Old 05-30-2018, 10:54 PM   #1
shortbed70
shortbed70's Avatar
64 c10 rear axle
So my factory lsd 12 bolt is a 64 model with the pssangers side panhard mount on the axle. My question is I believe itís a 17 spline axle and Iím wanting to swap from 6 lug to 5x4.75 chevelle pattern. Where is a good place to get axles that wonít break the bank and also spider gears that wil work with the factory lsd.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-31-2018, 12:18 AM   #2
Captainfab
60-66 Nut
Re: 64 c10 rear axle
If the wheel bearing surface on your current axles is good, I would just have the wheel stud holes plugged and redrilled to 5 x 4.75. You will have to have the hub register machined as well. I do make a rear disc brake conversion bracket set for the 5 x 4.75 that will bolt up to the truck/Impala backing plate flange. I also have a set of good 17 spline axles.
Captainfab is online now   Reply With Quote
Old 05-31-2018, 12:34 AM   #3
shortbed70
shortbed70's Avatar
Thank you for the reply. My boss doesnít really like redrilling axles so he recommended moser (sp)
Troy
Big Red Dog build
Old 05-31-2018, 03:44 PM   #4
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
Call Quick Performance they have the whole ball of wax for you. I bought everything I needed from them to keep my 64 12 bolt and make it 5 lug, posi, moser axles, Eaton Clutch Posi Unit, Truck Master Bearing / Install Kit, Eaton Clutch Posi Unit, Ring & Pinion Gear Set. Call em.
http://www.quickperformance.com/GM-1...e_p_20373.html
Old 05-31-2018, 11:34 PM   #5
Captainfab
60-66 Nut
I re recommended keeping your original axles since to my knowledge, no one makes 17 spline axles. Plus by the time you replace the side spiders in your current LSD, (if you can find them) you will be close to half the cost of a new posi unit. It sounded like you were on a tight budget. A new posi unit plus a set of aftermarket custom axles will run you $8-900 easily.
Old 06-01-2018, 04:18 PM   #6
61K10
61K10's Avatar
ck out Dutchman Axles. They might make them for you.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-02-2018, 08:55 PM   #7
shortbed70
shortbed70's Avatar
Very limited budget. Might see if I can work of some mods this winter with my boss. Trying to get my rear narrowed so all I have to do is buy axles. Heís got a line on them being a vendor
Troy
Big Red Dog build
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
