Old 06-07-2018, 09:25 PM   #1
Bandit130
Bandit130's Avatar
Accelerator Cable Replacement
Planning to replace my accelerator cable soon. Wondering if anyone has any special instructions or tricks? My first cable replacement, and appears to be fairly simple.
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 06-07-2018, 09:44 PM   #2
87Flh
87Flh's Avatar
Re: Accelerator Cable Replacement
I did this a few months ago, I had the Mr Gasket universal one. It lasted about 6 months before the plastic bushing on the pedal end broke.
If possible, find one with a steel or aluminum bushing. Or take the plastic one to a machine shop and have one made to match.
I replaced it with a stock style cable that was too long and I had to cut it to the right length. I cut it on the carb end and used the end from the Mr Gasket cable in its place. Works great now.
87Flh is offline   Reply With Quote
Old 06-08-2018, 07:37 AM   #3
Bandit130
Bandit130's Avatar
[QUOTE=87Flh;8277043]I did this a few months ago, I had the Mr Gasket universal one. It lasted about 6 months before the plastic bushing on the pedal end broke.
I'm not familiar with the bushing you refer to. Can you describe more?
Mopar by Birth
Chevy by Choice
Old 06-08-2018, 07:40 PM   #4
87Flh
87Flh's Avatar
its the round black part that clips into the pedal linkage, most of them are plastic and can get brittle over time.
Its on the left side of the picture.
https://www.oreillyauto.com/detail/b...ckup-rwd?pos=0
Old 06-08-2018, 07:41 PM   #5
87Flh
87Flh's Avatar
Then again, yours might be totally different than mine. If so disregard everything I said, lol.
Old 06-08-2018, 08:01 PM   #6
69heavychevy
69heavychevy's Avatar
The issue I had was the parts store one was way too long. It would bind up. Luckily I was able to find a decent one at the junkyard.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 06-10-2018, 05:30 PM   #7
Bandit130
Bandit130's Avatar
Received new cable. It has the plastic piece you described. My current one also has plastic which I believe is the factory original. Also, do not know what the blue plastic piece is. It slides on the cable housing. Looked at my current one and it does not have anything like that.
Mopar by Birth
Chevy by Choice
Old 06-11-2018, 07:38 PM   #8
87Flh
87Flh's Avatar
Not sure what that is for. I dont recall mine having that. Probably passes through some support bracket that was removed in the past. Looks like you got what you need though.
