Old 04-22-2018, 07:11 PM   #1
Gregski
Gregski's Avatar
HA - A Spill Free Fill Up!
anyone who's got a Square Body can attest to their temperamental fueling up issues, and I've dropped the tank and went through every inch of the piping to ensure nothing is obstructing justice here, lol its just the nature of the beast... but every once in a while when the sun is just at the right position in the sky and the cute cashier gives you that smile and doesn't call you Sir, (caue hewk you aint that old)... it can happen - you can fill up your tank without spilling a drop, whaa haa ha
Note: I use the Gangsta Technique when filling up by holding the nozzle flat parallel to the ground, like bad guys do with their glocks, jk
Gregski is offline   Reply With Quote
Old 04-22-2018, 09:11 PM   #2
v30crewcab
v30crewcab's Avatar
Re: HA - A Spill Free Fill Up!
must not be all the way full then!
on my diesel, I have to start pumping at a slow trickle, until I get most of a gallon in it, then I can start pumping full speed and don't have any issues. but I can't just throttle it out of the gate or it pukes everywhere.
88 military v30 crewcab shortbed
5.9 cummins, nv4500, 205
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-23-2018, 03:08 PM   #3
68longhorn
68longhorn's Avatar
I've never once had an issue. My 86swb has been my daily since 2008 and the last 100k miles. Is your charcoal canister plugged? Take the lines off of it and try it
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 04-23-2018, 03:53 PM   #4
tucsonjwt
I have had 3 squares: 73,76, 83 and all had the same problem. The gangsta method works for me also.
The problem started when the EPA compliant gas pump nozzles had that wire wrapped around the outside of the nozzle and the length of the nozzle was shortened. Occasionally, I find an old style longer nozzle without the wire and those fill fine without any sideways tricks.
tucsonjwt is offline   Reply With Quote
Old 04-24-2018, 06:09 AM   #5
68longhorn
68longhorn's Avatar
I did some research on this and I see you have those stupid California nozzles. I read that not inserting the nozzle all the way in can help. Another thing you can do is install a filler neck from a diesel, apparently the larger diameter filler helps this
Old 04-24-2018, 07:43 AM   #6
cadillac_al
The vent either works or it doesn't. I have one truck that takes the gas very slow. Luckily my daily driver can drink it as fast as I put it in.
76 Chevy K20
76 GMC K15
77 Chevy C10
cadillac_al is offline   Reply With Quote
Old 04-24-2018, 08:23 AM   #7
jkk
jkk's Avatar
I hold just inside the lip of the filler and it goes in fine
jkk is online now   Reply With Quote
Old 04-24-2018, 08:52 AM   #8
Dead Parrot
We still have the older style fill nozzles here in OK. Have found that any nose down slope you can get helps.
Dead Parrot is offline   Reply With Quote
Old 06-10-2018, 11:37 AM   #9
Gregski
Gregski's Avatar
that is a good tip, thank you, I will give it a go
Old 06-10-2018, 11:38 AM   #10
Gregski
Gregski's Avatar
thanks for the tip, the charcoal canister has been deleted three years ago and when I did it I realized that the charcoal canister does not have a bottom so by design it is opened, so I don't get how it would clog / effect the fillup anyway
Old 06-10-2018, 11:39 AM   #11
Gregski
Gregski's Avatar
Thank you my brotha and here I was thinking I was the only crazy one, Ha ha
Old 06-10-2018, 11:41 AM   #12
Gregski
Gregski's Avatar
this is what it normally looks like, on a good day, ha ha, I ain't complainin' I'm just sharing if any others are scratching their heads on this one, especially my fellow Californians (the least car friendly state in the Union)
Old 06-10-2018, 12:43 PM   #13
68longhorn
68longhorn's Avatar
IIm not sure on squares but numerous new cars can have a clogged canister causing overflows or clicking off.
Old 06-10-2018, 10:51 PM   #14
abig84
abig84's Avatar
Maybe it's only on the older trucks. I've owned a 84,85,86, and 82 and never had a spilage issue mostly just the pump shutting off. On the military trucks the opening is like 3 inches so you have to hold the nozzle the whole time or it will fall out
abig84 is offline   Reply With Quote
Old 06-13-2018, 05:36 PM   #15
hatzie
hatzie's Avatar
The 73-77 straight out fill neck is not friendly. 78-91 with the doors and a little more height is easier but they still occasionally barf fuel out.
1959 M35A2 LDT465-1D
1967 Dodge W200 B383, NP420/NP201
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-14-2018, 08:13 AM   #16
cadillac_al
I see we are talking about the new fangled gas pumps with the goofy rubber boot around it. I am fortunate not to have to deal with those any more. They used to have them in NH but I haven't seen them for a while. Maine never fell for that craze.
76 Chevy K20
76 GMC K15
77 Chevy C10
Old 06-14-2018, 09:30 AM   #17
Gregski
Gregski's Avatar
there he is, long time no hear
Old 06-14-2018, 09:31 AM   #18
Gregski
Gregski's Avatar
oh great another Kalifornian invention, I swear I like this state less and less every year
Old 06-14-2018, 09:51 AM   #19
SunSoaked
SunSoaked's Avatar
According to today's news, you might have 3 California states in November! Can't imagine that the philosophy of " if 1 is good then ...is better" applies in this case?
SunSoaked is offline   Reply With Quote
Old 06-15-2018, 06:09 AM   #20
Wgesnerjr
Wgesnerjr's Avatar
this article has some good diagrams in it. adding this to show there is a filter in the bottom of the charcoal canister that may be clogged and needing replacement. just google "charcoal canister filter" for a new one. think they were the same across the GM lines.
otherwise the article, although informative, gets a little b!#@hy.
https://oppositelock.kinja.com/dont-...ank-1702676878
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
