Old 04-05-2014, 11:31 AM   #1
Nitis
Nitis's Avatar
Which engine did you swap to and why?
As stated in my newbie thread I recently got a 72 k10. The tranny is brand new not sure if it's a turbo 350 or 400. But the engine is tired.
I don't need to go fast just want something reliable. My first thought was a tbi 5.7 as we have some history with those engines and how they work. But finding a god low mileage donor is next to impossible these days
I like the idea of the 6.0 motors as there are probably tons of them available but how much more complicated are they to swap? Also I don't want to go back to 8mpg. I know I'm not building a commuter but I want to be able to afford to drive it somewhere. And we all know the 6.0 engines are power houses but they are thirsty too.
I'm open to suggestion. I would love to do a cummins swap but this isn't the right truck for that plus dad said no not on this truck.
Nitis is offline   Reply With Quote
Old 04-05-2014, 11:32 AM   #2
Nitis
Nitis's Avatar
Re: Which engine did you swap to and why?
What did you use and why?
Old 04-05-2014, 11:48 AM   #3
In The Ten Ring
Just to keep this thread going....I did not swap...I still have the original I6. Everyone seems to go with 350 Crate or 383 Stoker. If I needed to swap, I'd go for a 292 I6 and if I had a V8 truck or needed a V8, I'd want a 283 or 327, even thoughboth seem rare to find. I like things original and I'm not a street rod type. If I were you, I'd go back as close to original as possible. Can the engine be rebulit? These 350 Crate engines (sorry guys, "motors" are electric) seem to be the way to go on a budget. Would you get better gas mileage with a small block?
In The Ten Ring is offline   Reply With Quote
Old 04-05-2014, 11:52 AM   #4
Nitis
Nitis's Avatar
Nothing wrong with that either all a matter of personal preference and what one wants for an end result.
Old 04-05-2014, 12:16 PM   #5
low&slow
My post managed somehow to get posted in your other thread
low&slow is offline   Reply With Quote
Old 04-05-2014, 09:59 PM   #6
Don't need to swap to get reliable. These trucks are great,first,because of their great reliability. There isn't a part on these trucks that isn't worth rebuilding or replacing with the same part new. I've had my '72 w/350 since '01 and all I do is drive it. I've had to do very few repairs along the way. I swapped the 350 from another '72 I had that I bought in '91 that was sitting waiting for restoration. That motor ran fantastic and was going to waste just sitting,so I swapped it in and put the other on ice. That engine was supposed to be rebuilt when I bought the truck in '91 and it still runs strong. I adjusted the carb (maybe) when I did the swap in '04 but other than that I have never touched it and it still runs great and gives me 12.5 mpg in a 3/4t 4wd automatic.
Check your compression. If it's not so great then you would want to rebuilt it or swap. But,it could just need a major tune-up. You can get a crate 350 from Jegs for about the cost of a rebuild or the sky is the limit
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
special-K is online now   Reply With Quote
Old 04-05-2014, 10:31 PM   #7
abraham.hd
I purchased a 5.3 complete with all accessories for 1000 bucks
abraham.hd is offline   Reply With Quote
Old 04-06-2014, 01:53 AM   #8
Willys47
Willys47's Avatar
I changed from a inline 6 to a big block. why because when I was at the age of 16 I got to drive a buds fathers 68 GMC with a 396 and WoW was that fun, the tork of that thing made me want that feeling some more
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-06-2014, 07:17 AM   #9
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
I went big block because I found found one that was $200 cheaper than a 350 and had a lot less miles. Much more fun to drive too.
FRANKENSTEINC10 is offline   Reply With Quote
Old 04-06-2014, 08:11 AM   #10
Lattimer
Lattimer's Avatar
My truck was a 6-cylinder, but a PO had swapped in a 327. After much trial and error I discovered some internal issues with the 327. So I bought a crate 350, but I went for a performance engine.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 04-06-2014, 02:53 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
My 5.3 was $200, its nice having a quick, relaible truck that gets 17mg. They don't look that good but that's what the hood is for.
4.8s make good power also.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-06-2014, 07:11 PM   #12
K10 STEPSIDE
K10 STEPSIDE's Avatar
The 5.3s are great. good mileage, power, etc.
but it isn't as easy as swapping in an older engine.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 04-06-2014, 07:31 PM   #13
1972RedNeck
1972RedNeck's Avatar
I presume that when you were talking about a Cummins swap, you were referring to a 6BT. You should look into a 4BT. They can be found with Chevy adapter plates and motor mounts that will bolt right in place of your current engine.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 04-06-2014, 07:33 PM   #14
Nitis
Nitis's Avatar
No I was totally thinking 4bt. Maybe on a future build do a two wheel manual trams runner
Old 04-06-2014, 07:39 PM   #15
TwinsSpeedShop
I use LS motors. The are reliable, basically indestructible and make good power. For the money of rebuilding a SBC you can get fuel injection, overdrive, and good mpg's. Now I do all of my work myself, so thats why I say for the "same" money. IF you are going to have to pay someone to do either, you might want to get quotes on both to weigh your options. Don't be scared of the wiring, there is so much information on the internet and this sight that can help you that its a no brainer if you have some mechanical skills. As for the TBI motors, ive done a few of those as well and to me the LS swaps are easier especially on the wiring side. Check out lt1swap.com for information on the wiring of the LS motors, tons of information on his site.
