View Poll Results: How about a poll
Scrap it (too far gone) 33 86.84%
Fix it (it is the original cab) 5 13.16%
Voters: 38. You may not vote on this poll
Old 06-13-2018, 08:22 AM   #1
oldhokie
When to write off a cab
Slowly digging into my 71 c10. Here are a few pics of the cab. Looking for thoughts here, is this worth saving?
Passenger floor and rocker.
1971 C10 shortbed project. I need lots of help.
oldhokie is offline   Reply With Quote
Old 06-13-2018, 08:24 AM   #2
oldhokie
Re: When to write off a cab
Drivers floor and rocker.
Old 06-13-2018, 08:25 AM   #3
oldhokie
Drivers side roof drop rail area.
Old 06-13-2018, 08:37 AM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
When to write off a cab...
Now would be a good time on this one. The roof is a deal breaker plus I'm sure it gets worse the more you dig.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 06-13-2018, 09:15 AM   #5
CSHADES
CSHADES's Avatar
I usually go by the assumption that there is 3 times as much rust as what you can see. I have fixed a lot of crusty vehicles and if that were mine I would look for a better cab.
CSHADES is offline   Reply With Quote
Old 06-13-2018, 09:29 AM   #6
oldhokie
Decided to have a little fun with this. Added a poll. Keep the opinions coming and vote.
I am in no way bound by the vote! Iím not completely crazy!
Old 06-13-2018, 09:38 AM   #7
Grumpy old man
Grumpy old man's Avatar
It's only metal , if you have the tools,skill and time you fix it if not you pressure wash it once dry you fog it and bag it and stash it away in a dry spot and someone down the road will consider it gold ! cut up and sold as repair pieces it's worth more than some replacement cabs and since you can buy special rivits on Ebay ...
Grumpy old man is online now   Reply With Quote
Old 06-13-2018, 11:29 AM   #8
3drburb
3drburb's Avatar
Now!!
Roof is the killer. Usually it's rust from the ground up but this one looks to only have a little good metal in the middle.
Best wishes on the project.
3drburb is offline   Reply With Quote
Old 06-13-2018, 11:41 AM   #9
oldhokie
Good news here is I only paid $900 for it. So expectations were low.
Old 06-13-2018, 03:18 PM   #10
Paul72
Paul72's Avatar
I've been known to put too much effort into a 'lost cause' cab, but hen again, I'm an eternal optimist!
'72 Chevy K20 - 383/4sp/205 - finished!
Next project - 72 Blazer on a 99 Tahoe chassis
Have the Tahoe, need the 72 Blazer
Paul72 is offline   Reply With Quote
Old 06-13-2018, 03:32 PM   #11
clay68c10
clay68c10's Avatar
Originally Posted by Grumpy old man View Post
...pressure wash it once dry you fog it and bag it and stash it away in a dry spot and someone down the road will consider it gold ! cut up and sold as repair pieces it's worth more than some replacement cabs and since you can buy special rivits on Ebay ...
If you have a place to stash it, definitely.
For your own build, I'd find another without the roof rot.
68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17.
68 Cadillac Sedan de Ville
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
02 E320
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-13-2018, 03:55 PM   #12
cypressbog
Go Pack Go!
Scrap it
1968 Chevy C-30 Stepside: FOR SALE
cypressbog is offline   Reply With Quote
Old 06-13-2018, 04:12 PM   #13
35boulder
Find another. Gonna be a lot of $$$ and or time fixing that one. Good luck!
35boulder is offline   Reply With Quote
Old 06-13-2018, 07:25 PM   #14
franken
Brothers says 550 and 300 for a floor (w/ brace) and roof. But if you bought the cab, it most likely has a VIN you don't have a title for, so if the VIN isn't an issue, I'd say get another.
Around here, There are typically at least one of these trucks in each of the pick a part yards for cheap ($165).
Old 06-13-2018, 09:11 PM   #15
rjs53
He'll yea brother, I'm with ya there. The floor looks better than mine, your roof could use some work but I would try to fix it. I look at it like this, I can sit on the couch and watch TV or look at this computer or I can go out and work on my project. If my times all I got in it, and I can learn something like body work then I'll do it. But then again I'm cheap, so if I were into it $900 then I would fix it. You get another for more and will still end up repairing something. What's the worst that could happen it doesn't work and you part it out
2003 Dodge 2500
1969 C10
2014 Camaro SS 1LE
rjs53 is offline   Reply With Quote
Old 06-14-2018, 05:51 AM   #16
oldhokie
Let me clarify. I have $900 in the whole truck. Itís a running 71 shortbed, has a late model bed (that will go away) ps, pb, ac (non original).
Old 06-14-2018, 07:06 AM   #17
BRL
BRL's Avatar
...well let's see...spend a fortune on an original rotting cab...bet your friends will be impressed with all the time and money you put into the original...(you'll just have to show them where that stupid VIN cab number is)...
...or you can find a pretty decent non-original with little to no rust, that needs some paint or something.
BTW oldhokie, good deal for $900.
BRL is offline   Reply With Quote
Old 06-14-2018, 07:13 AM   #18
Grumpy old man
Or just buy the parts ?
https://orlando.craigslist.org/pts/d...582406127.html
Old 06-14-2018, 07:50 AM   #19
ilikethewoods
ilikethewoods's Avatar
Time and patience is the key. Hell, they make replacement floors for a reason. Just my 2cents.
ilikethewoods is offline   Reply With Quote
Old 06-14-2018, 09:57 AM   #20
oldhokie
Thanks for all the replies. Here is what I am thinking.
I have plenty of time, and this was always going to be a slow process for me, so I will pull the cab, focus on cleaning up the frame, replacing the lines, etc.
I will tear into the cab a little more to see how much more there is, and keep looking for a better cab. If I can’t find a suitable cab then when the time comes to reinstall I will start working on this cab.
Old 06-14-2018, 12:43 PM   #21
Overdriven
For $900 the truck was worth it and I would’ve bought it too. But I’ve had to deal with roof rust before and it wasn’t fun. 70 Dodge Dart the vinyl top rusted holes in the roof above the A pillars. I’m sure the A pillars were rusty because inside the door hinge area was rotting where it met the rocker. Pull the roof and have a look, if what you see doesn’t scare you off then fix it.
Overdriven is offline   Reply With Quote
Old 06-14-2018, 01:30 PM   #22
adricar1
i would repair it , another cab as an option over here is out the question, its much better than the one i had to deal with
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 06-14-2018, 06:24 PM   #23
franken
If the VIN on the cab matches the title and rest of the truck I'd lean toward fixing it. Swapping VINs is still illegal at the federal level.
Old 06-14-2018, 06:54 PM   #24
I skimmed right past the floor and rocker pictures till I saw the roof. I would not be interested in that cab for anything real nice for myself. But... I would not scrap it. I can think of many uses with one being repaired to be used on an old truck it doesn't really matter on. I mean, you can just drive these things. You can actually go haul a bunch of stuff with them. They don't have to be magazine quality.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
special-K is online now   Reply With Quote
Old 06-14-2018, 08:46 PM   #25
toolboxchev
Magazine quality hehehe!
Anyone can Chrome Plate a turd! but it won't get ya home. My truck has been hit 5 times in the last 12 years it's got 2 notches under it's belt now.
When I purchased it all the good body panels went into storage.
toolboxchev is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
