Old 05-22-2018, 08:28 PM   #1
SoCalSlaughter
SoCalSlaughter's Avatar
Intake Manifold gasket question
So I have a 1990 Suburban v2500 5.7. The truck sits alot. I took the truck out to get its smog taken care of. The next day I noticed some oil dripping on the ground. I popped the hood and saw the front of the intake manifold was leaking some oil. While I had the hood open, I checked the oil level and noticed a small amount of milkshake on the end of the dip stick. I thought.. great head gasket time. Once I got the truck home I removed the oil fill cap and there was no sign of milkshake. With the truck running there was no bubbles in coolant. Removed all spark plugs and none where fouled or irregular from one another. I removed the intake manifold (Edlebrock performer), removed the thermostat and noticed it was a 190. I live in Southern Cali, seemed abit weird to have such a high temp. And noticed the intake manifold gaskets had the rear coolant ports blocked with the alittle metal block plate. But the intake manifold has the rear cooling passage. Im thinking the cooling system built up to much pressure and blew the gasket causing some coolant to get into the crank. Also, when removing breather hose from valve cover to TBI, the hose has some milkshake inside of it, just a film of it. The truck doesnt put out white smoke while it runs, it just passed it smog with flying colors, no miss at idle or anything
1990 Chevy Suburban v2500
1990 Chevy/Geo Tracker LSi 4x4
1991 Nissan 300zx SlickTop
1996 Chevy Silverado c1500
2011 Chevy Silverado LT
SoCalSlaughter is offline   Reply With Quote
Old 05-22-2018, 10:27 PM   #2
Dead Parrot
Re: Intake Manifold gasket question
When driven, short trips or long? Could be just normal blow by moisture not having a chance to evaporate. Double check the PCV system as that is what is supposed to remove blow by bad stuff.
Dead Parrot is offline   Reply With Quote
Old 05-23-2018, 12:33 AM   #3
SoCalSlaughter
Usually its short trips, takes me 15 min to get to work, usually leave around 6:30am. Also, about a year ago I moved close to the beach, less than a mile away, So Im sure that doesn't help. But I didnt think moisture would accumulate like that, none of my other vehicles show this.
Old 05-23-2018, 08:56 AM   #4
geezer#99
geezer#99's Avatar
Where did you get an intake with a rear cooling passage?
I’ve never seen one on a sbc
190 thermostat is about perfect too..
Old 05-23-2018, 10:35 AM   #5
toolboxchev
I am wondering the same thing about the intake manifold. Is it stock? I am looking for a manifold for a 1988 L98 Camaro Motor.
toolboxchev is offline   Reply With Quote
Old 05-23-2018, 01:56 PM   #6
95 S_Trucker
95 S_Trucker's Avatar
Some of the TBI engines have a heater hose attached to the rear of the intake manifold. That would explain the coolant passage.
-99 K2500 LS CCSB 7.4
-11 GMC 2500HD SLE CCSB 6.0
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Old 05-23-2018, 07:52 PM   #7
SoCalSlaughter
The factory iron intake and the new EdelBrock intake both have the rear water passage, and heater hose fitting is in the back of the intake
Pic of both below VVV
https://scontent-sjc3-1.xx.fbcdn.net...fd&oe=5B9199D0
Old 05-23-2018, 09:15 PM   #8
geezer#99
geezer#99's Avatar
Like I said, I’ve never seen one with a rear passage.
And I still haven’t.
There’s no passage there, just a port for the heater hose. A passage runs from head to head. Those don’t have that.
If there was a passage the motor would run extremely hot with limited water flow in the heads.
Old 05-23-2018, 09:20 PM   #9
jjzepplin
jjzepplin's Avatar
My Air Gap has both rear passages plumbed to a plate beneath the thermostat. 406 small block and has never overheated.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 3.73 posi-4-speed Saginaw-307-no budget build.
58 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=756563
99 Trans Am Donor?http://67-72chevytrucks.com/vboard/s...d.php?t=771213
jjzepplin is offline   Reply With Quote
Old 05-23-2018, 09:23 PM   #10
SoCalSlaughter
Ok, here is a bottom shot of the intake. You can clearly see the coolant passages by the dizz hole in the rear of the intake, head to head.
https://scontent-sjc3-1.xx.fbcdn.net...a4&oe=5B840F2D
Old 05-23-2018, 10:30 PM   #11
geezer#99
geezer#99's Avatar
I stand corrected!
My apologies for doubting you!
Old 05-29-2018, 08:09 PM   #12
SoCalSlaughter
So I finished replacing the intake manifold gaskets. Drove the truck about 18 miles today. Runs/drives great. I popped the hood when I got home and noticed the TBI unit was sweating/had condensation on it. It was cold to the touch. Removed the oil cap and it had a few tiny water droplets on the inside of it. Is this normal?
Old 06-02-2018, 06:56 PM   #13
67 Burb
67 Burb's Avatar
You're not getting any heat to the throttle body. The water passage in the TBI intake runs front to back (or back to front?) to warm the throttle body. See the photo.
What intake gaskets are you using? The ones with the rear coolant passage block-off? Are the heater hoses hooked up? Because the rear passage is blocked off except for a 3/32" hole in each gasket block-off, I think the coolant has to circulate through the heater hoses. (Just guessing on that though.)
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