My truck is a 70 SWB with 03 5.3/4l60e and Im getting between 18-20 commuting to work and driving around town. I have not made any long road trips to I do not know the hwy mileage. My brothers is a 6.0/4l80 LWB and he gets 12-13 in town and 17 on the hwy. The power is is great if thats what your after but the mileage will suffer.
TwinsSpeedShop is offline   Reply With Quote
Old 04-06-2014, 07:43 PM   #16
myyamr7
myyamr7's Avatar
I went from a 350 (wasn't original motor, but it did come with a 350) to a 402 big block. No real justified reason, other than I wanted one. The 350 ran awesome, but I needed to pull it out and re gasket it anyways. The big block is fun, way more torque and pulls the truck around better with the overdrive trans.
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 04-06-2014, 08:18 PM   #17
Schmoldt
LS1, Easy modifications, fast, great mpg 20-25 Plus, great power, light. Check out ls1tech those guys know their stuff!
Schmoldt is offline   Reply With Quote
Old 04-07-2014, 04:15 PM   #18
FstCarsNGuitars
FstCarsNGuitars's Avatar
In my '68 I went with a 454 / TH400, because the project i picked up had no engine and I've always wanted a big bock Chevy swb truck. I picked up the motor and tranny for $600 and they both run awesome.
FstCarsNGuitars is offline   Reply With Quote
Old 04-07-2014, 04:23 PM   #19
Nitis
Nitis's Avatar
I am really leaning towards doing the LS swap. I found a guy on here I actually know who lives in my town who has done one so that's somewhat comforting. Now it's just a matter of time and money! And finding the right donor.
Pretty sure I want to do the 6.0 so hopefully I can find one of those. But if the right 5.3 fell in my lap I'd jump
Old 04-07-2014, 05:10 PM   #20
Z10
Z10's Avatar
I built mine as a driver and wanted drivability & dependability. Started with a new ZZ4 and then added a FIRST TPI system. The engine is still new but is returning about 16mpg on the highway.
I considered a LS engine, but have always liked the look of the TPI. With the FIRST I get the look and the ability to support up to 600hp. Check out my build thread in my signature for more info and pics.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 06-13-2018, 11:05 PM   #21
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Bump
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 Service truck build:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-14-2018, 06:12 AM   #22
BRL
BRL's Avatar
Yanked out a 250-6 for a 355 V-8.
TRW fordged flattops, fulie heads,...blah...blah......blah.
Love the sound of a lightly loping cammed Small Block, going through non-leaking headers, (with a crossover) into QUIET, but free flowing Hemi mufflers...
WITH THE FLIPPIN" STEREO BLASTING ROCK & ROLL!!!
YAHOO!
...100 bolted in extra cubic inches and a whole lot more bottom end torque doesn't hurt anything either ya know.
EDIT:...oh, forgot to add the mandatory truck picture for no reason...
BRL is offline   Reply With Quote
Old 06-14-2018, 08:56 AM   #23
Grumpy old man
Grumpy old man's Avatar
I had the original 250 6 I was going to use in the 67 cleaned resealed ready , than came across a great deal on a 350 4 bolt recent rebuild for $300. sold the 6 to a local guy for his 63 for $350. cleaned resealed the 350 after adding a V8 manual cross member , Things change fast ...Old school is still cool
Grumpy old man is online now   Reply With Quote
Old 06-14-2018, 08:59 AM   #24
Rich69shortfleet
I swapped out a tired wheezy 307 for a 400 small block. Why? More torque and power with a package that would (mostly) fit in with the same brackets and such as the previous small block. At the time I wanted to upgrade to a big block but the added cost of the engine itself (got the sb400 for $150) and all new brackets, etc. put it well out of my then budget. If I had it to do again now I'd seriously consider an LS.
The 400 has run like a champ once I got it to run cool, but it is definitely a truck motor (came out of a mid-1970s Blazer) and while it has nice torque down low, it has no top end at all being all done by 4500 RPMs. While this is more than adequate for a truck, it would be fun to have more of a hot rod engine. I went REALLY conservative on the cam when I rebuilt it, I'd make a somewhat different choice now. A set of heads and a different cam would be fun.
Rich69shortfleet is offline   Reply With Quote
Old 06-16-2018, 04:07 PM   #25
old51sedan
old51sedan's Avatar
Grumpy,
I bet you didn't leave that compressor bracket on there, do you have anymore of those laying around?
old51sedan is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
