car. If you think you'll need better brakes than the drum setup (i.e. do you drive in a lot of traffic or notsomuch - or lots of rain?), then it's worthwhile and I would hang onto the original axle if you can store it. It kind of sucks to feel like you have to hang onto a giant chunk of metal you may never use just because it's original... and if space is tight, that makes it even harder. NP205 is about the best transfer case ever put in these trucks, but it's worth finding who on here has done the swap to know all the hiccups it will incur. Not sure about what possible crossmember issues, if any, etc etc.
Personally, unless you're often in a bunch of traffic or drive in a lot of rain, I'd restore it to stock. No wrong answer though, your thoughts on what to do to this truck are good ideas. I'd struggle with this decision personally - I like to keep em stock, but I like the original stuff (so I bought a 72 )
Would love to see some pics of it when you get a chance! And welcome to the forum!
Old 09-23-2018, 11:05 AM   #8
jocko
jocko's Avatar
BTW, here's some info on the transfer case swap:
http://67-72chevytrucks.com/vboard/s...d.php?t=710717
http://67-72chevytrucks.com/vboard/s...d.php?t=706152
http://67-72chevytrucks.com/vboard/s...ad.php?t=61494
http://67-72chevytrucks.com/vboard/s...d.php?t=494017
http://67-72chevytrucks.com/vboard/s...ad.php?t=99838
http://67-72chevytrucks.com/vboard/s...d.php?t=304242
http://67-72chevytrucks.com/vboard/s...d.php?t=323994
Old 09-23-2018, 01:48 PM   #9
B. W.
B. W.'s Avatar
I see both sides, I've kept a truck in stock form & I've upgraded to disc brakes.
Stock drums, in good condition & properly adjusted do a good job ( still like discs on the front)
I've run trucks as DD's for years with front drums & never had any "white knuckle" moments (that I remember!)
As far as the t-case, I'd keep the 221, it's a tough case, just difficult to get hard parts for. I ran a Dana 18 in a jeep truck that's kinda similar in design (they both have offset rear output shafts). It wined at 70 even after a rebuild. I switched to synthetic gear lube & it seamed quieter?! & ran cooler.
I'm inclined to keep an old truck all original.
B. W. is offline   Reply With Quote
Old 09-23-2018, 02:45 PM   #10
HO455
HO455's Avatar
Welcome aboard! It sounds like a great truck. Low production numbers for those early K models especially GMC. That may or may not sway your opinion. Here is a link and discussion about production numbers and if you follow the link in the thread a list of Chevy numbers by year and model.
http://67-72chevytrucks.com/vboard/s...d.php?t=664273
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 09-23-2018, 03:46 PM   #11
mike16
the whole disc is safer bs is just that.
dont justify ruining a nice origonal truck because others are un safe.
I never had a problem with drums. I dont carry a heavy load any more so they are even more than "more than enough". try if you must to drive defensively around other idiots rather than rat rod a truck. No excuses. its your truck do what you want with it but dont ruin it and blame others
another guys opinion
Old 09-23-2018, 04:13 PM   #12
Can68GMC
Quick pic
Old 09-23-2018, 04:16 PM   #13
jocko
jocko's Avatar
here's a flip for ya - SHARP truck!
Old 09-23-2018, 04:41 PM   #14
1972RedNeck
1972RedNeck's Avatar
As long as you keep your drums in good shape and well adjusted, they will have MORE power for a quick stop than discs - if you need to use the brakes for an extended period (going down hill) , then discs are better as they don't fade as quickly.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-23-2018, 04:42 PM   #15
Can68GMC
A few more pics...
I know these 221’s are noisy animals, I wasn’t able to find a bearing kit locally, but may have a lead on one so I’ll probably go that route first before I swap it out. I’m not a big fan of the closed knuckle 44’s, having a hard time finding new wiper seals for it, and I heard brake parts are hard to come by these days.
I was searching for a clean 71/72 when I came across this ‘68, it was just so clean and unmolested I couldn’t walk away from it.
Thanks to all for your opinions, I really think I should try and keep this truck as close to factory as possible
Old 09-23-2018, 05:01 PM   #16
Coley
Coley's Avatar
Smile Re: 68 Canadian GMC 920 4x4 Questions
That is a way cool and very rare truck...great find and great to know that they are still out there!!
If you can solve it out in stock form it will be well worth your while in keeping its value high and its driveability acceptable.
If you modify it for modern equivalent driveability reasons....a truck in that 'great original starter' condition will probably depreciate in my opinion.
If it was in poor shape or a 4wd basket case (and many are)...then doing modern change up is probably the way to go.
Either way, very nice truck!!
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-23-2018, 09:27 PM   #17
1972RedNeck
A few more pics...
https://torqueking.com/product/40188...4-front-axles/
Light duty?
https://torqueking.com/product/4936/...0-front-axles/
Or heavy duty?
Put new wipers on and fill the knuckles with corn head grease for many more years of leak free service.
Whoever told you that parts were hard to come by was just another typical drum brake, closed knuckle hater.
Outside of the axle housing and knuckles themselves, all of the parts for them are readily available, brand new.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 09-24-2018, 08:07 AM   #18
68panelman
68panelman's Avatar
There you go! Redneck has the knuckle solution.
Find a brake rebuilder that also re-lines shoes and be done.
That truck is worth it, she's beautiful. More pics and info on the spid please
Old 09-24-2018, 12:07 PM   #19
chewychevy67
I saw that truck on Kijiji for a while and contemplated it a few times. It looks really nice and not messed with. Congrats on your purchase.
chewychevy67 is online now   Reply With Quote
Old 09-24-2018, 12:19 PM   #20
Can68GMC
Yeah that was me, after I bought it I thought it was just to clean and original
To start modifying it, so I listed it for awhile. I’ve pretty much decided to go the whole resto route with it now, so I dropped the add
Old 09-24-2018, 12:27 PM   #21
chewychevy67
I was looking for a 3/4ton 4wd for myself but my wife wanted me to get something newer so the boys could all come with me otherwise I would have sent you a message. I agree with you on being too clean to mess with it. But as long as you do it right you won't devalue it.
Old 09-24-2018, 01:28 PM   #22
HO455
HO455's Avatar
Great looking truck! I'm glad to hear you're going to keep such a nice survivor intact.
I know that a lot of the drum brake hating started in the years after asbestos was banned. The original shoes were designed to use asbestos linings. After asbestos was banned the replacement lining materials worked OK at best. After years of issues newer material has been formulated that provides stopping power equal to or better than the original linings.
There was a crane at work we had to scrap in the 80's due to the new friction materials for the drum brakes on the winches could not be made to do the job safely. It was a real shame it was low hours and only 10 years old. But nobody wanted it and the market was flooded with similar cranes with the same issue.
The point of the whole story is there are different lining materials available today and it may take some experimenting but you can get very good brakes on a drum set up. (As long as you stay within there operating limits. I.e. heavy loads on steep long hills should be avoided). All of our trucks in this day and age of computer controlled ABS braking systems are really substandard. It would be nice if the aftermarket would come up with an ABS set up for us.
Once again great truck and I really dig the color scheme!
RIP Bob Parks.
Old 09-26-2018, 01:08 PM   #23
Joesjunk
Joesjunk's Avatar
Nice truck 👍🏻. That’s a great survivor. Is the black roof factory? Would love to see the spid on this truck. I would keep it all original and just enjoy it
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 09-26-2018, 02:53 PM   #24
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Very nice truck.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 09-27-2018, 09:26 AM   #25
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice lookin' truck! Dig the roof lights. Yeah, an SPID pic would be welcome.
~Steven
Simi Valley, CA
